Which is better for storage, Dropbox or Google Drive?
I’m trying to choose between Dropbox and Google Drive for long‑term file backup and everyday sharing. I use both Windows and Android, and I need something reliable for collaboration, syncing large folders, and keeping my photos safe. If you’ve used both, which one has worked better for speed, storage value, and ease of use, and why?
I’ve been using both for a few years because different teams I work with picked different things and I never fully committed to just one.
Dropbox - my experience
Dropbox for me has always felt a bit more “set it and forget it.” The sync has been really reliable, especially with lots of small files. I do some design work and project folders with tons of assets seem to update faster there than they ever did on Drive. The desktop app also just makes more sense to me… it behaves like a normal folder and I rarely have to think about it. What I don’t love is the price. Their free tier feels tiny now, and the paid plans jumped enough that I remember thinking “okay this better be worth it.” Also their web interface feels kind of dated compared to Google’s.
Google Drive - my experience
Google Drive is almost the opposite for me. I don’t love the sync client as much (it’s gotten better, but I’ve had a few weird moments where files took longer than expected to show up), but the integration with Docs/Sheets/Gmail is honestly the reason I keep using it. Being able to just throw someone a link and edit something together without thinking about versions is hard to beat. That said, I still get annoyed by how Google mixes “real files” and Google Docs files, especially when you download stuff. A coworker of mine refuses to use it because he says it feels messy once you get past a few hundred files. Another friend swears by Drive because of the collaboration and says Dropbox feels “old school” to him.
How I combine them
At some point I got tired of running two sync clients and constantly bouncing between them, plus OneDrive because of a client… that’s when I started using CloudMounter. I wasn’t looking for anything fancy, I just wanted everything in one place. Basically it lets me mount Dropbox and Google Drive like they’re just extra drives on my computer, so I open them from Finder like normal folders instead of opening three different apps.
What I like day-to-day is that I don’t have to mirror everything locally. Some of my archive folders are huge and I don’t want them eating my SSD space, but I still want easy access. I just connect when I need something. Also nice when I just need to quickly grab one file instead of waiting for a whole sync client to wake up. It didn’t change which service I prefer, it just made the whole “I guess I use all of them now” situation less annoying.
If someone forced me to pick only one, I’d probably say Google Drive if you collaborate a lot, Dropbox if you mostly care about file syncing and organization. But honestly most people I know end up using whatever their job or school uses and then adapting around it. Switching is only really worth it if something is actively bothering you.
I’d split it like this for your use case: long term backup, big folders, daily sharing, Windows + Android.
Quick take
Dropbox for sync reliability and big folder handling.
Google Drive for collaboration and price per GB.
Often the best setup is both, with clear roles.
Some points where I see it a bit different from @mikeappsreviewer:
  1. Sync reliability and large folders
    On Windows, recent Google Drive (the new Drive for desktop) is much more stable than it used to be. Large folders with tens of thousands of files still feel smoother on Dropbox, but Drive is no longer a disaster.
    If you have one huge project tree that you rename, move and refactor a lot, Dropbox still feels safer. Fewer “where did this folder go” moments.
    If most of your size is a few big files, like videos, raw photos, VM images, the gap shrinks a lot. Drive handles big binary files fine.
  2. Long term backup vs sync
    Neither is a full backup solution by design. They sync deletions. You delete locally, it deletes in the cloud after a bit.
    For long term safety:
  • Turn on extended version history if you pay for Dropbox.
  • In Drive, use “Don’t delete files from the cloud when removed from this device” where possible, and keep Trash retention in mind.
    I still suggest a separate backup, like an external drive or Backblaze, for anything you never want to lose. Sync is not backup.
  1. Collaboration and Android
    Here Drive is hard to beat.
  • Docs, Sheets, Slides in the browser and on Android.
  • Built in comments, suggestions, version history.
  • Easy sharing through links inside Gmail or chat.
    If your collaborators live in Google Docs, Drive will feel natural.
    Dropbox Paper exists, but on Android and web it lags behind the Google tools for shared editing.
  1. Storage limits and pricing
    For personal use, Google One plans usually give more GB per dollar than Dropbox Plus.
    If you already pay for Google One for Photos or Gmail storage, using Drive as your main archive keeps things simpler.
    Dropbox perks are more about sync quality and some pro features, not raw storage size.
