Can anyone help me recover deleted videos from an SD card?
I accidentally deleted important videos from my SD card while clearing space, and I stopped using it right away so nothing would get overwritten. These files are really important, and I need advice on the best way to recover deleted videos from an SD card, including safe recovery software or steps that actually work.
I’ve lost enough clips off SD cards to skip the fake suspense. Yes, deleted video is often recoverable. On most cameras, deleting a file does not wipe the data right away. The card marks the space as free, then future recordings take it over later. If nothing new landed on those sectors yet, your footage still has a shot.
First thing, stop using the card. Right now. Don’t shoot more video. Don’t snap photos. Don’t format it, even if Windows pops up a message and acts dramatic. Every write to the card cuts into your odds.
If your computer still sees the SD card, even as RAW or with a format prompt, I’d start with Disk Drill. I tried a few tools over time, and the part worth caring about here is Advanced Camera Recovery. Camera video often gets saved in chunks, not one neat block. Action cams, drones, dashcams, mirrorless bodies, all of them tend to leave footage scattered around the card. Plain file recovery tools sometimes pull back a broken shell, or a clip half a minute long when the original was twenty. Advanced Camera Recovery looks for those separated pieces and rebuilds them into one playable file. For footage from GoPro, DJI, Sony, Canon, Nikon, Fujifilm, Insta360, and similar gear, this matters a lot.
What I’d do:
  1. Download Disk Drill from the official CleverFiles site. Pick the Windows or macOS version you need.
  2. Install it and open it.
  3. Plug in the SD card with a card reader. I’d avoid connecting through the camera if you have a reader nearby. Direct access tends to go smoother.
  4. In Disk Drill, find your SD card in the device list. Click “Search for lost data.”
  5. When it asks for the recovery method, choose Advanced Camera Recovery. If your missing files are video from a camera, this is the mode I’d use first.
  6. Wait out the scan. Small card, fast card, healthy card, it might finish quickly. Large or flaky cards take a while. I’ve seen scans run past an hour.
  7. Hit “Review found items” in the upper-right area once results start showing up.
  8. Use the filters and search options so you’re not digging through junk. Sort by type, size, date, whatever helps narrow it down.
  9. Preview the clips before restoring them. This step saves time. If a preview plays, your odds are better. If it doesn’t, don’t assume the file is good.
  10. Select the videos you want and press “Recover.”
  11. Pick a different destination, like your internal SSD or another external drive.
  12. Do not recover back onto the same SD card. I’ve seen people do this once, and yeah, it went badly.
  13. After recovery finishes, open the files in your normal media player and check them end to end if the footage matters.
After that, the restored files should show up in File Explorer on Windows or Finder on macOS. Disk Drill for Windows restores up to 100 MB for free. On Mac, you’re able to scan and preview first, then decide if paying for a license makes sense.
One thing I’d do for anything important, paid work, family trip, legal stuff, one-time event, is make a byte-for-byte image of the card before touching recovery. Here’s the video link mentioned for that process:
This gives you an exact copy of the SD card, so your recovery attempts happen on the copy instead of the original. I learned to like this approach after messing up a card years ago. It keeps the source untouched, which helps if you need a second pass later.
Software recovery is fine for a lot of cases. Still, I’d stop and hand it off to a pro if any of this is happening:
  1. The SD card has physical damage. Cracks, bends, water exposure, any of it.
  2. Your computer does not detect the card at all.
  3. The card disconnects during scanning.
  4. It gets hot fast after plugging it in. I would not keep testing it at that point.
  5. Your camera throws hardware or media errors.
  6. The missing footage carries serious personal, business, or legal weight.
If the card still shows up in Disk Drill and it isn’t physically damaged, trying software first makes sense. Speed matters here. Stop using the card, start recovery as soon as you can, and your odds are usually better.
You did the right first step. Stop using the SD card. That gives you the best shot.
