My hard drive suddenly changed to RAW, and now I can’t open it or access important files. Disk Management shows the drive, but Windows says it needs to be formatted first. I’m looking for help with RAW drive recovery without data loss and the safest steps to restore or recover my files before I make it worse.
I’ve seen this before, and no, I would not format it first.
When Windows throws the 'You need to format the disk before you can use it' prompt, it usually means the file system looks broken to Windows. It does not mean your files are gone. A lot of RAW drives still have the data sitting there, intact enough to pull back.
The first thing I’d check is the drive’s behavior.
- If Disk Management sees it in a stable way, and the drive isn’t clicking, grinding, or dropping off at random, I’d try software recovery.
- If it vanishes, reconnects by itself, makes odd sounds, or shows up inconsistently, I’d stop there and send it to a recovery lab. When hardware starts acting weird, DIY turns into a gamble fast.
If this looks like file system damage and not a hardware failure, I’d do it in this order:
- Stop writing anything to the drive.
- Recover the files you care about first.
- Open the recovered files and check them.
- Then deal with the RAW partition.
- Only after all of that, move the data back if you still trust the drive.
For the first pass, I’d use Disk Drill. What stood out to me is it doesn’t depend on one recovery method. If enough file system info survives, it pulls files back with filenames and folders. If the metadata is too far gone, it falls back to signature scanning and looks for known file types across the disk itself.
The steps are straightforward:
- Install Disk Drill somewhere else, not on the damaged drive.
- Pick the RAW disk or RAW partition.
- Click Search for Lost Data. On an external drive, use Universal Scan if it asks. I’d only touch Advanced Camera Recovery for footage from cameras or drones.
- Let the scan finish, even if it feels slow.
- Preview what it finds.
- Recover the files to a different disk.
If you want free tools, the usual pair is TestDisk and PhotoRec.
- TestDisk is the one I’d try if the goal is fixing the partition itself. Sometimes it repairs the partition table or boot sector well enough for the drive to mount again.
- PhotoRec goes the other direction. It ignores the damaged file system and searches by file signatures. I’ve had decent results with it, but it tends to return files without the original names or folder tree, so cleanup afterward is a pain.
One step people skip, and I think it matters, is making an image of the RAW drive before trying repairs. If the disk still reads but feels unstable, a byte-for-byte copy gives you one clean fallback. If a repair attempt goes sideways, you still have something safe to scan instead of pushing the original disk harder.
I would not run repair tools until the important files are already copied out. After recovery is done and checked, then I’d test fixes on the partition. If the drive used NTFS before, CHKDSK sometimes helps, but I wouldn’t run it first because it writes changes to the file system. If CHKDSK doesn’t get anywhere, TestDisk is the next thing I’d try. If both fail, I’d wipe the partition table entry, recreate the partition in Disk Management, do a quick format, and copy the recovered files back.
One SSD note, because this part gets missed a lot. If the RAW volume is on an SSD, I wouldn’t let it sit for weeks. TRIM can clear deleted blocks over time, and once those blocks are gone, recovery gets uglier. RAW status does not always trigger TRIM right away, but earlier is better here. Less use, less delay, better odds.
Yes, RAW disk recovery is possible without losing your files. The key is doing things in the right order.
Do not format the drive first. Windows shows RAW when it fails to read the file system. Your data might still be there. I agree with @mikeappsreviewer on that part.
Where I differ a bit is repairs. I would skip repair attempts on the original drive at first, even if the disk seems stable. Fix tools sometimes change metadata and make file recovery worse.
My order would be:
- Check SMART health with CrystalDiskInfo or Hard Disk Sentinel.
- If health looks bad, clone the drive first with ddrescue or HDDSuperClone.
- Scan the clone, or the original if the drive is healthy, with Disk Drill.
- Save recovered files to another disk.
- After your files are safe, test file system repair or reformat.
A few signs matter:
- RAW + normal sounds + stable connection, software recovery often works.
- RAW + 0 bytes, freezes, slow reads, USB disconnects, stop DIY.
- SSD RAW state needs fast action. Time hurts recovery odds.
If you want to restore the partition structure instead of only copying files out, DMDE is worth a look. It is less beginner-friendly than Disk Drill, but strong for partition and directory reconstruction. For a lot of people, Disk Drill is easier and faster for RAW drive data recovery because previewing files tells you early if recovery is worth it.
This guide helped me compare the process before I touched my own drive:
watch how to recover files from a RAW hard drive
One more thing. If this is an external drive, swap the cable, port, and enclosure first. I’ve seen a “RAW drive” turn out to be a bad USB bridge. Annoying, but fixable.
Yes, RAW drive recovery is absolutely possible, and no, formatting first is not the smart move.
I mostly agree with @mikeappsreviewer and @byteguru, but I’m a little less enthusiastic about trying to “fix” the partition early, even on a drive that seems okay. A RAW volume means Windows can’t parse the filesystem, not that your files magically evaporated. Big difference.
What I’d do before any recovery app or repair command:
- Check the drive in another PC if possible
- For externals, try a different USB cable/enclosure first
- Look at the S.M.A.R.T. data
- If the drive is slow, freezing Explorer, or disconnecting, stop messing with it
One thing people skip is checking whether the partition type or starting sector got mangled. You can inspect that with a partition editor before doing anything destructive. Sometimes the data is still there and the issue is just the partition metadata being borked.
If the drive is readable enough, Disk Drill is a solid choice for RAW hard drive recovery because it lets you preview recoverable files before saving them. That matters. If previews open, your odds are way better than just staring at scan results and hoping. Save everything to another drive, obviously. Do not recover back onto the RAW disk. That part still trips pepole up somehow.
Also, ignore Windows if it offers to “scan and fix” or format. Windows is not your friend in this exact moment.
If you want a plain-English walkthrough, this step by step RAW drive recovery guide with Disk Drill is easier to follow than most text guides.
Short version:
- Don’t format
- Don’t run CHKDSK first
- Verify hardware stability
- Recover files off the drive
- Only then try repairs or reformat
If it’s an SSD, move fast. If it’s making weird noises, stop DIY entirely. That’s the line where recovery software turns into wishful thinking tbh.
RAW recovery is often possible, but I’d add one thing the others only touched on lightly: check whether the volume was encrypted or compressed before it turned RAW. BitLocker, VeraCrypt containers, even some NAS-formatted externals can look “dead” in Windows when the real issue is the wrong layer being read. In that case, repair tools can waste time.
I mostly agree with @byteguru, @reveurdenuit, and @mikeappsreviewer on avoiding format and not rushing into CHKDSK. Where I slightly disagree is with trying partition repair too early just because the disk appears stable. If the files matter, extraction first is safer than restoration.
My practical split:
- If the drive capacity looks correct and scans normally, file recovery has a decent shot.
- If capacity is wrong, filenames turn to gibberish, or the partition suddenly changed size, suspect deeper metadata damage or controller trouble.
Disk Drill is a reasonable first-pass option because it can preview recoverable files, which saves guesswork.
Pros:
- Easy to use
- Good previews
- Handles RAW volumes well in many cases
Cons:
- Deep scans can be slow
- Free recovery limits depend on version/platform
- Not the best choice if you specifically want manual partition-table surgery
One extra tip: check Event Viewer for disk, NTFS, or controller errors right after connecting the drive. That can tell you whether this is file system corruption or an I/O problem. If you see repeated bad block or reset errors, stop stressing the drive and work from an image if possible.
