Need help choosing a simple budgeting app that actually works
I’ve tried a few budgeting apps, but I either get overwhelmed by features or lose track because the setup is too complicated. I’m looking for an easy-to-use budgeting app that helps me track expenses, set savings goals, and stay consistent each month. What apps do you recommend, and what makes them work well for real daily budgeting?
I bounced between a bunch of apps too and kept quitting. What worked for me was going as simple as possible.
If you want dead simple and free:
  1. Spending Tracker (iOS / Android)
    • No accounts. You type stuff in.
    • Make 5 to 8 categories max. Example: Rent, Groceries, Eating out, Transport, Fun, Other, Savings.
    • Each time you pay for something, open the app, hit plus, pick category, done.
    • Once a week, look at the chart to see where most money goes.
    This keeps setup under 10 minutes.
If you want automation but still simple:
2) Simplifi by Quicken
• Connect your bank and cards, it pulls in transactions.
• Turn off extra features you do not care about, like investments.
• Create a “spending plan” for the month.
• Use maybe 8 to 10 categories, not 30. Delete or hide the rest.
• Check the “Left to spend” number once a day. Ignore the rest at first.
It costs a few bucks per month but it solved my “forget to log stuff” problem.
If you like envelopes:
3) Goodbudget
• No bank sync in free version. You enter income and expenses.
• You create “envelopes” for each area and fund them on payday.
• When an envelope hits zero, you stop spending there.
This works if you want strict limits.
For savings goals:
• In Spending Tracker or Goodbudget: make a category or envelope named “Emergency fund” or “Vacation” and treat transfers to savings as an expense.
• In Simplifi: set a “Goal” and schedule a monthly contribution, even if it is 20 bucks.
To stay with it:
  1. Decide your “money time” in advance. Example: 5 minutes each night after brushing teeth.
  2. Use one metric. Either “Did I stay under my total spending limit” or “Did I hit my savings transfer”. Ignore everything else the first month.
  3. Keep the budget stupid simple.
    • One income number.
    • Rent and fixed bills.
    • One “variable spending” bucket for all the rest if categories stress you out.
If you feel overwhelmed during setup:
• Set only three things:
  1. Monthly income after tax.
  2. Total amount you want to save this month.
  3. A single “spendable” amount for everything else.
    Then as you get used to tracking, split that “spendable” into a few categories.
Personal combo that worked for me:
• I use Simplifi for automatic tracking.
• I use one Google Sheet with three lines: Income, Bills, Flexible.
• I move a fixed amount to savings on payday and treat it like a bill.
After that, I only check if Flexible is red or green.
If you want the absolute lowest friction and do not care about automation, start with Spending Tracker for 30 days. If you stick with it, then try Simplifi or Goodbudget.
If all the “real” budgeting apps make you want to uninstall life, you’re not the problem, the apps are.
I like a slightly different angle than @vrijheidsvogel:
1. Try a calendar-based app instead of a “budget system”
A lot of apps force envelopes, categories, rules, whatever. If that’s what’s overwhelming you, look at:
  • Money Calendar / Money Lover / Dollarbird
    Not hyping any specific one, just the type: you see a calendar, tap a day, add what you spent.
    Why it works for non-spreadsheet brains:
    • You literally see “oh, I eat out 5 times a week”
    • You remember transactions better because you connect them to days and events
    • Setup is almost zero: income, a few categories, done
It’s basically a diary with numbers. Less “budget guru,” more “I just need to see wtf is happening.”
2. For savings goals, separate the accounts, not just categories
I slightly disagree with the “treat savings like an expense” only in-app. That’s fine, but if everything sits in one checking account, it’s easy to “accidentally” spend it.
Super simple version:
  • Open a free high-yield savings account at your bank or online
  • Create 1–2 goals only: “Emergency” and maybe “Trip”
  • On payday, move a fixed amount there
  • Don’t even track the tiny details in the app at first, just track the transfer
The visual of “checking = for spending, savings = do not touch” solves a lot without any fancy app features.
3. Use the app only for one question
Instead of exploring all features, decide the only question your app must answer when you open it. For example:
  • “How much have I spent this week vs my weekly cap?”
    Then your flow is just:
    • Add spending
    • Look at one number: “This week total” or “Remaining”
If an app does not let you see that quickly, ditch it.