  2. Folder structure and “mental map”
    I agree Drive gets messy at scale, but that is often user behavior, not only the tool.
    If you:
  • Force yourself to have one top level “Work” and “Personal” tree.
  • Use a short naming convention like “YYYY_project_client”.
    Drive becomes manageable even with thousands of items. Search helps, but a sane structure still matters.
    Dropbox feels closer to a normal file system, which helps if you think in folders first.
  1. Windows + Android specifics
  • Dropbox on Windows is clean and light, context menu integration is good.
  • Google Drive integrates better with Chrome and Android sharing menus.
    If you use your phone a lot to scan documents, edit small files, share quick links, Google Drive on Android is more convenient than Dropbox.
  1. What I would do in your shoes
    Given your needs: long term backup, large folders, collaboration, Windows and Android.
I would:
  • Use Dropbox as “project work drive”.
    • Active projects that need reliable sync across Windows machines.
    • Lots of small files, code, design assets, etc.
  • Use Google Drive for collaboration and shared docs.
    • Client folders with Docs, Sheets and uploaded reference files.
    • Anything you expect to edit together in real time.
  • Use Google One storage for general long term archive if price matters.
If you do not want two sync clients eating SSD and bandwidth, this is where CloudMounter helps a lot.
Mount both Dropbox and Google Drive as network drives.
  • Keep only your current “Active” folder synced locally in Dropbox or Drive.
  • Keep old projects online only, accessed through CloudMounter on demand.
    This solves the “big archive, small SSD” problem without you micromanaging selective sync all the time.
Concrete choice if you insist on one only:
  • Pick Dropbox if:
    • You care most about rock solid sync of large structured folders.
    • You have a lot of small files and active project work.
  • Pick Google Drive if:
    • You work with other people in Docs and Sheets all week.
    • You want better Android integration and cheaper big storage.
If you start to lose trust in sync, move that workload to Dropbox.
If cost or collaboration pain hits first, lean toward Drive.
Short version: neither is “better” overall, they’re good at different things, and for what you described I’d deliberately split roles instead of trying to crown a single winner.
A few spots where I see it a bit differently than @mikeappsreviewer and @sognonotturno:
  1. Long‑term “backup” vs “I messed up yesterday”
    They’re right that sync is not backup, but in practice most people use these as “oh crap, I overwrote that file” safeguards.
    If your main concern is multi‑year safety on Windows + Android:
  • Dropbox paid plans with extended history are nicer if you’re constantly iterating on big project trees.
  • Google Drive’s version history is actually great for Docs/Sheets, but weaker for lots of binary files you shuffle daily.
For true long‑term backup of your irreplaceable stuff, I’d still keep a boring external drive or a real backup service in the mix. Relying only on Drive/Dropbox for “forever” is asking to get biten the day you mis‑delete a whole tree and notice 2 months later.
  1. Syncing large folders
    They both mentioned this, but I’d push harder on one point:
  • Tons of small files, nested folders, constant refactors: Dropbox is still ahead in my experience. The client feels more “file system native” and you see fewer random sync quirks.
  • Fewer, very large files (videos, archives, disk images): the practical gap is small. Google Drive has mostly caught up here.
If your “large folders” are like code repos, design assets, libraries of tiny files, I would not trust Drive as my only sync tool. If they are mostly big blobs, you can pick based on price and ecosystem and be fine.
  1. Collaboration
    Here I’m actually more bullish on Google Drive than both of them:
  • Docs/Sheets/Slides collab, comments, suggestions, versioning: this is where Drive is borderline unfair.
  • For Android, Drive + Docs/Sheets apps feel native, and sharing links from your phone is frictionless.
Dropbox Paper never really reached the same level. If collaboration is more than “occasionally share a PDF,” Drive wins by a lot.
  1. Windows + Android reality
    Since you’re on both:
  • Windows: Dropbox is lighter and more predictable as a sync client, but Drive for desktop has improved to the point where it is “good enough” for most non‑power‑users.
  • Android: Drive is just more integrated everywhere. System share menus, document scanning, quick edits, all smoother in practice.
So if your daily life includes sending stuff from your phone, Drive will quietly save you time every day.
  1. Storage and price
    I actually disagree a bit with how gentle they were on Dropbox pricing:
  • For pure GB per dollar, Google One is usually clearly better.
  • If you’re anywhere near the free tier limits, Drive/Google One gives you more breathing room before you feel squeezed.
