My home Wi-Fi works fine near the router, but the signal drops badly in the back bedroom and upstairs. I’m thinking about buying a Wi-Fi extender, but I’ve read mixed reviews about speed loss, setup issues, and whether they really improve coverage. I need help figuring out if a Wi-Fi extender is worth it or if there’s a better fix for weak Wi-Fi signal at home.
The Part People Hate About Extenders
I learned this the annoying way. A Wi-Fi extender listens on the same radio, then repeats what it heard. So part of your throughput gets eaten in the process. If the router feeds the extender 300 Mbps, the far side often lands closer to 150 Mbps, sometimes worse once walls, distance, and neighbor Wi-Fi pile on.
So yeah, when people say extenders slow things down, they are not making it up. It is baked into how these things work.
There is a second issue, and for me it was almost worse. A lot of extenders spin up a separate SSID. You walk upstairs, your phone hangs onto the weaker network for too long, and now your apps feel broken even though Wi-Fi still shows bars. I had to toggle Wi-Fi off and on more than once. Some newer extenders fake a single network name, but the handoff still felt messy when I tested it.
Related thread here:
http://www.reddit.com/r/TechNook/comments/1s5a0zb/are_wifi_extenders_actually_worth_it
Cases Where an Extender Is Fine
If you have one bad spot and you mostly scroll, browse, watch YouTube, or stream something in one room, an extender might be enough. I would put a dual-band model somewhere between the router and the dead zone, like a hallway or stair landing.
Placement matters more than people think. Too far away, and it repeats a weak signal. Too close to the router, and it does not help the room you care about. I had to move one around three times before it stopped being useless. A quick speed test at each outlet saves time.
Where Mesh Starts Looking Better
For a four-level place, mesh makes more sense to me. It costs more up front, sure, but day to day it is less annoying. All nodes use one network name, and your phone or laptop usually shifts to the stronger node on its own while you move around. No manual reconnects. No standing on the stairs waiting for Instagram to wake up.
For 4 levels, I would expect 2 or 3 nodes. Price usually lands around €150 to €300 or more, depending on brand and kit size. TP-Link Deco and Eero come up a lot for a reason. They are in the middle on price and easy to set up.
If you also care about rooftop coverage, extenders start to look rough fast. Concrete floors chew through signal. At that point you end up thinking about one extender per floor, which gets messy and not cheap either. Once I penciled out the numbers, the gap between stacking extenders and buying a starter mesh kit did not look huge anymore.
What I Would Do
If money is tight, I would try one decent extender first, placed between floors 2 and 3 on the landing. Test there before buying more stuff.
If you want the roof covered too, or you want the network to feel like one network instead of a patchwork fix, I would skip straight to mesh. A 2-node kit is often enough for floors 2 and 3, then you add another node later if the roof still needs help. That route felt less frustating for me.
Yes, extenders help, but only when your problem is coverage, not weak internet service.
Simple test first. Stand next to the router and run a speed test. Then run one in the bad bedroom. If you get 300 Mbps near the router and 20 Mbps in the bedroom, your issue is Wi-Fi coverage. An extender is a cheap fix. If you get 25 Mbps near the router and 20 Mbps in the bedroom, your ISP plan or modem is the bottleneck, not the Wi-Fi.
I agree with @mikeappsreviewer on one thing, placement decides if the extender works or sucks. I disagree a bit on extenders being too messy by default. Newer ones are less annoying than older models if you buy from a decent brand and keep expectations normal.
My rule:
- One bad room, buy an extender.
- Whole house, buy mesh.
- If you have ethernet in the walls, use a wired access point instead. Best option by far.
Important part people miss. Put the extender where the router signal is still strong, around 50 to 70 percent signal. Not in the dead zone. If you stick it in the bad room, it repeats bad Wi-Fi and you get bad Wi-Fi twice.
Also check your band. 2.4 GHz reaches farther, 5 GHz is faster but dies faster through walls and floors. Sometimes splitting bands and putting the bedroom devices on 2.4 fixes the issue for free. Kinda boring, but it works more often than people think.
If your house has thick walls or two floors, I would skip the cheapest extender. They tend to be flaky and slow. Spend a bit more or you end up buying twice. Setup is usualy easy, but tuning the location takes a few tries. That part is the annoyng bit.
Yes, extenders can help, but I think people oversell how bad they are and oversell how magical mesh is too.
If your issue is literally 1 or 2 problem spots, an extender is a perfectly normal band-aid. Not elegant, not amazing, but fine. Where I differ a bit from @mikeappsreviewer is that for basic use, the speed hit often does not matter much. If your bedroom goes from unusable to a stable 50 to 100 Mbps, that’s already more than enough for streaming, Zoom, browsing, etc.
What I’d check before buying anything:
- If the back bedroom gets weak Wi-Fi but decent speed sometimes, coverage is the problem.
- If upstairs is bad all the time, check building materials too. Plaster, brick, old insulation, and hvac ducts can murder signal.
- Try moving the router first. Even 5 feet higher or more centered can fix a shocking amount of this stuff. People skip that becuase buying a gadget feels easier.
Also, not every “extender” is the same. Some are junk. A decent one with dual-band and AP mode is way less painful than the bargain-bin specials. @byteguru is right that cheap ones are where a lot of the horror stories come from.
My actual ranking:
- Wired access point if possible
- Mesh if whole-house coverage sucks
- Extender if only one area is bad
- Randomly buying the cheapest repeater and hoping for miracles
One more thing people miss: sometimes the problem is the client device, not the Wi-Fi setup. Older phones/laptops have weaker radios than newer ones. So if one device struggles upstairs and another is fine, that tells you a lot.
So yeah, extenders do work. They’re just not magic, and they’re kinda easy to place wrong. If you want “fix one bad room cheaply,” buy one. If you want “same strong Wi-Fi everywhere with less fiddling,” skip it.
I’m a little less down on extenders than @mikeappsreviewer, but also a bit less optimistic than @byteguru and @espritlibre. They help when the goal is “make this one annoying area usable,” not “make every corner of the house feel like it’s next to the router.”
The part I’d focus on is latency and stability, not just raw speed. A lot of people test download speed and stop there, but weak Wi-Fi often shows up as video calls freezing, smart TVs buffering randomly, or pages hanging before they load. An extender can improve that if it gives the device a more consistent link, even if the headline Mbps number is not amazing.
Where I disagree slightly with the usual advice: mesh is not always automatically worth the extra money. If your problem is one bedroom plus maybe part of the upstairs hall, buying a whole new system can be overkill. On the other hand, if you game a lot, move around the house on calls, or have a bunch of smart home gear, extenders are usually the first thing people outgrow.
A couple things people often miss:
- Interference matters as much as distance. Microwaves, baby monitors, Bluetooth-heavy rooms, and neighbor Wi-Fi can wreck one part of the house.
- Upstairs can be worse because of floor materials, mirrors, pipes, and ductwork, not just “too far away.”
- Some devices are sticky and refuse to switch cleanly, so the extender gets blamed for behavior that is partly the phone or laptop.
Pros for an extender:
- Cheaper than mesh
- Good for one dead zone
- Usually fast to try and easy to return if it flops
Cons:
- Can add delay
- Roaming can still be clunky
- Performance is wildly dependent on house layout
My honest take: if you want a low-cost patch, try an extender. If you want a permanent fix, skip to mesh or a wired access point. Extenders work, but they are a compromise, not a cure.
