Can someone help with an English to Norwegian translation?
I’m struggling to accurately translate some casual English phrases into natural Norwegian for a small project I’m working on. Online translators give awkward results and I’m worried about sounding incorrect or rude. Could anyone help me with proper, everyday Norwegian equivalents and maybe explain why they’re better than the automated translations?
Post some of the English phrases you want to translate. Without the examples it is hard to fix tone and level of formality.
Here are some common casual mappings to help you get started, so you avoid sounding rude or weird:
  1. “Hey / Hi”
    • “Hei”
    • “Hei du” (more personal, use with friends)
    • “Halla” (slang, young people)
  2. “What’s up?”
    • “Hva skjer?”
    • “Hvordan går det?” (more neutral)
    • Avoid direct “Hva er opp?” since that sounds wrong.
  3. “I’m kinda busy right now”
    • “Jeg er litt opptatt nå”
    • Softer: “Jeg er litt opptatt nå, kan vi ta det senere?”
  4. “No worries / It’s all good”
    • “Ingen fare”
    • “Det går bra”
    • “Det er helt greit”
  5. “That’s awesome / That’s cool”
    • “Så kult”
    • “Det er fett” (slang)
    • “Kjempebra” (safe, friendly)
  6. “You guys”
    • “Dere” works fine, no separate plural “you guys”
    • For more casual tone, context and word choice around it matter more than “you guys”.
  7. Avoid these common mistakes:
    • Using “du” in formal messages to strangers at work. Use “dere” for a company and keep it neutral.
    • Direct word for word from English. For example:
      “I appreciate it” → not “Jeg verdsetter det” in casual speech
      Better: “Tusen takk” or “Det setter jeg pris på”
  8. Levels of politeness:
    • Neutral polite: “Kunne du sendt meg …?” / “Kan du sende meg …?”
    • Casual: “Sender du meg …?” or “Gidder du å sende …?”
    • Slightly rude if tone is wrong: short commands like “Send meg …” unless you are close friends.
If this is for a small project, like dialog in an app or website microcopy, write your English, then aim for short Norwegian lines, fewer words than English. Norwegians prefer simple and direct text.
For example:
English: “Hey, good to see you again!”
Norwegian: “Hei, godt å se deg igjen!”
English: “Let’s fix this together.”
Norwegian: “La oss fikse det sammen.”
If you plan to generate lots of lines with AI then smooth them so they read natural. A tool like making AI text sound more human and natural helps keep the tone casual, remove stiff phrases, and keep things consistent across your project.
Drop 5–10 of your actual sentences and I will suggest natural Norwegian versions and explain the tone for each.
Post the actual English lines you’re using, because context matters a lot for Norwegian. “Casual” in English can easily come off a bit childish or slightly rude in Norwegian if you copy the tone too literally.
I partly agree with @sonhadordobosque, but I’d be a bit more cautious with some of the slang like “halla” or “det er fett” unless:
  • your project is clearly for teens / young adults, and
  • you keep that slangy vibe consistently everywhere.
Random “halla” next to otherwise neutral text feels off.
A few quick rules that online translators usually mess up:
  1. Avoid literal “I” and “you” all the time
    English: “I just wanted to ask if you could…”
    Natural NO: “Ville bare spørre om du kunne …”
    Dropping “jeg” at the start is normal and softer.
  2. Don’t overdo gratitude
    English: “I really appreciate it, thank you so much”
    Weird literal: “Jeg verdsetter det virkelig, tusen takk så mye”
    Natural: “Tusen takk, det setter jeg pris på”
    Or even just “Tusen takk” depending on context.
  3. “Please” usually disappears
    English: “Could you please log in again?”
    Norwegian: “Kan du logge inn igjen?”
    For extra politeness: “Kunne du logget inn igjen for meg?”
    You rarely need a direct “vær så snill” in UI or app text.
