I keep seeing people talk about LLMs in AI, but the explanations I find are either too technical or too vague. I’m trying to understand what a large language model actually is, how it works in simple terms, and what makes it different from other AI models. I need help breaking this down so I can figure out when and why I should use an LLM in my own projects.
Think of an LLM as a text prediction engine that got huge and trained on tons of data.
Here is the simple breakdown.
What an LLM is
Large Language Model = a big statistical model that learns patterns in text.
You give it text as input.
It predicts the next token (piece of text) over and over.
Tokens are usually chunks of words, not full words. -
How it learns
Training data: internet pages, books, code, forums, docs, etc.
Goal: “Given the previous tokens, what is the most likely next token.”
It repeats this on billions or trillions of tokens.
Over time it learns:
- grammar
- common facts
- writing styles
- coding patterns
It does not store a copy of the web.
It stores numeric weights that encode patterns.
How it works when you use it
You type a prompt.
The model turns text into tokens.
It runs those tokens through many transformer layers.
Each layer updates an internal vector that represents meaning.
At the end, it outputs a probability distribution for the next token.
It samples one token, adds it, repeats.
That loop looks like “chatting” to you. -
Why it feels smart
Text prediction, at scale, looks like reasoning.
If you see tons of math problems, predicting the next step in a solution looks like doing math.
If you see lots of Q&A, predicting the answer looks like understanding.
But under the hood it is still pattern matching and probability. -
What makes a model “large”
- Number of parameters: billions to trillions of weights
- Amount of training data: terabytes of text
- Compute used: big clusters of GPUs
More parameters let it store more patterns.
More data exposes it to more situations.
- What they are good at
- Summarizing text or docs
- Explaining topics in simple language
- Writing code or helping debug
- Drafting emails, reports, and posts
- Converting between languages or formats
- Acting as a “glue” between tools and APIs
- What they are bad at
- Reliable facts without checking sources
- Exact math for long multi step problems
- Up to date info if trained on old data
- True understanding of the physical world
They also hallucinate.
That means they output something that looks right but is false.
How you can use one in practice
For learning: “Explain X to me like I am 15.”
For work: “Summarize this doc into 5 bullet points.”
For coding: “Write a Python function that does Y, then show tests.”
For writing: “Draft a polite response to this email.”
Then you edit the output, do not trust it blindly. -
Mental model for you
Treat it like a smart autocomplete that has read a lot.
Give it clear instructions.
Give it examples.
Ask it to show steps.
Validate anything important with external sources.
If you want to go one step deeper, look up “transformer attention” and “tokens” next. Those two topics explain 80 percent of what matters about how LLMs work day to day.
Think of an LLM as “a brain that only lives in text,” not in the real world.
@byteguru’s “smart autocomplete” description is pretty solid, but I’d tweak one thing: calling it just pattern matching can make it sound dumber than it behaves. The scale and structure actually let it do some surprisingly general reasoning, even if it’s not thinking like a human.
Let me break it in a slightly different way:
- What an LLM is
It’s a giant math function that:
- takes text in
- turns it into numbers
- transforms those numbers a bunch of times
- turns them back into text
It has no database of facts, no lookup tables. Just a massive pile of numbers (parameters) that encode “how pieces of text relate to each other.”
- How it actually learns (conceptually, not engineer-speak)
Instead of “learning facts,” it does this over and over during training:
- See:
The capital of France is - Guess the next word
- If it guessed
Berlin, it gets “punished” mathematically - If it guessed
Paris, it gets “rewarded” - Nudge all its internal numbers slightly toward the better guess
Repeat trillions of times on all sorts of text. Those tiny nudges add up to a system that has internal structures that correlate with concepts like “countries,” “capitals,” “if…then…,” “steps in a proof,” etc.
So it doesn’t memorize a big FAQ page. It learns something closer to:
“When you see a pattern that looks like a country question, capital names tend to follow, and this vector of numbers looks like ‘France’ which connects strongly to this other vector that looks like ‘Paris’.”
- Why it feels like understanding
This is the confusing part. LLMs:
- Don’t have goals, feelings, or real-world experience
- Do not “know” you or themselves in any deep sense
But:
- If they’ve seen 100k math solutions, they learn a general structure of what a math solution looks like
- If they’ve seen lots of reasoning, they can reproduce the shape of reasoning
So when you ask “why do we see seasons,” it can generate a chain of explanation that matches explanations it’s seen. That looks like understanding. Whether you call that “understanding” is more philosophy than engineering tbh.
- What makes it “large” in a way that actually matters
Not just “bigger number go brrr.” Larger models:
- Can represent more subtle distinctions. “Dog vs wolf vs fox vs metaphorical ‘wolf in sheep’s clothing’”
- Can hold more context in their “mind” at once
- Can combine ideas more flexibly, like using math style in a code example inside a legal explanation
At small sizes, they sound like a glitchy autocomplete. At large sizes + lots of data, they start to handle multi-step instructions and subtle context.
- How it runs when you talk to it (intuitive view)
Conversation is basically:
- You: dump text in
- Model: builds a sort of temporary “thought cloud” in its internal vectors representing what you said
- From that cloud, it predicts the next token
- That new token gets added to the input
- The thought cloud updates a bit
- Repeat
So the “state of the conversation” is encoded in a big, constantly updated numeric summary. It’s not remembering each sentence as a separate thing like we do. It’s compressing your whole convo into one evolving blob of meaning.