I agree with @mikeappsreviewer on one big point, recover from a card reader, not through the camera. I differ a bit on process. Before running any recovery app, I’d check the card’s health first if you’re on Windows. Use a tool like H2testw or SD Card Formatter only for diagnosis, not for writing or formatting. If the card drops connection or reads at weird speeds, stop. Software recovery gets messy fast on failing media.
If the card is stable, Disk Drill is a solid pick for deleted video recovery from an SD card. Scan first, preview what it finds, then save recovered clips to your computer, never back to the card. For deleted videos, file size matters. If your clips were 2 GB each and the scan shows 40 MB fragments, expect partial recovery. If you see files near the original sizes, your odds go up a lot.
One more thing people skip, copy the whole card to an image file first if possible. Then work from the image. Less risk, fewer oops moments.
Also, this short guide on SD card video recovery is worth a look:
quick SD card video recovery tip
If the videos are for work, legal stuff, or a one-time event, I would skip home tools after one failed scan and go to a recovery lab. Repeated scans are where people make it worse, ask me how I know lol.
You already did the most important thing, which is stop using the card. That part matters more than people think.
I mostly agree with @mikeappsreviewer and @mike34, but I would not spend too much time “testing” the card if these videos are irreplaceable. Every extra mount, scan, and retry is still stress on the card. If it reads normally, move straight to recovery or, even better, make an image first and work from that.
A couple practical things that haven’t been said as clearly:
  • If the videos came from a phone, check the phone’s gallery trash/recently deleted folder too. Some people assume the SD card copy is gone when the phone still has a cached or synced version.
  • Check cloud backups before doing anything heroic. Google Photos, iCloud, OneDrive, Dropbox, camera vendor apps, all the boring stuff people forget.
  • If the card was used in an Android phone as “internal/adopted storage,” recovery gets way harder because files may be encrypted. In that case, random tools can be a waste of time.
If the card shows up fine on your computer, Disk Drill is a reasonable option for SD card deleted video recovery. I’d focus less on the file names and more on whether previews actually play and whether recovered file sizes look realistic. Big video files that come back tiny are usually bad news.
Also, if the footage is super important, wedding, legal, paid work, once-in-a-lifetime family stuff, I’d seriously consider a recovery lab before doing multiple scans. That’s where I slightly disagree with the “just keep trying software” mindset people sometimes have. Sometimes DIY works. Sometimes it just burns time and your shot at a cleaner recovery.
This thread is also pretty relevant if you want more opinions on recovering deleted home videos from an SD card:
best chance of recovering home videos from an SD card
Short version: no new writes, card reader only, recover to another drive, and don’t panic-click format if Windows gets weird about it. That part gets ppl every time.
I’m with @mike34 and @cazadordeestrellas on one key thing: if these videos are truly irreplaceable, don’t turn this into a weekend of endless “one more scan.” I slightly disagree with the idea of doing much health checking first unless the card is acting weird already. If it mounts cleanly, I’d either image it immediately or run one careful recovery pass and stop there.
A couple things that help specifically with video recovery that people miss:
  • Try to remember the exact camera/app that made the files. Video containers matter. MP4, MOV, AVCHD, GoPro chaptered files, DJI clips, dashcam segments, all recover differently.
  • If recovered videos won’t play, they may still be salvageable with a video repair tool because sometimes the payload is there but the header is damaged.
  • Sort scan results by file signature/type, not just original folder names. Deleted SD footage often comes back without the old names.
On software, Disk Drill is a fair choice if the card is still readable.
Pros of Disk Drill
  • good at finding deleted media on SD cards
  • preview helps weed out obvious junk
  • interface is easy enough that you’re less likely to click the wrong thing
  • supports imaging, which is the safer route
Cons of Disk Drill
  • deep scans can return a lot of messy, renamed results
  • free recovery limits can be annoying on big video files
  • if the card has real hardware issues, software won’t magically fix that
Compared with what @mikeappsreviewer, @mike34, and @cazadordeestrellas were saying, my added advice is this: after recovery, test each recovered clip fully, not just the first 10 seconds. Corruption often shows up halfway through long videos.
If the card disconnects even once, stop DIY and go pro. That’s the line I wouldn’t cross.