4. Apps to consider based on your tolerance level
  • Ultra minimal, manual, but not spreadsheet-y
    • Calendar-style app (like Dollarbird-type)
    • Use 5 categories max: Housing, Food, Transport, Fun, Other
  • Slightly more structure but still simple
    • EveryDollar free version
      • No bank sync in free tier, but very guided
      • You make a “plan” at the top of the month, then just log transactions
I’m not a huge fan of EveryDollar’s philosophy stuff, but the app itself is stupid simple if you ignore the fluff.
5. A 2-week “test drive” method so you don’t burn out
Instead of setting up a whole Monthly Master Plan:
Week 1:
  • Pick one app
  • No budget targets yet
  • Just track every expense as you go
Week 2:
  • Look at last week’s total spending
  • Decide: “Next week I want to spend 50–100 bucks less than that”
  • Set only that one goal in the app if possible (weekly limit)
Month 2:
  • Only after you survive a full month tracking, start creating real categories & savings goals
You’re probably not failing at budgeting; you’re just being thrown into “advanced mode” way too early. Start with: track everything, ask one question, use one or two accounts, and ignore 90% of the buttons in the app.
Quick analytical breakdown.
You’ve already got great suggestions from @viaggiatoresolare (calendar vibe, very visual) and @vrijheidsvogel (super simple tracker vs Simplifi / Goodbudget). I’ll come at it from a different angle: instead of hunting for the “perfect” budgeting system, pick the lowest-friction tool that matches your personality and then add just one tiny rule.
1. Decide what kind of brain you have
This matters more than the app:
  1. “Just tell me the number” brain
    You want to open an app and see:
    • “You can still spend: $X today / this week”
      Everything else is noise.
  2. “Where is my money actually going” brain
    You need clarity by category, not perfect automation.
  3. “I hate data entry” brain
    If you have to type things in all day, you will quit.
Once you pick which one you are, the app choice gets easier.
2. Where I slightly disagree with both
  • They are mostly in the “track every transaction” camp. That works, but for a lot of people the habit dies in 10 days.
  • If that is you, then your app should only track variable spending, not every bill and transfer.
So instead of logging all the fixed stuff, you can just subtract it once a month and only track “fun / daily life” money.
3. Simple approach that complements their ideas
Step 1: Separate “boring bills” from “daily money”
You do not need an app for this part, just a quick calculation once a month:
  • Take your take‑home pay
  • Subtract rent, utilities, debt payments, subscriptions and your regular savings transfer
  • Whatever is left is “life money” for the month
Example:
  • Income: 2,800
  • Fixed bills: 1,500
  • Savings: 200
Life money = 1,100 for the month.
Now the only thing your app has to help you control is that 1,100.
Step 2: Use any dead‑simple app as a “life money meter”
Pick an app that lets you:
  • Set a total monthly budget
  • Quickly categorize only a few things
  • See a remaining balance without digging through menus
You do not need 20 categories here. Use 3 to 5 max:
  • Food
  • Transport
  • Fun
  • Misc
  • (Optional) “Oops / unexpected”
Each time you spend from your life money, you log it. You ignore bills, savings transfers, all of that. So logging feels lighter.
This can be done in almost any basic expense tracker or calendar-style app like the ones mentioned, and it fits nicely with a simple budgeting app that actually works rather than overwhelms you.
4. Pros & cons of this stripped-down method
Pros:
  • Much less data entry
  • Easier to stick with daily
  • One number to watch: “life money left”
  • Works with almost any simple budgeting app
Cons:
  • You do not get full granular reports
  • You have to remember your fixed bills math once a month
  • Not ideal if your income or bills change a lot every few weeks
5. How to actually stay with it 30 days
Different emphasis than the others:
  1. Set a daily “allowance” from your life money
    If you have 1,100 life money and 30 days, that is about 36 a day.
    You are not trying to be perfect, just close.
  2. Use one rule
    “If my remaining life money divided by days left is under X, I slow down.”
    That is it. No big plan.
  3. Do a 10-minute weekly review
    • Open the app
    • Check total spent vs what you expected
    • Adjust the next week’s daily allowance if needed
6. Where the other suggestions fit
  • If you find you like manual entry and want more control, what @vrijheidsvogel suggested with Goodbudget and envelopes can be your “next level.”
  • If you discover you remember things by days and events, the calendar style from @viaggiatoresolare will feel natural, and you can keep using the same life‑money logic in a calendar view.
Bottom line: the “right” simple budgeting app is the one that lets you see a single, clear number you care about without making you wrestle with setup or 40 features. Start with only your life money in the app, not your entire financial life, and the whole thing gets a lot less overwhelming.
