I accidentally formatted the wrong SD card and lost important photos and files I hadn’t backed up. I need help figuring out the best SD card recovery steps, what to avoid doing next, and whether there’s a real chance of getting the data back.
I’ve been in this spot before, and the first move is simple. Stop using the SD card right now.
If the card was formatted by a camera, drone, phone, or a Windows PC, it was often a quick format. That usually wipes the index, not the photo and video data itself. The files often still sit on the card until new stuff gets written over them. So if you haven’t shot more clips or copied new files onto it, your odds are still decent.
What hurts recovery fast:
- taking more photos
- recording new video
- moving files onto the card
- running random “repair” tools on it
What I’d do next is use recovery software from a computer. I’d start with Disk Drill. I found it easier to work through than some of the older tools, and it tends to do well with formatted SD cards. The preview part matters more than people think, since you can check if a photo opens or a clip looks intact before saving it somewhere else. If your lost files came from action cams, drones, or dash cams, its Advanced Camera Recovery mode is worth trying because those videos get fragmented a lot.
Here’s the basic flow I’d follow:
- Pull the SD card out of the device.
- Use a card reader and connect it to your computer.
- Install the recovery app on your computer’s internal drive, not on the SD card.
- Scan the card.
- Look through the preview results.
- Save recovered files to your computer or a different external drive.
If you want other options, Recuva is fine for easier cases. I used it years ago and it worked for a few deleted photos, but it was weaker once formatting and broken-up video files got involved. UFS Explorer is stronger when things are messy, like partial corruption or damaged file systems, though the interface feels more geared toward people who already know what they’re doing.
One thing people miss. If the card keeps disconnecting, shows up and vanishes, turns painfully slow, or your computer won’t detect it at all, I’d stop with software. That starts looking less like a simple format issue and more like hardware trouble. In that case, a recovery lab makes more sense, since repeated scans on a failing card sometimes make the outcome worse.
If the card was quick-formatted, recovery odds are still decent. Full format is worse, but not always fatal. The big factor is overwrite rate. If you wrote 0 new files after formatting, recovery rates for photos are often pretty solid. Once new video hits the card, odds drop fast.
I agree with @mikeappsreviewer on stopping use right away. I differ a bit on one point. Before running multiple scans, make one image copy of the SD card if your software supports it. Work from the image, not the card. Fewer reads. Less risk if the card starts acting weird.
My order would be:
- Write-protect the SD card if it has a lock switch.
- Connect by reader, not through the camera.
- Check Disk Management or Disk Utility. If size looks wrong, stop.
- Create a byte-for-byte image first.
- Run recovery on the image with Disk Drill or another solid scanner.
- Recover to a different drive.
If photos matter most, sort results by file type and date first. If filenames are gone, EXIF data often survives. That helps a ton.
Skip CHKDSK, First Aid repair, and anything offering to “fix” the card. Those tools are for file system repair, not safe recovery. They sometimes make a mess.
If you want more examples from people who recovered pics after formatting, this thread is useful: recover photos after formatting an SD card.
For search purposes, think of this as SD card formatted by mistake, photo and file recovery steps.
If the card disconnects, gets hot, or reads at 0 bytes, stop and send it in. DIY gets risky fast. That part sucks, but it saves data more often than people think.
Yep, there’s still a real chance, but it depends on how the card was formatted and whether anything touched it afterward.
I agree with @mikeappsreviewer and @mike34 on the big picture, but I’m a little less eager to tell people to keep trying lots of software if the card is acting even slightly flaky. If it mounts normally and shows the correct capacity, cool, try recovery. If it freezes Explorer/Finder, reports weird size, or suddenly wants to be “initialized,” stop messing with it.
A couple things people forget:
- some cameras do a normal quick format, some do a more aggressive one
- SD cards can use wear leveling, so recovery can be less predictable than old hard drives
- if the files were RAW photos, you may recover them with generic names but intact metadata
What I’d do is one careful pass, not ten. Use Disk Drill first because formatted SD card recovery is one of the cases it handles pretty well, especially when you need previews to see what’s actually salvageable. If it finds your photos and they preview fine, recover them to another drive and call it done. Chasing a “better” scan with 5 more apps sometimes just wastes time.
Also, if the card had very important stuff like paid client photos, baby pics, legal docs, etc., I’d seriously consider skipping DIY entirely. That’s the part people hate hearing, but labs exist for a reason.
One more useful resource if you want a visual walkthrough: step-by-step SD card recovery tutorial for deleted or formatted files
Short version: if you formatted the wrong SD card and did not reuse it, your odds are decent. If you kept shooting video after the format, odds drop fast. Don’t “repair” it, don’t save anything back to it, and don’t panic-click every tool you can find. That’s how people turn a recoverable mistake into a permanant one.
Big thing nobody has mentioned enough: if the card was encrypted by the device, recovery software may only pull junk unless you read it through the original device or with the same app flow. Not super common for plain cameras, more common with some phones and action cams.
I mostly agree with @mike34, @boswandelaar, and @mikeappsreviewer, but I slightly disagree on doing too much “checking” before recovery. Even opening the card in apps that auto-generate thumbnails can cause writes on some systems. I’d keep it as close to read-only as possible and disable auto-import tools first.
A few practical checks:
- Look at the recovered file sizes, not just filenames.
- Test 3 to 5 previewed photos from different dates.
- For videos, try the tail end too. Fragmented clips often preview the first seconds only.
- If the card was reformatted in-camera after being used in another brand camera, folder structure recovery may be worse, but raw carving can still work.
Disk Drill is a reasonable first pass because previewing saves time.
Pros:
- easy to use
- good photo/video discovery after quick format
- preview is helpful
- can work well on SD cards
Cons:
- deep scans can take a while
- recovered names/folders may be messy
- license cost if you need full recovery
- not magic if data was overwritten
Competitor-wise, Recuva is lighter for simple deletes, and PhotoRec can dig up files but the output is chaotic. If this is irreplaceable data, one careful attempt is smarter than endless retries.