Dropbox is what I’d pay for if sync quality is literally part of my job. If you just want a big, cheap online attic, Drive wins.
  1. Keeping your SSD from dying
    Where I absolutely co‑sign them is using something like CloudMounter, and I’ll be explicit because it actually solves a problem you mentioned:
  • CloudMounter lets you mount Dropbox and Google Drive as network drives on your machine so you browse them like regular folders without downloading everything.
  • That means your 200 GB “old projects” can live online only, whether they’re on Drive or Dropbox, and you just pull what you need, when you need it.
For your use case, CloudMounter is especially handy since you want large folders and long‑term archives without filling your Windows laptop. It’s also “neutral” so if one day you want to swap Dropbox for Drive or vice versa, you don’t have to redo your whole local sync strategy.
  1. Practical setup I’d actually run in your shoes
Given: Windows + Android, long‑term storage, big folders, and collaboration.
I’d do this:
  • Use Dropbox as:
    • Active projects “workdrive” that lives on your Windows box.
    • Anything with lots of small files, frequent reorganizing, or that absolutely must stay in sync cleanly.
  • Use Google Drive / Google One as:
    • Collaboration & shared stuff with others (Docs, Sheets, shared folders).
    • General archive of large, relatively static files where cost per GB matters.
  • Add CloudMounter on Windows to:
    • Mount both Dropbox and Drive as virtual drives.
    • Keep only a small “Active” folder synced locally.
    • Keep all old/rarely used projects online only and pull files on demand.
If you truly refuse to juggle two:
  • Pick Dropbox if your priority is “don’t screw up my big project tree” and collaboration is mostly sending traditional files.
  • Pick Google Drive if you live in Docs/Sheets, you share from Android a lot, and price/storage matter more than the last 10% of sync polish.
Personally, with your exact mix, I’d accept the mild annoyance of using both, glue them together with CloudMounter so they don’t eat your whole drive, and sleep better at night.
If you zoom out a bit, you’re really choosing between:
  • A “local‑first filesystem with cloud superpowers” vibe (Dropbox)
  • A “cloud‑first collaboration hub that also stores files” vibe (Google Drive)
@stellacadente leaned harder into collaboration, @sognonotturno split roles neatly, and @mikeappsreviewer focused a lot on day‑to‑day feel. I agree with most of that, but I’d frame the decision with a few different angles you might not have considered yet.
1. Think in failure scenarios, not features
Instead of “which is nicer,” ask “what is the worst thing that can go wrong for me here?”
Dropbox worst cases (for your use case):
Pros in a bad day:
  • Sync conflicts are usually obvious and localized. Renames and refactors of huge trees tend to survive.
  • Rollback on lots of small files is manageable, especially with extended history.
Cons in a bad day:
  • If you accidentally remove a big local folder, cloud deletion follows. If you notice late, recovery is tedious and sometimes incomplete.
  • If your active project is on one machine and that machine dies in the middle of sync, your mental picture of “what made it to the cloud” can be misleading.
Google Drive worst cases:
Pros in a bad day:
  • Shared Docs/Sheets are very resilient. It is hard to lose work inside those.
  • Permissions and link sharing mean collaborators usually do not copy sensitive data out as often as with standalone files.
Cons in a bad day:
  • Folder ownership and sharing chains can get tangled. Someone leaves a team, the “owner” account is removed, and suddenly parts of your archive are orphaned or harder to find.
  • Mixed content types (Docs vs binary files) can make bulk exports or migrations painful if you ever want to leave.
If your absolute nightmare is “my carefully curated folder tree corrupts or desyncs,” Dropbox is safer. If your nightmare is “I cannot recover who changed what in this shared spreadsheet from last week,” Drive is safer.
2. How “messy” are your collaborators?
This is where I slightly disagree with the others being relatively tool‑focused.
If your collaborators are:
  • Disorganized, send random attachments, rename things arbitrarily
  • Already deep in Gmail, Android, and random Google accounts
Then Google Drive actually absorbs that chaos better. The UI might feel messy to you, but the collaboration primitives (links, comments, Drive search by “people” and “recently opened”) patch over a lot of human sloppiness.
  • Techy, comfortable with hierarchy, version control, and “do not touch that folder” rules
Then Dropbox as the main project storage plus a simple folder convention can feel cleaner long term.
