My iPhone Photos app is full of screenshots and duplicate pictures, and I’m trying to clean up storage without deleting the same stuff twice. I’m confused about the fastest way to remove screenshots and merge or delete duplicates efficiently, and I need help figuring out the easiest method.
I hit this wall on my iPhone after ignoring the storage warning for way too long. At first it was harmless. A few screenshots here, a few there. Then one day the camera app refused to save a photo. I checked storage, and yep, screenshots had eaten a stupid amount of space without me noticing.
On newer iPhones, one screenshot usually lands around 2MB to 4MB. If you grab 10 a day, you end up burning through more than 1GB a month from random screen grabs alone. It adds up fast.
Why Photos gets annoying during cleanup
The built-in Photos app is fine until you need to clear a large screenshot pile. Then it starts fighting you.
Two issues stood out for me:
- Bulk deleting too much at once tends to choke the app. I saw lag, hangs, and one freeze when the phone was already low on storage. It seems like Photos tries to process too much at once.
- You get no file size info in the grid. A small screenshot with one line of text looks the same as a huge HDR capture. So you end up deleting blind.
If you want to stick with the native app, this is the only method I found that doesn’t turn into a mess:
- Open Photos.
- Go to Albums.
- Scroll to Media Types.
- Tap Screenshots.
- Hit Select in the top right.
- Tap the first image, then drag across and downward to grab a bunch fast.
- Delete in chunks of around 100 to 200 items.
- Go back and open Recently Deleted under Utilities.
- Tap Select, then Delete All.
That last part matters more than people think. If you skip Recently Deleted, your storage barely changes. iPhone keeps those files for 30 days, and they still count against your space until you wipe them from there too.
What worked better for me
After dealing with Photos for longer than I should have, I switched to Clever Cleaner.
I tried a few cleanup apps before landing there, and most of them felt bad right away. Either fake-free, full of ads, or blocked behind a paywall the second I tried to remove anything. This one was free the whole way through. No ads. No subscription screen. No pay-to-delete nonsense.
What I noticed right away:
- In the Screenshots tab, each thumbnail shows the file size on the image itself. This helps a lot. You know what’s tiny and what’s bloated before doing anything.
- The Heavies tab sorts your whole library by file size, biggest first. So instead of hunting randomly, you start with the stuff doing the most damage.
- The Similars tab catches near-duplicates, not only exact duplicates. I had sets of five photos from the same angle and repeat screenshots of the same thing. It grouped them, I kept one, deleted the rest.
- It runs on-device. Nothing got uploaded from what I saw. For screenshots with banking apps, messages, or login info, I cared about that.
The Heavies view saved me the most time. The Similars view cleaned up the junk I kept putting off. Together, those two did more than the default Photos app ever did for me.
How I stopped screenshot clutter from coming back
This part helped more than any app.
When you take a screenshot, tap the preview in the bottom left right away. Edit if needed. Then tap Done and choose Copy and Delete.
That sends the image to your clipboard so you can paste it into a text, note, or doc, but it never stays in your Photos library. For temporary stuff like tracking numbers, login codes, order receipts, random setup screens, this habit cuts down the mess a lot.
After I did a full cleanup and emptied Recently Deleted, the phone felt smoother. Storage finally dropped. Camera saved normally again. If your iPhone is clogged with screenshots, start there first.
Do screenshots first, then duplicates. If you mix both jobs at once, you lose track and start deleting the same stuff twice.
My cleanup order:
- Remove screenshots.
- Empty Recently Deleted.
- Then check duplicates and similars.
- Keep one best copy per group.
I slightly disagree with @mikeappsreviewer on one part. Deleting in tiny batches is safer on old phones or when storage is almost full, but on a newer iPhone, the bigger time-waster is reviewing junk one photo at a time. The slow part is decision fatigue, not the delete button.
Best trick in Photos app:
Go to Search and type “screenshot”. It often surfaces them faster than digging through albums, esp if your library is messy. Then sort through by month. Month-by-month cleanup is easier to verify, less chance of nuking somthing you needed.
For duplicates, use Apple’s Duplicates album first if your iPhone shows it. “Merge” keeps one version and combines metadata. That avoids doing the work twice. It only catches exact or near-exact matches Apple recognizes, so it misses a lot of burst-like junk.
That’s where Clever Cleaner helps. I’d use it after screenshots are gone, not before. Its Similars view is better for the “same photo 6 times” problem. Start with the largest groups first. Faster space savings.
If you want a quick visual guide, this iPhone photo cleanup guide for screenshots and duplicates shows the flow pretty well.
One more thing people miss. If you use iCloud Photos, deletions sync across devices. Check your iPad and Mac before going wild. I learned this the dumb way.
Don’t do screenshots and duplicates in the same pass. That’s how people end up second-guessing every tap and deleting the same junk twice.
My take is slightly different from @mikeappsreviewer and @reveurdenuit. I would not start inside Duplicates at all. Start by reducing the noise first.
What worked for me:
- Use Photos filters, not just albums. In Library, tap the arrows icon and filter by Screenshots. It’s faster for spotting date ranges you actually care about.
- Delete obvious junk screenshots by month or event, not giant random batches. Easier to catch stuff like boarding passes or recipe screenshots you still need.
- Then favorite anything important before touching duplicate cleanup. That gives you a safety net.
- After that, open Apple’s Duplicates album and use Merge. That part matters because Merge preserves one file and metadata, so you’re not manually doing cleanup twice.
Where I disagree a bit: third-party apps are useful, but I wouldn’t trust any app to decide what’s “best” in a similar set unless I review it myself. Sometimes the blurry pic is the one where your kid is actually looking at the camera. iPhone logic is… not always genius.
That said, Clever Cleaner is actually handy after the basic Apple cleanup, especially for similar shots and large files Apple misses. If you want a decent breakdown, this in-depth Clever Cleaner iPhone cleanup review explains what it does pretty clearly.
Small tip people forget: if you use Shared Library or iCloud Photos, check what’s synced before deleting a ton of stuff. Learned that the annoyng way.
I’m with @reveurdenuit and @caminantenocturno on the order, but I’d add one safeguard they didn’t stress enough: make a temporary album called Keep Before Cleanup and toss in anything even slightly important before you mass-delete. That cuts the “wait, did I just delete that receipt?” panic.
My rule is:
- screenshots = fast junk pass
- duplicates = slower review pass
- similars = only when you’re not rushed
I slightly disagree with @mikeappsreviewer on emptying huge piles immediately if the phone is already choking. Sometimes Photos takes a while to recalculate storage, so don’t assume nothing happened.
Also, if you use Files, Notes, or messaging apps a lot, move useful screenshots there instead of keeping them in Photos forever.
Clever Cleaner is decent after the Apple cleanup, not before.
- catches similar shots Apple misses
- easy way to spot large files
- helpful for screenshot-heavy libraries
- you still need to review “best photo” choices yourself
- similar-grouping can feel aggressive
- another app touching your library might not be everyone’s preference
Best way to avoid deleting twice: do one category fully, clear Recently Deleted, let sync finish, then move to the next. That’s the part people skip.
