I accidentally deleted important files from my hard drive and emptied the Recycle Bin before realizing it. I’m trying to find the best way to recover deleted files from a hard drive without making things worse, and I really need advice on what recovery tools or steps actually work.
Losing files feels awful. I’ve been there, and the part where people panic and keep clicking around is usually what makes it worse. If the drive still works, your odds are often decent, but only if you stop touching it now.
First step, stop using the drive. Right now. When a file gets deleted, the data usually stays on the disk for a while. The system only marks the space as available. Once new data lands there, recovery starts falling apart fast. So don’t install anything to it, don’t move files onto it, and don’t keep using it like normal.
If the deleted stuff was on a second internal drive or an external drive, unplug it and hook it up to another computer for recovery. That’s the cleanest path. If it was on your Windows or macOS boot drive, things get trickier. I’d boot from a USB stick or use another machine if you have one, because your main OS keeps writing temp files and logs in the background.
What I’d do next is install Disk Drill onto a different drive, not the one with the missing files. People miss this part all the time, then wonder why recovery got worse. One useful thing in Disk Drill is the option to make a full byte-by-byte image of the drive first. I like doing that when the data matters, because then you scan the copy instead of poking at the original disk over and over. It also shows previews before recovery, which saves time when you’re sorting through renamed junk and half-broken file trees. The free version lets you scan and preview, then you pay only if you want to restore.
A few things I’d keep in mind:
- Hard drives usually give you a better shot than SSDs. Old-school HDDs tend to leave deleted data sitting around longer. Still, don’t relax. Some newer hard drives support TRIM too, and once cleanup happens, recovery gets uglier.
- If the drive clicks, grinds, or keeps dropping offline, stop. I would not run recovery software on a drive with mechanical trouble. That’s lab territory.
- One deep scan is enough. Running scan after scan doesn’t magically pull new files out of nowhere. It mostly wastes time and adds stress to a weak drive.
If Disk Drill doesn’t get it done, I’d try a second tool before giving up. Recuva is easy and quick for simpler deletions. DiskGenius is better when partitions or file systems look messed up. Data Rescue is one I’ve seen Mac users lean on. I still had better luck with Disk Drill for a mix of ease and scan depth, but those are decent fallback options.
Move fast, keep the drive idle, and don’t start experimenting on the original disk. If you handle it carefully, you still might get most of it back.
I’ve recovered deleted files from HDDs more than once. Success rate depends on 3 things. Drive type, time since deletion, and whether you kept using it.
I agree with @mikeappsreviewer on stopping use of the drive. I disagree a bit on trying multiple apps right away. If the files matter, clone first, then test tools on the clone. Less risk, less wear.
My order would be:
- Check cloud sync trash, OneDrive, Google Drive, Dropbox.
- Check File History on Windows, Previous Versions, or Time Machine on Mac.
- If nothing is there, make a sector-by-sector image.
- Scan the image with Disk Drill.
- Recover files to a different drive.
Why I push backups first. They bring back original names and folders. Raw recovery often gives you a pile of files with random names. For photos and docs, file carving works ok. For big videos or project files, results get messy fast.
If it’s an SSD, odds drop a lot because TRIM wipes deleted blocks fast. On a normal HDD, I’ve seen recoveries work days later if the disk stayed mostly idle. If the drive is making noises or reads slow as hell, stop and use a lab.
For anyone searching this later, this is a solid guide for recovering permanently deleted files from a hard drive, SSD, USB drive, or memory card, with less risk of overwriting data. Also worth a quick watch, easy deleted file recovery tips for hard drives.
Main thing, do not restore back onto the same drive. Thats where people screw it up.
One thing I’d add to what @mikeappsreviewer and @viajeroceleste said: before you jump straight into recovery software, check whether the files were ever opened from an app that keeps its own recovery cache. Word, Excel, Photoshop, some video editors, even PDF apps sometimes leave autosave/temp copies behind. People forget this all the time, and it can be way cleaner than raw file recovery.
Also, slight disagreement on the “deep scan asap” mindset. If the files are super important, I’d actually avoid a long scan on the original drive unless you already know the drive is healthy. First look at SMART status with something simple. If the HDD has reallocated sectors, read errors, or is acting flaky, scanning can turn a recoverable situation into a way bigger mess.
For actual file recovery, yeah, Disk Drill is a solid option, mostly because it handles both deleted file scanning and image-based recovery without being a total pain. I’ve had better results when searching by file type + modified date instead of relying on folder structure, which is often toast after Recycle Bin emptying. Recuva is fine for basic stuff, but if filenames matter, results can be hit or miss.
Another thing people do wrong: they recover everything. Don’t. Recover a few critical files first, test them, then go after the rest. Saves a lot of time and avoids false hope.
If this was an external hard drive and not your system drive, your chances are usualy way better. Also worth reading this external hard drive data recovery success story and tips.
If the drive starts clicking, slows to a crawl, or disconnects, stop DIY stuff imediately. That’s lab territory, not “try one more scan” territory.
One small disagreement with @viajeroceleste, @codecrafter, and @mikeappsreviewer: people focus so much on recovery apps that they skip the boring but useful check of the file system itself. On an HDD, if the deletion was recent, sometimes the MFT or directory entries still leave enough metadata for a cleaner recovery than a giant raw carve.
What I’d do is this:
- Mount the drive read-only if possible.
- Check whether the lost files were in a known folder with stable names.
- Run a filesystem-aware scan first, not an all-out deep carve.
- Only use raw recovery if that fails.
That matters because deep scans often return thousands of files with useless names.
Disk Drill is good here because it lets you separate scan results pretty clearly.
Pros:
- easy previews
- can image the drive
- decent sorting/filtering
- handles common file systems well
Cons:
- deep scans can be noisy
- paid recovery
- huge result sets can get messy
If you want alternatives after that, Recuva and DiskGenius are still worth a look, but test recover a few files first, not everything at once.
Also, if the deleted files were fragmented video files, temper expectations. Those are often the first things to come back corrupted even when photos and docs recover fine.
