My WD My Passport external hard drive suddenly stopped opening and now my computer either won’t detect it or asks me to format it. I have important photos and work files on it, so I’m looking for reliable data recovery software for WD Passport drives that can help me recover files without making things worse.
I’ve messed with a lot of WD My Passport drives, and “my files vanished” usually does not mean the data is dead. More often, I found the drive itself still worked, and the mess was in the file system, the partition table, or a bad delete.
First thing I’d do is check whether Windows still sees the drive.
Open Disk Management and find the WD My Passport in the disk list. I would ignore the drive letter for now. What matters first is simple. Does Windows detect the device, and does the listed size look close to what the drive should be?
If the capacity looks right, I’d take it as a decent sign. Even when Windows marks it as RAW or Unallocated, or throws up a format prompt, I’ve still had good recovery results. The hardware is at least talking back. Different story if the drive never shows up, drops in and out, or starts making odd clicks or grinding noises. At that point I’d suspect hardware trouble before anything else.
If the drive is visible, stop writing to it. Seriously. I learned this the annoying way once after copying random stuff onto a drive before recovery. If files were deleted recently, or the partition went inaccessible out of nowhere, new writes eat space where recoverable data might still be sitting.
Before you run recovery software, check whether the files already exist somewhere else. I’ve seen people spend half a day scanning a drive, then realize their folders had been synced to OneDrive, Google Drive, Dropbox, or some other cloud account the whole time. It sounds dumb until it happens to you.
If there’s no backup, I’d go straight to recovery software.
For WD My Passport drives, I usually start with Disk Drill. I’ve had decent luck with it on deleted files, formatted partitions, and RAW volumes. It also handles NTFS and exFAT well, which is what I keep seeing on these drives. The preview feature helps a lot too, since you get a quick reality check before wasting time recovering junk.
This is the flow I’d use:
- Install the software on your PC, not on the WD drive.
- Connect the My Passport and wait for the software to detect it.
- If the drive is unstable or keeps acting weird, make a byte-for-byte backup first and scan the image instead of the original drive.
- Run a full scan.
- Go through the results and preview anything important. If a photo, video, or document opens fine in preview, I usually feel pretty good about recovery odds.
- Save recovered files to a different drive.
After you get your files back, set up backup before putting the drive back into normal use. External drives are fine for storage, but I would never keep the only copy of important stuff on one. Use File History, Acronis, cloud sync, whatever fits your setup. One extra copy saves you from doing this whole mess agian.
If the WD Passport shows up off and on, I would start with a clone first, not a direct scan. I know @mikeappsreviewer mentioned imaging if the drive is unstable, and I agree with that part more than jumping straight into recovery. A flaky USB board or weak sectors gets worse fast.
For software, Disk Drill is a solid pick for WD My Passport data recovery. I’ve seen it pull photos and Office files off RAW and formatted external drives with filenames intact more often than stuff like Recuva. R-Studio is stronger for advanced cases, but it’s less friendly and easier to mess up if you’re stressed and in a rush.
My short list:
- Disk Drill, best balance of easy use and results.
- R-Studio, better for deeper work.
- PhotoRec, free, messy output, but decent for photos.
One thing I disagree on a bit. If your computer does not detect the drive at all, software is not where I’d spend time first. Swap cable, port, and power situation. WD Passports are annoyngly sensitive to bad USB cables.
If you want a simple Windows walkthrough, this easy Windows hard drive recovery guide is worth a look.
Do not format it. Do not run CHKDSK. Those two choices screw people over all the time.
If the WD Passport is still showing the correct capacity sometimes, I’d actually put UFS Explorer or R-Studio on the shortlist before the usual beginner stuff. Slightly disagreeing with @mikeappsreviewer and @cacadordeestrelas here: Disk Drill is probly the easiest recommendation, but “easy” is not always the same as “best” if the partition metadata is trashed.
That said, Disk Drill for WD My Passport recovery is still a very reasonable first try if you want something less nerdy and faster to navigate. The preview is useful, and for photos/docs it saves a lot of guesswork. If you want a simple breakdown, this Disk Drill review for external hard drive recovery is worth a skim.
My take:
- If the drive is detected with size shown, use software.
- If it disconnects randomly, clone first if possible.
- If it clicks, slows to a crawl, or vanishes entirely, stop DIY stuff.
Also, small thing people skip: check Device Manager and SMART with CrystalDiskInfo if it stays connected long enough. That can tell you whether this is logical damage or the drive slowly dying. If SMART is bad, don’t keep rescanning it for hours. That’s how a recoverable drive turns into ewaste.
And yeah, don’t format it even “just to see if it works.” That trick is how people make a bad day worse.