- What it’s distinctly bad at (in non-handwavy terms)
Some of this gets brushed off as “hallucinations,” but there are real structural reasons:
No ground truth check
It cannot look at the outside world unless someone bolts tools or a browser on top of it. By default, it just guesses what text looks right. -
Weak on long, fragile logic
Long chains of reasoning are tricky because each step is a prediction that can drift. Errors compound. -
No built-in concept of time
It doesn’t “know” today is 2026. It only knows distributions of text up to its training cutoff. Everything “new” is extrapolation or from tools.
- Why people build apps around LLMs instead of just “asking the model”
Raw LLM = text in, text out.
Useful systems = LLM + tools + constraints.
Examples:
“Agent” that:
- uses the LLM to decide what to do
- calls external APIs / search / databases
- uses the LLM again to explain the results
Coding assistant that:
- uses an LLM
- but also parses code, runs tests, uses static analysis
So the LLM is like a very flexible brain-in-a-box that you wire up to other stuff to keep it grounded and less unreliable.
- How to mentally file it
Personally, I’d go slightly stronger than “smart autocomplete” and think of it as:
“A text-only reasoning engine, trained on ridiculous amounts of data, that simulates how humans talk, explain, and solve problems, but has zero direct access to reality unless you give it tools.”
That framing captures:
- why it’s shockingly helpful
- why it can be totally confidently wrong
- why smaller versions suck more
- why people debate whether it “understands” anything
If you want to dig one step deeper next, I’d look up:
- “word embeddings” or “token embeddings”
- “attention heads as pattern detectors”
Those are the bits that explain how this big pile of numbers can actually represent structure instead of random noise.
And yeah, still double-check whatever it says when it actually matters. LLMs are like that friend who’s super articulate and sometimes just… makes stuff up with a straight face.
Think of LLMs as very advanced text habits, not mini people.
@byteguru did a great job with the “smart autocomplete” picture. I’d push back slightly on the “brain that only lives in text” metaphor though, because it tempts people to imagine feelings, beliefs, or intentions. What’s really there is closer to:
A gigantic mathematical surface that lets us slide from one piece of text to the most statistically compatible next piece.
That sounds abstract, so here is a different angle that complements what was already said:
1. What an LLM actually stores
It does not store:
- A list of facts
- Sentences from the web as-is
- A mental map of the world
It does store:
- A compressed geometry of language
- Distances like “how similar is ‘doctor’ to ‘physician’ vs ‘stethoscope’”
- Directions like “move this way in the space and you go from singular to plural, from present to past, from casual to formal”
So instead of remembering “Paris is the capital of France” as a sentence, it has a configuration where the “France” direction lines up strongly with the “Paris” direction in a pattern typical of capital-city relations.
That is why it can sometimes invent a plausible but wrong capital. The geometry might put “Sydney” close enough to “Australia” that it slides there, even though the real answer is “Canberra.”
2. Why it sometimes feels smarter than pattern matching
Calling it “just pattern matching” misses that the patterns live in a continuous space. That lets it:
- Interpolate between examples it has seen
- Combine fragments of patterns in new ways
- Generalize to things it has never exactly encountered
For example, if it has never seen your specific code bug, it can still:
- Recognize the shape “off by one” or “null pointer style” pattern
- Map your snippet into that concept region
- Generate a fix that follows the pattern of other fixes
Is that “reasoning”? Engineers will argue about the word. Functionally, it often behaves like weak, approximate reasoning backed by a ton of examples.
3. Where I’d disagree a bit with the “text-only reasoning engine”
I like that description but I’d add a caveat:
LLMs are context junkies. They are only as “rational” as the context you feed them.
- If you give them a prompt shaped like a rant, you get rant-flavored output.
- If you give them a prompt shaped like a careful proof, you get more careful, stepwise output.
So they are not general reasoning engines in a vacuum. They are style-and-structure amplifiers that can carry out reasoning if you cue them into that mode. No cue, and they fall back to loose, “sounds right” text.
4. “Large” matters less for facts, more for behavior
Size helps with:
- Richer concepts: not just “dog” but “guard dog vs family pet vs literary symbol”
- Stability: fewer random nonsense jumps
- Instruction following: multi-step tasks, multiple constraints at once
But bigger does not automatically mean:
- Always factual
- Always logical
- Safe by default
You can think of small models as toddlers with a handful of word games, and large models as adults with a huge collection of scripts. Both are still driven by statistical prediction, not by a truth meter.
5. Pros and cons of using an LLM as your mental model of “AI”
This is where I’ll fold in the kind of pros/cons list people usually want when they hear the term.
- Very broad skills: explanation, summarization, basic coding, translation, brainstorming
- Flexible: same underlying system can chat, write, reason, and format
- No task-specific training needed for each new prompt
- Easy to interact with: natural language instead of programming syntax
- Unreliable on specific facts without tools or verification
- Can sound confident when wrong
- Limited awareness of time, current events, or your actual environment
- Struggles with very long, fragile chains of logic
All of that flows from the same core: it is built to continue text coherently, not to prove things true.
6. How to mentally file it (slightly different from @byteguru’s take)
Instead of “a brain that only lives in text,” I’d suggest:
“A high-dimensional language map that lets you walk from your question to a likely answer-path, using patterns learned from huge piles of human writing.”
This keeps the focus on:
- Maps, not memories
- Paths, not static facts
- Likely answer-paths, not guaranteed truths
That framing helps you remember to:
- Use it as a first draft, not final authority
- Pair it with tools (search, code execution, calculators) for anything critical
- Judge it by behavior, not by imagined inner life
@byteguru gave a solid mechanical picture with training examples like “The capital of France is …”. The angle here is more about how to think about what is really inside the model so you do not over-trust it or under-estimate it.
If you end up building with LLMs later, this mental model makes it much easier to design prompts, evaluation, and guardrails that play to their strengths and cage their weaknesses.