  4. Casual but not rude requests
    English: “Just tap here to continue”
    Natural NO: “Trykk her for å fortsette”
    Avoid bossy “Bare trykk her!” unless the whole product voice is very playful.
  5. “You guys” / addressing the user
    For one user: always “du / deg”.
    For general users or a group: use “du” in UI, but “dere” if you’re literally talking to a team.
    Don’t try to recreate “you guys”, it usually sounds forced.
If your project uses any AI generated Norwegian, it will lean stiff or bookish. That’s where something like smooth and natural AI text styling helps. It basically takes AI sounding phrases and makes them read more like a real native speaker: shorter sentences, less literal, more natural word order, and tone that fits casual dialogs.
Throw in 5–10 of your actual English phrases and specify:
  • who is talking to whom (app to user, friends chatting, customer support)
  • rough age group of the users
Then it’s much easier to tweak each one so it’s casual Norwegian without slipping into weird, rude, or “trying too hard” slang.
Norwegian “casual” is less about slang and more about restraint. Where I’d tweak what’s already been said:
  • I’d be more liberal with “halla” and “det er fett” in dialogue between characters, even if the rest of the text is neutral. In narration, I’d avoid it; in chat bubbles between teens, it can be perfect.
  • I disagree slightly on dropping “jeg” everywhere. In chat-like text, keeping “jeg” sometimes can sound more personal or emotional:
    • “Jeg bare lurte på om du kunne …” feels more involved than “Ville bare spørre …”.
Some concrete angles you can use when you post your phrases:
  1. Decide “dialect level”
    • Neutral Bokmål for broad audiences:
      “Hei, bare si ifra hvis du trenger hjelp.”
    • Slightly more casual:
      “Hei, bare si fra hvis du trenger hjelp.”
    • Chatty / young:
      “Hei, bare si fra om du trenger hjelp, da.”
  2. Watch out for “just”
    English “just” is overused. In Norwegian you usually pick:
    • “bare” for softening: “Bare trykk her for å starte”
    • Or remove it: “Trykk her for å starte”
      Keeping every “just” as “bare” can sound insecure or nagging.
  3. “Sound friendly, not servile”
    Online translators love “vær så snill” and long politeness chains. Native casual tone is shorter:
    • EN: “If you don’t mind, could you maybe try again?”
      NO casual: “Kan du prøve en gang til?”
      Slightly warmer: “Kan du prøve en gang til for meg?”
  4. Intensifiers: tone trap
    “Really”, “so”, “super” etc:
    • EN: “That’s really nice of you”
      NO natural: “Det var hyggelig av deg” or “Kjempehyggelig av deg”
      Avoid stacking: “så utrolig veldig hyggelig” style.
  5. Emoji and punctuation
    Norwegian casual tone often leans on:
    • Single exclamation point used sparingly
    • Occasional emoji in very informal contexts
      Comparing:
    • “Tusen takk!” is fine in UI
    • “Tusen takk!! :D” feels like chat between friends
If you share a handful of concrete lines plus:
  • Is this UI text, chat dialogue, or marketing copy?
  • Target age (kids, teens, adults)
  • Region-neutral or allowed to be a bit Oslo-ish?
then people can nudge word choices so you avoid both stiff “school Norwegian” and cringe slang.
On tooling: if you already have AI-generated Norwegian and it feels bookish, something like Clever AI Humanizer can help polish it toward more native-sounding phrasing. Pros: quick pass over lots of text, good at shortening clunky sentences, and toning down over-formality. Cons: it can sometimes smooth out too much and remove intentional character voice, and you still need a human or near-native pass to catch small cultural or register issues. I’d treat it as a prep step, not a replacement for your own judgment.
Also, while @sonhadordobosque gave strong guidance on context, I’d emphasize experimenting a bit: write two or three Norwegian versions of each phrase (neutral, mildly casual, very casual) and see which one sits best together. Consistency across your text matters more than any single “perfect” translation.