So for collaboration, it is not just “Drive is better.” It is also “Drive is more forgiving when people behave badly with files.”
3. Large folders: structure vs size
Everyone mentioned “lots of small files → Dropbox.” I’d refine that:
  • If you have deep nesting plus frequent structural changes (renames, moving subtrees, refactoring project layouts), Dropbox is still ahead. Its model is closer to a normal filesystem.
  • If you have shallow but huge folders (say, one massive “Media” folder with thousands of files in a single level), Drive is usually OK, but browsing can feel sluggish and search becomes your main navigation tool.
For your Windows + Android flow, a pattern that works well is:
  • Keep “ActiveProjects” in Dropbox, fully synced to Windows.
  • Keep more monolithic stuff like “VideoExports” or “ClientDeliverables” in Google Drive where size and cost matter more than surgical renames.
4. Where CloudMounter realistically fits
Others already mentioned CloudMounter, but I’d stress when it makes sense and not just “because it exists.”
Good fits for CloudMounter in your case:
  • You have a laptop SSD that is smaller than your total archive.
  • You occasionally need old client folders, but not often enough to justify local sync.
  • You dislike juggling different sync settings and clients.
CloudMounter pros:
  • Lets you mount Dropbox and Google Drive as network volumes, so both feel like normal drives in File Explorer.
  • No need to keep huge archives resident on your SSD. Access them on demand.
  • Makes it less painful to run a “split brain” setup: Dropbox for active projects, Drive for archives and collaboration, while still feeling unified on Windows.
CloudMounter cons:
  • Performance depends on network quality. For heavy work on large files, local sync is still better.
  • It is another layer in the stack. If something is weird, you have to debug: is it Dropbox/Drive, CloudMounter, or Windows networking.
  • Offline work is not its strength. If you spend lots of time without stable internet, you will still want native sync for key folders.
So CloudMounter works best as your “cold storage gateway,” not a blanket replacement for native clients.
5. Long term backup: decide what actually deserves redundancy
I’m slightly harsher than the others here: both Dropbox and Google Drive are poor substitutes for long‑term, multi‑year peace of mind.
Given your use case:
  • Mark ~10 to 20 percent of your data as “absolutely cannot lose.”
  • That subset should live in three places:
    • Local machine (or main working drive)
    • Cloud sync (Dropbox or Drive)
    • Separate backup (external drive or dedicated backup service)
Everything else can live with two copies max (local + cloud or cloud + backup), and archives can even be cloud only if you are comfortable with that risk.
Do not try to make Dropbox or Drive behave like a full backup appliance with manual tricks. Use their built in strengths and let a boring backup handle the “what if something silent goes wrong and I notice months later” scenario.
6. If you had to choose exactly one today
Everyone already gave “it depends” conditions, so I will simplify with your exact stack in mind:
  • Heavy use of Windows and Android
  • Big folders
  • Collaboration and sharing
  • Long‑term backup concerns
If you must pick one:
  • I would lean Google Drive, but only if you accept that you will pair it with a real backup solution and you will discipline your folder structure.
  • I would lean Dropbox if your main pain is “I need my giant project trees to sync flawlessly between one or two Windows machines and I mostly send finished files to others.”
The tie‑breaker is really Android. If you share from your phone every day, Drive quietly wins a lot of small battles.
7. A concrete mix that differs slightly from the others
If you are open to using both but want a sharp line between them:
  1. Dropbox
    • Only “WorkActive” projects, mirrored locally on Windows.
    • No archives, no personal clutter. Treat it like a clean working drive.
  2. Google Drive
    • All shared docs, spreadsheets, notes and “read or comment” client folders.
    • Finished exports and large, mostly static assets where cost per GB is more important.
  3. CloudMounter on Windows
    • Mount both accounts.
    • Do not sync old project folders locally at all. Use CloudMounter to dive into them when needed.
    • Keep your Dropbox sync scope tiny, so sync stays fast and your SSD stays free.
That setup gives you:
  • Dropbox’s reliability exactly where you do complex work with large structured folders.
  • Google Drive’s collaboration and pricing where they matter.
  • CloudMounter as the safety valve so you never feel forced to download your entire history just to keep it reachable.
You are basically splitting by lifecycle: active & complex in Dropbox, collaborative & archival in Drive, and letting CloudMounter bridge both worlds without bloating your main Windows machine.
