I accidentally deleted some files from my SSD and I’m thinking about using Recuva to try to recover them. I’ve read that SSDs handle deleted data differently because of TRIM, so I’m worried recovery software could lower my chances or cause problems. I need help figuring out if Recuva is safe for SSD recovery and what I should do first to avoid making things worse.
People ask this all the time, and I never thought the answer was a clean yes or no. If you want the short version, yes, Recuva is safe to run. It is not malware. It is not built to wreck your PC. Still, “safe” means a couple different things here. Safe from viruses, mostly yes. Safe for your privacy and safe for your deleted files, that takes a bit more care.
I’ve been testing recovery apps on old SSDs, flash drives, and one dying laptop drive I should have retired sooner. Recuva still comes up a lot in 2026, so here’s the plain version of what I saw.
About the malware rumors
A lot of the fear traces back to the old CCleaner incident in 2017. Same company lineage, same baggage. Piriform got hit in a supply chain compromise, and the official CCleaner update shipped with malware. Bad story. A ton of people remember it, and I don’t blame them.
Still, that mess is old now. Piriform ended up under Avast, then Gen Digital. Current Recuva installers from the official source are usually clean in normal checks. If you throw the installer at VirusTotal, you might see one weird detection from a smaller engine. I saw that too. In most cases it looks like a heuristic flag because recovery tools poke around low-level disk areas and some scanners hate that.
If you download from the official site, your risk from a virus angle looks low. If you grab it from random software mirrors, you’re asking for trouble.
Privacy is a separate issue
This part gets skipped too often. Recuva itself is not spying in some dramatic movie way, but the company behind it does collect routine device and network info. Things like IP address, device identifiers, operating system details, and rough location data show up in their policy. I read through it after install because I don’t like mystery traffic leaving my machine.
If you care about that, go into Options, then Privacy, and turn off the usage sharing box right away. I do this before I scan anything. Free tools often come with some data collection attached, and this one is no different. One detail people miss, IP logs are kept for a long stretch before they get anonymized. Last I checked, it was 36 months.
The part where people ruin their own recovery
This is the big one. Recuva is usually not what destroys your files. The user does.
Do not install it onto the same drive where your deleted files were sitting.
I’ve seen people lose photos, then download the installer straight onto the same desktop drive, run the install, then save recovered files back to that same drive again. At that point you’re writing new data into the exact space where the old files might still exist. Windows deletes the reference first. The file data often stays there until something overwrites it. Your install, your browser cache, your recovered output, any of it.
The safer move is the portable build. Put it on a USB stick. Run it from there. Then recover files onto another drive, external SSD, second internal drive, anything except the one you’re scanning.
How well it works in real use
This is where I cooled on it.
For easy jobs, Recuva is fine. Deleted something from the Recycle Bin ten minutes ago on a healthy Windows drive, good chance it helps. It’s light, quick, and free. No paywall over your results, which is rarer than it should be.
Once the case gets messy, it starts showing its age.
The app still feels old because, well, it is. The core design hasn’t changed much since the mid-2010s. There were a few updates to keep it alive on newer Windows builds, but it still behaves like an undelete utility first, not a full recovery platform.
On damaged partitions and RAW drives, I’ve had it miss the drive entirely. If Windows says “format this disk before use,” Recuva often stops being useful. On formatted USB tests, success rates were all over the place. In the range I saw and in public tests, it lands around 63 to 67 percent. That sounds passable until you open the files.
And yeah, this happened more than once. Recuva marked a JPG as excellent, restored it, and the image would not open. I also got flattened results with folder structure gone. Thousands of files dumped into one directory, generic filenames, no sorting worth trusting. If your recovery job is small, you live with it. If it’s 10,000 photos from work, it gets ugly fast. typo city.
When I’d stop using it
If the files matter, I wouldn’t spend too long hoping Recuva pulls off a miracle.
Wedding photos. Client footage. Tax records. School work due tomorrow morning. Stuff like that. If the first pass fails, or the drive looks unstable, stop. Repeated scans are not free in a practical sense. A failing drive does not improve because you keep asking nicely.
At that point I'd move to a stronger recovery tool. In my own tests, Disk Drill did better on damaged partitions, RAW volumes, and formatted media. It also handled media file signatures better, especially larger video files and some camera RAW formats where Recuva gave me junk or nothing. If you want to see that difference walked through in real usage, this comparison is worth watching.
