I’ve been using the Fabulous app for a while and I’m not sure if it’s really worth the subscription cost anymore. Some features help my routine, but others feel buggy or confusing, and I’m unsure if I’m using it right or missing better alternatives. Can anyone share real experiences, tips, or comparisons with similar habit-building apps so I can decide whether to keep or cancel it?
I’d say treat Fabulous like a paid habit template pack, not a full life system.
Quick breakdown from my use and what others report:
Core question
Ask yourself one thing:
If you stopped paying today, which concrete habits would fall apart next week.
If the answer is “none” or “one small thing”, the subscription does not earn its price. -
What tends to help
• Structured morning and night routines, especially if you like checklists.
• The ritual aspect. Music, short texts, a timer, all in one place.
• If you respond well to streaks and “quests”.
Example:
I used it to lock in:
– Morning water
– 10 minute stretch
– Short planning block
After 2 months I no longer needed the app for those. They felt automatic.
- What feels buggy or confusing
• Journey flows change a lot. You finish one thing, app pushes a different “path”.
• Notifications feel random if you do not prune them hard.
• UI hides important controls under menus.
If you are unsure you use it “right”, that is on their design, not on you.
Quick fix:
Spend 20 minutes and do this:
• Turn off every type of notification.
• Turn on only 1 or 2 alarms tied to real-world anchors. Example, 7am morning routine, 10pm shutdown.
• Delete all rituals that do not map to your actual day. Keep max 3 routines.
- How to test if it is worth it
Do a strict 2 week test before your next renewal:
Week 1, use Fabulous
• Track only 3 behaviors you care about. Example, sleep time, walk, reading.
• Log them daily in a plain notes app or spreadsheet.
• Use Fabulous as you normally do.
Week 2, no Fabulous
• Pause or uninstall it.
• Keep the same 3 behaviors.
• Track them in the same manual log.
Then check:
• Did your completion rate drop a lot in week 2.
• Did your stress go down without the app.
• Did you miss any specific feature like timers or the journey texts.
If your numbers are similar or better in week 2, the app does not earn the fee for you.
Alternatives that cover 80 percent of it cheaper or free
• Apple Reminders or Google Tasks for simple recurring habits.
• Any free habit tracker like Loop (Android) or Streaks trial or Habitify.
• A paper checklist on the fridge.
The key is the routine itself, not the themed journeys. -
When the sub makes sense
• You like narrative style coaching and you open the app multiple times a day.
• You want guided programs for sleep, focus, or anxiety and you actively follow them.
• You treat the price like buying daily prompts and audio sessions. -
When to drop to free or quit
• You tap “skip” or “later” more than you complete stuff.
• You feel nagged or guilty every time it pings you.
• You need YouTube tutorials or Reddit threads to decode simple flows.
At that point it works against you.
If you still feel unsure, set a reminder 3 days before renewal. Until then, strip your setup to one morning routine and one night routine.
If even that feels like friction or you keep ignoring it, let the subscription go and move your two key habits to a simpler app or paper.
I’m in a similar boat, and I’ll be blunt: Fabulous is really good at feeling deep and life‑changing, but the actual utility can be pretty thin once the novelty wears off.
Couple of points that might help you write an honest review and decide if it’s worth it:
Separate “aesthetic” value from “behavior” value
Fabulous is polished: music, animations, the whole “journey” vibe. That does have value if it makes you actually open the app and do stuff.
But for an honest review, ask:- Are you doing more of the habits that actually matter to you now?
- Or are you mostly tapping through pretty screens, skipping half the rituals?
Confusing / buggy feeling is a legit downside
You mentioned not being sure if you’re “using it right.” That’s not you being dumb, that’s a UX problem.
In a review, I’d call out:- Constant shifting of “journeys” and paths
- Overlapping routines that feel redundant
- Notifications that feel spammy or off‑timing
If using an app to “simplify your life” makes you feel slightly lost or guilty, that’s relevant feedback.
Cost vs what you actually use
Forget what the app could do. Look at what you really touch weekly:- Is it basically a glorified checklist and timer?
- Are you still following any of the full programs, or do you skip the narrative stuff?
If you’re mostly using 10% of the features, it’s fair to mention that the subscription feels overpriced for that slice.
You’re probably not “using it wrong”
I slightly disagree with the vibe a lot of users get that they need to “optimize” their setup perfectly. If a habit app requires strategy guides and pruning sessions to feel sane, that’s part of the honest criticism.
A good tool should feel almost boringly obvious to use. Fabulous sometimes feels like it wants to be your therapist, coach, and RPG all in one, and that’s… a lot. -
Emotional side
Something people quiet‑quit apps over but rarely write in reviews:- Do you feel low‑key ashamed when you open it and see broken streaks?
- Do the constant prompts feel supportive or like nagging?
If it’s emotionally draining or guilt‑inducing, that alone can make it not worth a recurring fee, even if some routines are helpful.
