Need help finding SD card recovery software for large cards
I accidentally deleted photos and video files from a high-capacity SD card, and now I need reliable SD card recovery software that can handle larger cards without missing data. I’m hoping to recover important files before I use the card again, so I’d really appreciate recommendations that actually work.
I went through this once with a camera card, and the first move matters more than anything else. Stop using the SD card now. Pull it out of your phone or camera and leave it alone. After deletion or formatting, the files are often still there for a while. The card usually marks the space as free, then new data starts stomping over the old stuff.
I skipped the lab route because the price was rough. Home recovery software made more sense, at least for me. If you want the shortest answer, I had the best luck with Disk Drill. I kept coming back to it after other tools gave me half-broken results. It runs on both Mac and Windows, and I did not need to poke around menus for an hour to figure it out.
Where it helped most was camera media. A lot of recovery apps look fine until you throw real files at them, stuff like Canon CR2 or CR3, Sony ARW, Nikon NEF, or big video clips from a GoPro, drone, or mirrorless body. Those files get messy fast. Video is worse. On damaged cards, pieces of one clip often sit in different spots, and some apps pull back fragments you can save but not open.
Disk Drill has an Advanced Camera Recovery mode for this. I tried it on broken footage once and it found clips other programs saw as garbage. You can scan for free and preview what turns up. On Windows, it also recovers up to 100 MB for free, which is enough to test whether it’s finding the right files before you spend anything.
If you want other routes, here’s the simple breakdown I’d use.
  1. R-Photo: I’d pick this if your target is only photos and video on a Windows PC and you want a free option. The layout is clean, previews are easy to check, and it does a better job than I expected for a no-cost tool. It is not for documents, so if you need Word files or PDFs, skip it.
  2. Recuva: Fine for basic recovery on Windows. It is easy to run and free without weird limits. I would only trust it for simpler cases, though. If the card shows up as RAW, the file system is damaged, or the files came from newer cameras, results tend to fall off.
  3. DiskGenius: This one felt built for people who don’t mind cluttered screens and too many options. It is strong when the card is badly corrupted, especially with FAT32, which a lot of SD cards use. The catch is the free version is almost useless for big media files since recovery is capped at 64 KB.
  4. DiskDigger: This is one of the few paths if you are stuck on Android and have no computer nearby. I still think a PC is the better route. The desktop edition recovers files for free, but saving them one by one with a 5-second wait got old fast when I tested it. Kinda maddening tbh.
One thing people skip, and I wouldn’t, if the card starts disconnecting, throws read errors, or freezes your computer, make an image of it first. A byte-for-byte copy gives you something safer to work from. Then you scan the image instead of hammering the failing card over and over. Disk Drill and DiskGenius both handle this.
And yeah, don’t restore files back onto the same SD card. Save everything to your computer or an external drive. Writing data onto the card you’re trying to rescue is how people lose the second chance. Use a card reader if you have one. It usually goes smoother.
Large SD card size is less of the issue. The file system and how the card was used matter more. A 256GB or 1TB SDXC card formatted exFAT needs a tool that reads exFAT well and rebuilds big video files without chopping them up.
I agree with @mikeappsreviewer on one part, stop writing to the card. I disagree a bit on tool order. I would not start with the most feature-heavy scan first if the card still mounts cleanly. Start with a fast scan, check file names and folder structure, then move to deep scan only if needed. Deep scans on huge cards take forever and dump tens of thousands of raw hits, which gets messy fast.
My short list:
  1. Disk Drill
    Best pick if you want one app that handles large SD cards well on Mac or Windows. It does well with exFAT, SDXC cards, and large photo or video sets. Preview is useful before you pay. If your files are camera media, Disk Drill is the safest first install for most people.
  2. PhotoRec
    Free. Ugly. Effective. It ignores the file system and carves files by signature, which helps after format damage. Downside, filenames and folders are often gone. For 4K video recovery, results are mixed but it finds a lot.
  3. UFS Explorer
    More technical. Better if the card has corruption, bad partitions, or weird mount behavior. Not beginner friendly, but solid.
Best process for big cards:
Read the card with a USB 3 card reader.
Copy an image of the card first if reads are slow or glitchy.
Recover to an internal drive or SSD with lots of free space.
Check a sample of the biggest video files before saving evrything.
Also, for a quick visual guide, this quick SD card recovery tips for deleted photos and videos is easier to skim than most forum posts.
Big card by itself usually is not the problem. What matters more is whether the card is SDXC/exFAT, whether it was just deleted vs quick-formatted, and whether the files are giant 4K/5.3K clips that need proper reconstruction.
I mostly agree with @mikeappsreviewer and @vrijheidsvogel, but I’d push one extra point: on large cards, preview quality matters almost as much as scan quality. Some apps “find” thousands of files, then half the videos are zero-byte junk or unplayable. That’s where Disk Drill tends to be worth trying first. It’s one of the better options for large SD card recovery on both Windows and Mac, especially if you need to check recovered photos and video before committing.
If you want a slightly different shortlist:
  • Disk Drill: best all-around choice for large SD cards, deleted photos, and big video files. Easy enough, not too dumbed down.
  • DMDE: underrated if folder structure matters. More manual, less friendly.
  • PhotoRec: very strong as a fallback, but the recovered files can come back lookin like a yard sale with broken names and no folders.
  • R-Studio: excellent, but honestly overkill for some people and not as beginner-friendly.
One tiny disagreement with the usual advice: I would not always jump straight to raw carving first. If the card still mounts fine, try a normal filesystem scan before the “recover every blob on earth” mode. Saves time, and less mess.
Also, save recovered files somewhere else. Not back to the SD card. Seems obvious, yet people still do it somehow.
If you want more opinions, this thread on best SD card recovery software for photos and videos is worth skimming too.
Large card recovery is mostly about patience and file integrity, not just card size. I slightly disagree with the “start fast-scan first no matter what” camp. If the deleted data is mostly huge videos from an action cam or mirrorless camera, a shallow scan can give false confidence because it finds filenames but not playable clips.
My take:
Disk Drill
  • Pros: strong exFAT support, good previewing, easier to sort real files from junk, solid for mixed photo/video recovery.
  • Cons: not the cheapest option, deep scans on very large SD cards can still be slow, and raw results may lose original names in tougher cases.
If the card is healthy and still mounts, Disk Drill is a good first choice because it balances usability with decent reconstruction. If it does not mount properly, I would lean toward DMDE or UFS Explorer before wasting time on simpler tools.
One thing I’d add to what @vrijheidsvogel, @cazadordeestrellas, and @mikeappsreviewer said: check the SMART-like behavior of the reader/card combo in practice. If transfers stall, speed drops to zero, or the card reconnects, switch readers immediately. Bad readers get blamed on software all the time.
Also, if these are important videos, recover a few largest clips first and test playback fully. Thumbnail preview is not enough. A recovered 12 GB file that stops at 43 seconds is not a real win.