One feature I wish more people used is disk imaging. Disk Drill includes byte-to-byte imaging, so you clone the failing drive first and scan the copy. I like this approach because the original hardware gets touched less. If the drive dies halfway through later, you still have the image. Recuva does not give you the same level of protection there.
What I’d do, step by step
- Download only from the official source.
- Pick the portable version if you can.
- Run it from USB, not from the affected drive.
- Turn off usage sharing in the privacy settings.
- Save recovered files somewhere else.
- If results come back corrupt or incomplete, stop and switch tools.
My take
So, is Recuva safe. Yes, in the normal malware sense, I’d say yes if you get it from the official site. For simple deletions on a healthy Windows system, it still makes sense as a first try.
But I would not confuse “safe to install” with “best choice” or “safe for every recovery job.” Those are different things. Recuva works best when the mistake is fresh and the drive is healthy. Once file systems get damaged, partitions go RAW, or the recovered files start coming back broken, it runs out of road pretty fast.
If you use it carefully, it’s a decent first shot. If the data matters, move fast, be picky, and don’t keep hammering the same drive hoping luck changes. I learned this one the hard way, and yeah, it cost me a folder I never got back. That sucked.
Yes, Recuva is safe to run on an SSD in the sense that it does not harm the drive by itself. The bigger issue is whether it will find anything.
On SSDs, TRIM often wipes deleted blocks fast. Sometimes within seconds. Sometimes after idle time. Once TRIM has done its job, Recuva sees filenames or old metadata, but the file data is gone. So the risk is less ‘Recuva will damage the SSD’ and more ‘you waste time while Windows keeps writing to it.’
I differ a bit from @mikeappsreviewer on one point. I would not start with Recuva if the files matter. It is fine for a cheap first try on HDDs. On SSDs, odds drop hard after deletion. You want the best scan early, not the oldest one.
What to do now:
- Stop using the SSD.
- Do not install recovery software onto it.
- If it is your system drive, shut down and connect it to another PC if possble.
- Scan from another drive.
- Recover to a different drive.
If Recuva shows lots of files as recoverable, test a few small ones first. ‘Excellent’ status means less on SSDs than people think. Corrupt recoveries happen a lot.
If the data matters, use Disk Drill first. It handles modern storage better and gives you a stronger shot on deleted files, partitions, and mixed file types. If you want a solid list of data recovery tools worth trying, this page is useful: best data recovery software for SSDs and deleted files
Short version. Safe for the SSD, yes. Safe for your chances of recovery, only if you stop writing to the drive right now. Time matters more than the app here.
Yes, Recuva is safe for an SSD in the hardware-wear sense. A read-only scan is not going to magically ‘use up’ your SSD. That fear gets overstated a lot. What actually hurts your recovery chances is continued writes, not the scan itself.
Where I slightly disagree with @mikeappsreviewer and @sterrenkijker is this: people talk about TRIM like it means recovery is instantly impossible every single time. Often it does kill the chances fast, yes. But not always in the exact same way on every system, firmware version, enclosure, or file deletion scenario. So if the files matter, I would not assume ‘TRIM happened, game over’ without checking. I just also would not waste hours doing five different scans on the same live system drive either.
A couple practical points:
- If Recuva is already on another drive or USB, trying it is fine.
- If you need to install it onto the same SSD where the files were deleted, that is a bad idea.
- If this is your Windows boot SSD, every minute the PC stays on, Windows keeps writing logs, cache, temp junk, etc. That’s the real problem.
Also, Recuva on SSDs is kind of a ‘maybe you get lucky’ tool. On old-school HDD accidental deletions, it’s a decent first poke. On SSDs, I’d rather use something more current if the files are even mildly important. Disk Drill tends to be the better first attempt for SSD data recovery because it handles modern storage cases better and gives you a more serious recovery workflow.
If you want background on the tool itself, this is a decent reference on how Recuva file recovery software works.
Short version:
- Safe for the SSD: yes
- Safe for recovery odds if you keep using the drive: nope
- Worth trying for low-stakes files: sure
- Best choice for important SSD recovery: probably not, tbh