Compared to what else you could do
Without repeating @caminantenocturno, I’ll just add: the gap between Fabulous and a simple habit tracker or reminders app is often psychological, not functional.
You pay for the coaching tone, stories, and vibe. If that no longer sparks you to act, you’re basically paying for theme music.
If you’re writing a review, you can sum it up like:
- What it genuinely helped you build at first
- Where it started to feel bloated, confusing, or naggy
- How much of the subscription value you actually tap into today
- Whether that ongoing cost makes sense for the small number of routines that still benefit you
And for your own decision: if canceling it makes you feel relief more than panic, that’s your answer, honestly.
Pros & cons style, since you’re trying to write an honest Fabulous app review and decide if it’s worth keeping.
Pros of Fabulous app (from a practical user angle)
- Helps you start routines: That “ritual” framing and narration can genuinely reduce friction for the first few weeks.
- Built‑in structure: If you struggle to design your own habits, the pre‑made programs give you a ready‑made roadmap.
- Sensory engagement: Sounds, visuals, and journeys can make mundane stuff (water, stretching, journaling) feel less boring.
- All‑in‑one feel: Habits, journaling, routines, focus sessions, etc., all live in one place, which can be nice if you hate juggling apps.
Cons of Fabulous app
- Overly scripted experience: Where I slightly disagree with @caminantenocturno is that for some people, the “story” can actually become a barrier. If you just want “Do X at 8 am,” the long intros and journeys start to feel like cutscenes you cannot skip.
- Poor scalability: It works great when you have 3 or 4 habits. Once you layer multiple journeys and routines, it becomes noisy, harder to track what truly matters.
- Low transparency on progress: It is not very clear why you are doing certain steps at certain times, and the analytics are pretty shallow compared to simpler trackers. This can make it feel like you are just obeying the app rather than learning how habits work.
- Subscription vs actual usage: For many people, Fabulous ends up being a glorified routine starter kit, not a long‑term operating system for life. Paying a recurring fee for something you only lean on in “reset” periods might not feel right.
How to decide if your review should lean positive or negative
Ask yourself four blunt questions and answer them in your review:
Net behavior change:
Compared to before Fabulous, what concrete habits exist in your life now? Waking earlier, drinking more water, consistent exercise, reading, etc. List the 2 or 3 that actually stuck. That is your strongest “pro” section. -
Sustainability without the app:
If your subscription ended today, which habits would you still do because they are now “just what you do”?- If most routines feel internalized, you can say something like: “Great starter, less necessary over time.”
- If everything collapses without the prompts, then the app is functioning as a crutch that you are renting. That is worth calling out.
Cognitive and emotional load:
Where @caminantenocturno focused on shame and nagging, I would zoom in on “mental bandwidth.”- Do you feel you need to manage the app: turning off journeys, pruning routines, fiddling with reminders?
- Or does it quietly slot into your day?
If the tool requires regular maintenance, note that as a con: “A habit app that occasionally feels like another job.”
Opportunity cost:
Forget theoretical value. Look at your actual weekly pattern:- Time spent inside Fabulous vs time actually doing habits.
- Money per active feature. For example, “I’m mostly paying for a morning checklist and a focus timer.”
In your review, you can phrase this like: “Good value if you actively follow the structured journeys. Feels expensive if you mostly use it as a checklist and reminder app.”
How to structure a short, honest review
You could outline it roughly like this:
What it did well for you at first:
“Helped me set up a consistent morning routine and start drinking water regularly. The guided journeys were motivating in the first month.” -
Where friction appeared:
“As I added more journeys, things started overlapping and I felt unsure which path to follow. The interface sometimes felt cluttered, and I spent more time arranging routines than actually doing them.” -
Value vs subscription cost:
“At this point, I mostly use Fabulous as a basic habit checklist with pretty visuals. For that narrow slice of functionality, the subscription feels high compared to simpler habit trackers or free reminder apps.” -
Who it is good for / not good for:
- Good for: People who like narrative, gentle coaching, and a ‘gamified’ vibe, especially in the first 1 to 3 months of building routines.
- Less good for: People who prefer quick, minimal prompts, hate long explanations, or already know exactly which habits they want and just need a lightweight tracker.
Where I somewhat disagree with others
Compared to @caminantenocturno, I think Fabulous can still be worth the subscription if you treat it as a seasonal tool. For example, paying for a year with the explicit intention of using it during “reset periods” like January or after a stressful life change can make sense. You are basically paying for a structured boot camp, not a permanent lifestyle manager.
If, on the other hand, you open the app with a tiny sense of dread, feel lectured by the content, or find yourself constantly swiping past screens just to tick boxes, that is a sign to both:
- Mention in your review that it becomes overbearing over time.
- Cancel and test whether a simple habit app or calendar reminders are enough.
That mix of concrete outcomes, friction points, and how often you actually rely on Fabulous is what will make your review feel honest instead of just “I liked it / I didn’t.”
