I turned on Optimize iPhone Storage to save space for my photos, and now I’m wondering if the same setting works the same way on iPad. I’m running low on storage and need help understanding whether iPad can offload full-resolution photos to iCloud like iPhone does, or if there are any differences I should know about.
I fought with this on my own iPhone and iPad for longer than I want to admit, so here’s the plain version.
Optimize iPhone Storage works the same way on iPad. It’s set per device. I had it enabled on my phone, while my other Apple stuff kept full originals because I had more room there.
It does not erase your photos. It also does not ‘move’ them in the old-school drag-and-drop sense. The full-resolution original stays in iCloud Photos, and your phone keeps a smaller local copy. When you open the photo, iOS pulls down the full version again if you need it. If your connection is bad, you’ll notice the delay fast.
The part people run into is iCloud storage. If iCloud is full, optimization sort of stalls out. Your phone needs space in iCloud to upload the originals first. If those originals never finish uploading, iOS has nothing to swap out, so your local storage stays packed. I hit this exact wall once while trying to install an iOS update, and toggling the setting did almost nothing.
On my phone, low storage showed up as lag before anything else. Apps started closing. The camera took ages to open. Typing felt off. iOS wants free space for temp files, updates, indexing, and all the background junk it does quietly. When you get too close to zero, the phone starts acting busted.
What annoyed me was how limited Apple’s built-in cleanup is. It shrinks local copies if iCloud has room, sure. It does not help much with duplicate-ish shots, giant forgotten videos, or the pile of screenshots you stopped needing two weeks ago but never deleted. I had a bunch of near-identical pet photos and ten screen recordings from one bug report. Total mess.
The thing I ended up using was Clever Cleaner. I usually avoid cleaner apps because most of them feel sketchy or naggy. This one felt normal, no ads in my face, no weird paywall halfway through.
The useful part for me was the Heavies view. It sorts media by file size, which Photos still doesn’t show in a way I found useful. I found one random 4K recording eating 4GB by itself. Deleted it, restarted the phone, and things felt less awful right away.
The similar photos section helped too. It grouped those almost-the-same shots and let me keep one without manually comparing every frame like a maniac. Screenshots were easier to clear because I could see what they were costing me file by file. I liked one more detail, the scan runs on-device, so your library isn’t being shipped off somewhere else.
If you’re trying to make room for an iOS update, I’d do it in this order:
- Find your biggest files first. Large videos and screen recordings are usually the fastest win.
- Delete screenshots. Mine pile up like dust.
- Go to Settings > General > iPhone Storage and offload apps you haven’t touched in months.
- Empty Recently Deleted in Photos. If you skip this, the space does not come back yet.
After you clear enough junk, iCloud Photos often starts syncing again, and then Optimize Storage has room to work the way it was supposed to in the first place.
If your phone feels slow and storage is almost maxed, I’d treat free space as the first fix. I did, and yeah, it helped a lot.
Yes. iPad does the same thing.
On iPad, the setting is called Optimize iPad Storage. Same idea as iPhone. Full originals stay in iCloud Photos. Your iPad keeps smaller device copies when space gets tight. Open a photo, and the full version downloads again.
One part I’d add to what @mikeappsreviewer said, it does not always shrink your library fast. iPadOS waits until it feels pressure. So if you flip the setting on today, you might not see a huge drop right away. Apple is annoyingly slow about it.
Check this path on iPad:
Settings > Apps > Photos > Optimize iPad Storage
A few limits matter:
- iCloud Photos must be on.
- You need free iCloud storage for originals.
- It works per device, not across all devices at once.
If your iPad is packed now, photos are only one part of it. iPads often lose more space to downloaded Netflix files, Procreate timelapses, GarageBand stuff, large Messages attachments, and Safari downloads. Look in:
Settings > General > iPad Storage
I slightly disagree with the idea that Photos cleanup should be your first move every time. On iPad, large app data is often the real storage hog. Check the storage graph first so you do’nt waste time.
If your photo library itself is the issue, Clever Cleaner is worth a look for finding huge videos, duplicates, and screenshots faster. This is a decent example of watching Clever Cleaner free up iPhone storage fast.
Short version. Yes, it works on iPad too. Same system. Same catches. Slower than most people expect.
Yep, iPad does it too. Same concept, just labeled Optimize iPad Storage instead of iPhone.
One small thing I’d push back on from @mikeappsreviewer and @byteguru: people sometimes expect the storage number to drop instantly, and Apple just… doesn’t work that fast. iPadOS usually waits until storage pressure is real before it starts being agressive about replacing originals with smaller local versions. So if you just turned it on, don’t panic if nothing huge changes today.
Also, on iPad, photos are often not the main villain. Stuff like downloaded shows, art app files, PDFs, Messages attachments, and giant game data can eat way more space than your photo library. Check Settings > General > iPad Storage before assuming Photos is the whole problem.
If your actual issue is the photo library, then Clever Cleaner is useful for spotting the junk Apple hides badly, especially huge videos, duplicate shots, and screenshot clutter. I’d use that before randomly deleting apps you still need. There’s also a decent Reddit discussion here about whether Clever Cleaner is really a free iPhone cleaner with no ads.
Short version: yes, it works on iPad too. Same system, same iCloud dependency, same annoying delay.
Yep, it works on iPad too, but I’d add one nuance to what @byteguru, @jeff, and @mikeappsreviewer were getting at: optimization is really a storage-pressure feature, not a manual “shrink my library now” button.
So yes, iPad can keep smaller local photo versions and leave originals in iCloud, but if your iPad is already choking, don’t assume Photos is the fastest fix. In my experience, iPad storage disasters are often app-created files, offline media, or message attachments long before Photos becomes the biggest offender.
What I’d check that hasn’t been stressed enough:
- whether your iPad is on stable Wi-Fi and charging overnight
- whether Low Power Mode is limiting background activity
- whether Photos is actually done syncing
- whether “System Data” is the real storage hog, which Optimize Photos will not solve
One place I slightly disagree with the usual advice: turning this on is good, but it’s not always the best emergency move if you need space today. It’s more of a long-term storage management setting.
If your photo library is messy, Clever Cleaner can help sort duplicates, screenshots, and big videos faster than the stock Photos app.
Pros:
- easy to spot large media
- useful for duplicate cleanup
- quicker than manual scrolling
Cons:
- won’t fix iCloud sync issues
- won’t reduce app data or system storage
- still requires you to review before deleting anything
So, yes, iPad supports the same idea. Just don’t expect instant relief if the real problem lives outside Photos.
