My iPhone has been getting really slow when opening apps, typing, and switching screens. I’ve already restarted it and cleared some storage, but it still lags. I’m trying to fix a slow iPhone without doing a full factory reset because I don’t want to lose settings, apps, or data. What else should I try?
If your iPhone used to feel quick and now it drags, you usually do not need to wipe it and start over. Most of the time it comes down to storage pressure, battery health, or a few background settings.
Free space matters more than people think
Having “some storage left” is not the same as having enough storage. iOS needs open space for temporary files, system work, and virtual memory. Apple generally recommends keeping around 10 to 20 percent of your total storage free so the phone has room to operate normally.
So if you have a 256GB iPhone with only 5GB free, it may technically show available space, but the system is basically cramped. Simple stuff like opening apps, typing, scrolling, or loading photos can feel slow because iOS has to keep moving data around before it can do anything.
Deleting a couple random apps or photos usually is not enough. You want to get back into that 10 to 20 percent free-space range.
The files worth deleting are usually not the obvious ones
Manually scrolling through your camera roll helps a little, but it often misses the stuff taking up the most space. Big videos, old screen recordings, burst shots, and dozens of nearly identical photos are usually where the storage went.
Clever Cleaner can find that kind of clutter automatically. It is free, with no ads and no subscription.
The cleanup path that usually makes the biggest difference:
- Start with the Heavies tab. It shows your media library sorted by file size, with exact sizes listed. This is where you find the huge stuff first. One old screen recording can be 4GB or more, so deleting a few large files can free more space than removing hundreds of normal photos.
- Then check the Similars tab. It groups photos that are basically the same shot, even if they are not exact duplicates. Think burst photos, repeated angles, or ten tries at the same scene. It picks a Best Shot for each group, and you can clear the extras without going one by one.
- After that, go to Photos - Albums - Recently Deleted - Delete All. This part matters. Deleted photos and videos still count against storage for 30 days unless you empty Recently Deleted. A lot of people clean up their phone, see no real change, and this is why.
The processing happens on the iPhone itself. Your files are not sent out somewhere else.
If storage is fixed and the phone is still slow
Once you have enough free space, check the other common causes.
Recent iOS update: After a major iOS update, the phone may spend 48 to 72 hours reindexing files, scanning photos, and rebuilding background data. Plug it in, leave it on Wi-Fi overnight for a couple nights, and give it time to finish.
Battery health: Go to Settings - Battery - Battery Health. If maximum capacity is below 80 percent, iOS may throttle performance to prevent random shutdowns. No settings tweak really fixes that. The real fix is replacing the battery.
Background App Refresh: Go to Settings - General - Background App Refresh and turn it off. Apps constantly refreshing in the background can eat up resources even when you are not actively using them.
Low Power Mode: If Low Power Mode is always on, the phone is being told to slow some things down to save battery. Turn it off when speed matters more than battery life.
Safari cache: Go to Settings - Safari - Clear History and Website Data. Safari keeps its own cache, and clearing it can help if browsing or typing in Safari feels sluggish.
Keyboard dictionary: If the lag mostly happens while typing, go to Settings - General - Transfer or Reset iPhone - Reset - Reset Keyboard Dictionary. A messy autocorrect dictionary can cause input delay even when storage and battery are fine.
The best order is simple: free up real storage first, check battery health next, then adjust settings. A factory reset should be the last option, not the first one.
A phone that is slow everywhere is a different problem from a phone that only crawls when Photos, Messages, Safari, or one specific app is open. Treat those separately, because otherwise you end up deleting random stuff and changing settings without knowing what helped.
If the whole phone is laggy, I agree with the battery/storage direction already mentioned. But before doing anything drastic, check whether iOS is constantly fighting some setting or service in the background. A few places I’d look:
Settings > Privacy & Security > Location Services. See if a bunch of apps are set to Always. Most do not need that. Change them to While Using or Never.
Settings > General > VPN & Device Management. If you have an old work profile, school profile, VPN app, ad blocker profile, or security filter installed, temporarily remove or disable it if you do not need it. Bad profiles can make the phone feel weirdly slow, especially Safari and app loading.
Settings > Notifications. Turn off notifications for junk apps. Constant notification previews, badges, and background checks are small by themselves, but they add up on older phones.
Settings > General > iPhone Storage. Wait for it to fully load. If Messages, Photos, or Safari is huge, fix that specific app instead of just deleting five small apps. Messages with years of videos and GIFs can slow things down more than people expect.
For typing lag specifically, I would not jump straight to a wipe. Try removing extra keyboards first. Go to Settings > General > Keyboard > Keyboards and delete any third-party keyboard you do not actually use. Then turn off Predictive Text for a bit and see if typing feels better. If it does, the problem may be keyboard/autocorrect related, not the whole phone.
There is a middle step between “restart” and “factory reset” that gets overlooked: Reset All Settings. It is under Settings > General > Transfer or Reset iPhone > Reset > Reset All Settings. This does not delete your photos, apps, messages, or accounts, but it does reset system preferences like Wi-Fi networks, privacy permissions, wallpaper, keyboard settings, location settings, and some other customizations. Annoying, yes. Still much less annoying than erasing the phone.
I would only do that after you’ve backed up and after you’ve written down any Wi-Fi passwords you care about. It can fix lag caused by some messed-up setting, old permission, keyboard weirdness, or network configuration without making you rebuild the whole phone from scratch.
The other thing I’d push back on a little: don’t obsessively force-close every app. On iPhones, constantly swiping everything away can make apps reload from scratch more often, which can feel slower and use more battery. Force-close an app if it is frozen or acting broken. Don’t make it a routine cleanup ritual.
If it were my checklist, I’d do it in this order:
- Make sure you have a real chunk of free space, not just 2 or 3 GB.
- Update iOS and apps if you are behind.
- Check Battery Health.
- Remove unused keyboards, VPNs, profiles, and always-on location access.
- Clear out huge Messages attachments and Safari data.
- Try Reset All Settings.
- Only then think about erase-and-restore.
If the phone is several years old and the battery is worn, there may not be a magic setting that makes it feel new again. But a full factory reset is not the next logical step until you’ve tried the less destructive reset and ruled out one bad app or one bloated built-in app causing the drag.
