I run a small business and my spreadsheets are becoming a mess. I’m struggling to track expenses, cash flow, and forecasts all in one place, and it’s starting to cause mistakes in my budget. I’d really appreciate suggestions for easy-to-use small business budgeting software that’s affordable, works well for a very small team, and ideally connects to my bank and accounting tools. What are you using and what should I avoid?
Spreadsheets start nice then turn into spaghetti, so you are not the only one there.
Here is what tends to work for small biz budgeting, with tradeoffs.
QuickBooks Online
Best for: You invoice clients, need basic accounting, want forecasting later.
Why it helps:
• Bank feeds pull in transactions daily and auto categorize over time.
• Simple P&L, cash flow, budget vs actual reports.
• Tons of tutorials and bookkeepers know it.
Budget side:
• You set a budget by category, then run “Budget vs Actuals” monthly.
• Cash flow: use the “Statement of Cash Flows” plus the dashboard cash widget.
Rough cost: 30–90 USD per month depending on plan. -
Xero
Best for: You want cleaner interface and better multi currency, less payroll focus.
Why it helps:
• Solid cash flow reports, good for small agencies or online businesses.
• Nice tracking categories, so you see which products or projects eat your budget.
Budget:
• Good budget manager, exports to Excel for tweaks then reimports.
Cost: Usually a bit cheaper or similar to QuickBooks, depends where you are. -
Wave + a budgeting tool
Best for: Super tight budget, low volume, simple needs.
Wave handles basic accounting for free.
Pair it with:
• YNAB (You Need A Budget) or
• EveryDollar or
• Monarch Money
Workflow example:
• Use Wave for income, invoices, and basic reporting.
• Use YNAB for spending decisions and cash flow. It forces you to “give every dollar a job” so you see what money is left for next month, taxes, etc.
Downside: Double entry between systems, so you need discipline. -
Dedicated FP&A or forecasting tools
If your revenue is lumpy or you hire staff, stuff like:
• LivePlan
• Float
• Fathom
Float plugs into QuickBooks / Xero and gives short term cash flow forecasts that are easier to read than standard reports.
LivePlan is more for full forecasts and investor style plans. -
What I would do in your shoes
Simple service business, under say 500k per year:
• QuickBooks Online or Xero.
• Connect bank and credit cards.
• Set up expense categories that match how you think, not the default mess. Example: “Marketing Ads,” “Tools and Software,” “Founders Pay,” “Taxes Holdback,” “Contractors,” “Rent,” “Travel.”
• Build a 12 month budget inside the tool. Start from last 6–12 months of actuals.
• Set one “money meeting” each week.
- Check bank balance.
- Check open invoices and bills.
- Run P&L for month to date vs budget.
- Adjust next month’s budget if it is way off.
- When spreadsheets still help
Keep one master spreadsheet only for higher level planning.
Tabs like:
• Annual revenue targets.
• Hiring plan.
• One simple cash runway sheet.
Then let the software handle daily inputs and reports. You reduce errors and stop copying numbers fifty times.
If you share your type of business and rough monthly revenue, people here can tell you which of these fits best.
You’re definitely not alone with the “spreadsheets turned into a horror movie” problem.
Since @sognonotturno covered the usual suspects like QuickBooks/Xero really well, I’ll throw out a few different angles and tools that might fit better depending on how you actually run things.
1. If you live in your bank feed and want auto‑magic cash flow:
Look at PocketSmith or Tiller Money + a clean Google Sheet.
PocketSmith
- Strength: time‑based cash flow forecasting. You can literally see “if I pay this bill here, what does my balance look like 3 months out.”
- Good if: your pain is “I don’t know if I can afford X in three months” more than “I need proper accounting.”
- Weakness: not true accounting, so you’d still need something else for tax time.
Tiller Money
- Pipes your bank data into Google Sheets or Excel with daily updates.
- You keep the spreadsheet flexibility, but the data entry hell mostly goes away.
- You can build a budget, reports, cash flow tabs, all from templates.
- Downside: you can still make the sheet into spaghetti if you keep tinkering. Ask me how I know.
This approach is great if you like the idea of spreadsheets but hate typing in every stupid transaction.
2. If you want “budget first, accounting second” (and are ok being a bit manual):
I’ll actually disagree slightly with pairing Wave + a personal budgeting tool like YNAB as your core stack long term. It works, but for a real business it can start feeling like duct tape.
A slightly cleaner setup:
- Use YNAB (or MoneyGrit / Simplifi) purely as a cash allocation tool:
- Set categories like “Tax reserve,” “Owner pay,” “Operating expenses,” “Emergency buffer.”
- You decide ahead of time what each incoming dollar is for.
- Keep accounting in something super basic like Wave only for compliance: invoicing, P&L at year end, etc.
So: budgeting brain in YNAB, tax brain in Wave or whatever your accountant likes. This separates “what should I do” from “what happened.”
3. If you hate bookkeeping and want something more automated than QBO/Xero:
Look at Zoho Books or FreshBooks.
- Zoho Books
- Better priced than QuickBooks in a lot of cases.
- Decent budgeting, recurring expenses, and cash flow report.
- Nice if you might eventually use other Zoho tools (CRM, inventory, etc.).
- FreshBooks
- Especially good if you’re service based and care about time tracking + invoicing.
- Has basic expense tracking and reports but the budgeting side is more “manual.”
- Works if you’re mostly trying to avoid losing track of what’s owed and what’s spent.
They’re not as “standard” as QBO/Xero, but they are often simpler and less bloated for a small shop.
4. If what you really need is forecasting not just tracking:
This is where a lot of people underestimate the problem. You don’t just want to know where your money went; you want to know if you’re going to crash the plane.
Instead of only the higher end tools @sognonotturno mentioned, consider:
- Profit Frog
- Built specifically for small businesses doing scenario based forecasting.
- You can play with “what if my revenue drops 20%” or “what if I hire someone.”
- Grid or Causal
- More “spreadsheet but smarter” tools.
- You plug in assumptions and let it build models and charts.
- Overkill if you’re just trying to keep the lights on, but amazing if you want to test different futures without wrecking your core data.
5. One structural change that matters more than the specific tool:
No matter what you pick, if everything is in one place, your life gets easier:
- One primary bank account for operating expenses.
- One tax / reserve account you sweep money to on a schedule.
- One primary software where all transactions land first.
- Optional “planning layer” (spreadsheet / FP&A tool) for forecasts only.
Trying to make one tool do: invoicing, bookkeeping, day to day spending decisions, detailed forecasting and high level strategy is exactly how you end up with 19 tabs and broken formulas at 2am.
Use:
- One tool for recording actuals.
- One tool for deciding what to do next.
Those can be in the same app, but they don’t have to be.
If you share what kind of biz you run (service vs product, online vs local, rough monthly revenue), it’s a lot easier to say “pick X and ignore the rest.” Different setups behave very differently under the same software.
