I accidentally deleted photos and video files from my SD card while using my Mac, and I haven’t saved anything new to it since then. These files are really important, and I need help figuring out the best way to recover deleted SD card files on Mac before they’re gone for good.
I’ve had to recover SD cards on a Mac a few times, and the route you take depends on what went wrong.
If you deleted files by mistake, your odds are often decent. A quick format is still recoverable in a lot of cases too, since it usually strips the file table instead of erasing the data blocks right away. A full format plus more use of the card is where things start going bad fast. New photos or videos write over old sectors, and once that happens, recovery drops off hard. Hardware failure is a different mess. If the card keeps unmounting, gets hot, shows up inconsistently, or the Mac refuses to read it, software tools often won’t do much.
The biggest screw-up I keep seeing is people using the card after the loss. I did this once with a 32GB card from an old camera and lost half the set for good. Even a small batch of new shots can overwrite older files, especially on smaller cards.
On Mac, I’d start with Disk Drill. I’ve tried a few options over time, including UFS Explorer and R-Studio. Those are solid, but Disk Drill felt easier to work through without losing recovery quality for normal SD card cases. If you want something you can open and use without reading a manual for an hour, it’s a good place to begin.
The steps are simple enough:
- Plug the SD card into your Mac with a card reader
- Launch Disk Drill and pick the SD card from the list
- Run a full scan, not the rushed one
- Wait until the scan finishes, even if it looks done early
- Preview what it found
- Recover the files to a different drive or to your Mac’s internal SSD
One part I liked was the preview handling. It does well with camera file types, including a lot of RAW formats, and it’s better than some lighter recovery apps when video files are fragmented. I usually treat preview as the first reality check. If a photo opens cleanly there, or a video seeks without glitching, the recovered copy has a better shot at being usable.
I also wouldn’t dump everything back in one pass. Pull a small test batch first. Open the images, check the videos, skip through them a bit, make sure nothing is broken. It saves time, and it tells you early whether the scan found good data or a pile of junk.
Stop using the card. Eject it and leave it alone. You already did the most important part by not saving new stuff.
I mostly agree with @mikeappsreviewer, but I’d add one thing first. Make an image of the SD card before you scan it. On Mac, use Disk Utility or Terminal with dd. Work from the image if you’re nervous about the card getting worse. It takes longer, but it gives you one clean source to retry recovery from. That matters if the card starts acting flaky mid-scan.
For deleted photos and videos on macOS, Disk Drill is still a solid pick because it handles exFAT, FAT32, and common camera file types well. If your card is healthy, recovery odds are often decent after accidental deletion. Better than after formatting, and way better than after reuse.
My order would be:
- Create a byte-for-byte image of the SD card.
- Scan the image or the card with Disk Drill.
- Filter by file type and date.
- Recover a few files first to your Mac, not back to the SD card.
- Test the videos before pulling everything.
If video files come back broken, try sorting by original folder structure first, then by file signatures. Cameras often split clips in odd ways, so one scan view may look worse than another. Small detail, but it helps.
If the card disconnects, mounts read-only, or throws I/O errors, skip the DIY loop and move to pro recovery. Repeated rescans on a dying card are a bad idea tbh.
Also worth a read if you want more SD card recovery software options for Mac and SanDisk cards:
best SD card recovery software for SanDisk and Mac users
Stop using the SD card, obviously. That part matters more than people think.
I mostly agree with @mikeappsreviewer and @suenodelbosque, but I’m a little less sold on jumping straight into a bunch of scans if the card is old or kinda flaky. Every extra read pass is still stress on the card. If it mounts fine and looks healthy, sure, use Disk Drill for Mac SD card recovery first since it’s easy to preview photos/videos and it handles the usual SD card file systems well. But if Finder hangs, the card randomly ejects, or macOS throws read errors, don’t keep poking it for hours.
One thing not mentioned enough: check whether the files were deleted while the SD card was connected through Photos, Image Capture, or Finder sync stuff. Sometimes the files are gone from the card but still exist in a local import cache, Photos library, or even a temp folder on the Mac. Search your Mac before going full recovery mode. I’ve seen people “recover” files that were sitting on the laptop the whole tiem.
Also, if these are videos from a camera, file recovery can bring back clips that exist but won’t play cleanly. That doesn’t always mean total failure. VLC can open stuff QuickTime refuses to touch. So test recovered files with more than one app.
If you want more opinions on Mac recovery tools, this thread is worth skimming: best Mac file recovery software advice from Reddit.
Short version: don’t write anything to the card, recover to a different drive, test a few files first, and if the card acts physically weird, stop DIY stuff before you make it worse.
