I recently got a Garmin Vivoactive 5 and I’d like to connect it to my MacBook to sync data, manage files, and install updates when needed. I’ve seen different recommendations online, but I’m not sure which method is the most reliable and convenient.
Should I just use Garmin’s native software, or are third-party tools better for accessing the watch’s files? I came across Android File Transfer and MacDroid, but I’m not sure if they’re still good options.
I’d appreciate hearing what works best for you!
For syncing, firmware updates, backups, and map management on supported watches, Garmin Express is the obvious place to start. It’s Garmin’s official desktop app and should cover most routine device-management tasks.
Direct file access is a different issue. Garmin watches that use MTP don’t connect properly through macOS on their own, and Google no longer offers Android File Transfer. MacDroid is a popular replacement that can mount the watch so you can browse and move files with Finder-style access. I haven’t used it personally, but it may be worth trying if that’s what you need.
For regular syncing and updates, though, I’d stick with Garmin Express.
The Vivoactive 5 does not pair to a Mac over Bluetooth, so connect it by USB with a data-capable Garmin cable directly into the Mac. If Garmin Express still misses it, check macOS Privacy & Security permissions for removable volumes; MacDroid is only relevant for manual file access, not normal syncing.
Don’t pay for extra file-transfer software just because the watch fails to appear in Finder. The vívoactive 5 uses MTP for file transfer, and music-capable Garmin watches in MTP mode generally do not mount like ordinary external drives on a Mac. Garmin Express can still detect and manage the watch.
The clean setup is:
- Install Garmin Express on the Mac.
- Connect the watch with the included Garmin USB cable, preferably straight into the Mac rather than through a dock or monitor.
- Open Express and choose Add Device.
- Sign in to your Garmin account and let the initial sync finish.
Express handles activity uploads, software updates, Connect IQ content, workouts, and personal music. Garmin’s own instructions specifically use Express for transferring MP3 and M4A files to the vívoactive 5, so I’d push back slightly on treating MacDroid as the normal solution for music or routine management.
If Express cannot find the watch, check whether macOS sees the hardware before reinstalling anything. Hold Option, open the Apple menu, choose System Information, then look under USB. If a Garmin or vendor-specific device appears there, the cable connection is working and the problem is more likely Express or its removable-volume permission. If nothing appears, suspect the cable, charging contacts, adapter, dock, or USB port. Garmin recommends a data-capable cable and a direct connection rather than a hub.
MacDroid only makes sense if you have a specific reason to browse the MTP storage manually. Even then, avoid casually moving or deleting files in Garmin’s system folders. For ordinary activity syncing, you may barely need the Mac after setup because Garmin Connect on your phone can sync data and download watch updates automatically in the background.
Do not unplug the watch when Garmin Express says the transfer is finished if the watch itself is still showing an update screen. The file transfer may be complete while installation continues on the vívoactive 5, and interrupting that stage can create unnecessary recovery work.
It helps to separate “syncing” from “file browsing.” For normal use, Garmin Connect on your phone handles activity data and account syncing. Garmin Express on the Mac handles USB-based setup, software updates, personal music, and other supported content. The watch does not need to appear in Finder for either workflow, so Finder visibility is a poor test of whether the connection works.
There is a small expectation trap here: Garmin Express is not a general-purpose local backup tool. Your synced health and activity information primarily lives in Garmin Connect, rather than as a tidy folder on the Mac that you can restore manually. If local copies matter, export important activities from Garmin Connect separately instead of assuming Express has archived everything.
I agree with @cyberpixel5891 that MacDroid should be treated as an optional tool, not part of the basic setup. Install it only if you have a specific file that must be placed on or retrieved from the MTP storage. Manual access gives you more opportunities to delete, rename, or move something the watch expects to find. For routine ownership, the less annoying setup is phone syncing for daily use and Garmin Express only when the Mac is actually needed.
Watch for the macOS accessory prompt. On some MacBooks, the watch can begin charging while macOS is still waiting for you to approve the USB connection. If you dismiss or miss that prompt, Garmin Express may act as though nothing is attached. Reconnect the watch with the Mac unlocked and choose Allow when asked. The related setting is under Privacy & Security if you need to change how accessories are handled.
Use the same Garmin account in Express that you already use in Garmin Connect on your phone. Creating a second account by accident can make the watch, activities, and Connect IQ items appear to be missing even though the USB connection itself is fine.
For the first connection, I would keep the setup as plain as possible: watch with a reasonable battery level, data-capable cable, direct MacBook port, Garmin Express open, and no hub or monitor in between. Finder visibility does not matter. Once Express detects the vívoactive 5, let it finish syncing and leave the watch attached until the watch returns to its normal screen, especially after an update.
If detection fails, avoid changing several things at once. First reconnect with the Mac unlocked and check for the accessory approval. Then try another port or known data cable. After that, confirm the watch appears in System Information under USB. Only start reinstalling Express if macOS can already see the hardware. That order helps separate a cable or permission problem from an application problem.
I would leave MTP software out of the initial setup. Manual storage access has a narrow use case, and it adds another driver-like layer when you are still trying to establish whether the basic USB connection works. For syncing, updates, and music transfers, Garmin Express is the safer starting point.
Don’t confuse “music in the Music app” with music Garmin Express can actually copy. Express can transfer local MP3 and M4A files, but protected Apple Music subscription downloads will not transfer like purchased or ripped files. That catches a lot of Mac users who think the watch or cable is malfunctioning.
@kerneldev7882zone is right that Garmin Express should be the first stop, but “personal music” has that limitation. If your main goals are activity syncing and updates, connect by USB and ignore Finder completely. If your goal is loading subscription music, use a supported music-provider app on the watch rather than trying to drag files across from the Mac.
I would only bother with MTP software when you can name the exact file you need to access. Installing it merely to make the watch appear as a drive creates more ways to damage the folder structure without improving normal syncing.
Picture two owners. One just wants their runs and sleep data to show up in the app. The other wants to load a playlist onto the watch for phone-free workouts. These are basically different problems, and the thread has been treating them as one setup question.
For the first person, honestly, the Mac barely matters. Garmin Connect on the phone already pulls activities and pushes firmware over Bluetooth. @real_gadget already made this point and I think it deserves more weight than it got. If your goal is data syncing, you can set up the watch, never plug it into the MacBook, and lose nothing. Garmin Express is the answer to a question a lot of Vivoactive 5 owners will never actually ask.
The music person is where the Mac comes back in, and where I’ll push back gently on the cable advice above. Everyone keeps saying plug it straight into the Mac, no dock, data-capable cable. Fine. But the included Garmin cable is USB-A, and most current MacBooks are USB-C only. So you need an adapter, and a cheap charge-only USB-C dongle will make Express act like the watch is broken when it isn’t. That single detail trips people up constantly and it looks identical to a dead cable or a permissions problem. Before you reinstall anything or blame MTP, confirm your adapter actually carries data.
On MacDroid, I’d land close to where the earlier replies did. It solves a narrow thing, browsing the MTP storage by hand, and for the Vivoactive 5 that’s rarely the thing you need. Express already moves MP3 and M4A files across, so the main reason to reach for manual file access is if you’re doing something Garmin didn’t intend. If you do go that route, the risk isn’t the tool, it’s you deleting a folder the watch expects. Treat it as a scalpel, not a default.
So my rule of thumb: phone for daily life, Mac plus Express only when there’s music or a stubborn update, and a manual file tool only if you have a specific file in mind and a reason not to trust the normal path.
