How can I recover emptied Trash on a Mac without a backup?
I accidentally emptied the Trash on my Mac and realized important files were still in it. I do not have a Time Machine or iCloud backup, and I really need these documents back for work. I am looking for safe ways to recover permanently deleted files on macOS without causing more data loss.
I did this on a MacBook Air and my stomach dropped for a sec. I emptied Trash, then remembered a folder in there had work files and a pile of photos. So yeah, I went through the whole mess already.
The main thing I learned, emptied Trash does not always mean the files vanished on the spot. On macOS, the system often removes the pointers first and marks the space as free. The file data might still sit there until new data lands on top of it. So the clock starts right away.
The bad part is the SSD. Most newer Macs use SSD storage, and TRIM runs in the background. TRIM tells the drive to wipe deleted blocks. Sometimes it kicks in fast. Sometimes there is a window. That is why I stopped using the Mac almost immediatly after I noticed what happened.
I ended up trying Disk Drill. For me, it was the one that went the smoothest on APFS, and it did not fight me on Apple Silicon access the way a couple other apps did. I am not saying it fixes every case. In mine, it got most of the important stuff back.
Here is the exact setup I used.
  1. I stopped normal use of the Mac right away. No browsing, no downloads, no random app installs.
  2. I plugged in an external USB SSD. I did not want recovered files writing onto the same internal drive I was trying to recover from.
  3. I downloaded Disk Drill and installed it on the external SSD, not on the internal Mac drive.
  4. When I launched it, I gave it Full Disk Access.
  5. The path was, System Settings → Privacy & Security → Full Disk Access.
  6. It showed my internal SSD in the list. I picked it and started “Search for lost data.”
  7. The scan took about an hour on my MacBook Air. After it finished, I opened “Review found items.”
  8. I filtered the results down to documents and photos first. Without filters, the list was huge and kind of a mess.
  9. I previewed files before restoring them. In my case, if the preview opened cleanly, recovery usually worked fine too.
  10. After checking the files, I hit Recover.
  11. I saved everything to the external SSD.
End result, I got back almost all of my documents and most of the photos, with original names still there. Some junk files, temp stuff, cache leftovers, those were broken. I did not care. The files I needed survived.
If you had Time Machine running before you emptied Trash, I would start there first. It is safer, faster, and less messy than scanning a drive.
  1. Open Time Machine from the menu bar or through Spotlight.
  2. Go to the folder where the deleted files used to live.
  3. Move back to a date from before you emptied Trash.
  4. Select the files and press Restore.
That puts them back in the original folder with the names intact, which is way nicer than sorting through recovery output.
Also check the places people forget.
  1. iCloud Drive
  2. Recently Deleted in Photos
  3. Recently Deleted in Notes
  4. Dropbox deleted files
  5. Google Drive trash and version history
  6. External drives with older copies
One more thing. If the deleted stuff came from an SD card, camera card, or drone card, I would look at the original card too. Recovery from the card is often easier, as long as you did not keep shooting on it.
I would avoid cleanup tools right now. No Mac cleaner apps, no optimizer junk, no system tidy-up passes. Do recovery first. Mess with cleanup later.
If software turns up nothing and the files are critical for work or legal reasons, then a recovery lab is the last step. For the usual accidental Trash-emptying case though, software is where I would start, and fast.
Stop writing to the internal drive first. That matters more than anything else.
A small disagreement with @mikeappsreviewer, on newer Macs with SSDs, waiting too long often kills your chances fast. TRIM is brutal. So your best move is to shut the Mac down, then work from external media if possible.
What I would do:
  1. Check app-level recovery first.
    If the files were docs, look inside the app you used.
    Pages, Word, Excel, Photoshop, Preview, some of them keep temp or auto-save copies.
    For Office, look in AutoRecovery folders.
    For iWork, open the app and check Recents.
    This takes 5 minutes and sometimes saves your butt.
  2. Check cloud sync history, even if you think you had no backup.
    A lot of people say ‘no backup’ but had Dropbox, OneDrive, Google Drive, Adobe Cloud, or Box syncing in the background.
    Those services often keep deleted files for 30 days or more.
    Version history helps too.
  3. Use another Mac, or boot from external storage.
    Do not install recovery tools onto the same internal SSD if you can avoid it.
    If you need software recovery, Disk Drill is one of the safer Mac options and it handles APFS decently. Save recovered files somewhere else, not back to your Mac’s main drive.
  4. If FileVault was off on an older Intel Mac or the files came from an external HDD, your odds are better.
    If FileVault was on, or it was an internal SSD with TRIM, odds drop a lot. Harsh but true.
  5. If the docs are worth money, skip DIY after one scan.
    A recovery lab costs a lot, but repeated scans and continued Mac use make things worse.
Also, this quick guide is decent for visual steps:
Mac deleted file recovery steps after emptying Trash
If you want, post your Mac model, macOS version, and file types. The next steps depend on thsoe details.
First thing, do one thing neither @mikeappsreviewer nor @voyageurdubois really stressed enough: check whether the files were ever actually stored locally in the first place.
If those “documents” came from Mail attachments, Slack downloads, Pages temp files, or something you opened from a cloud app, there may be another copy sitting in:
  • Mail Downloads
  • Downloads stack/folder
  • app temp folders
  • the original email/thread/chat
  • “Open Recent” inside the app
People panic and go straight to recovery scans when the file is still lurking somewhere dumb. I’ve seen that happen more than once.
Also, slight pushback on the “shut it down instantly no matter what” advice. That’s usually smart, yeah, but if your Mac is already on and you know the files might exist in an app’s AutoRecovery or cloud trash, I’d check those before rebooting around and changing states. Just do it fast and don’t start normal use.
Another thing worth trying on macOS:
  • Spotlight search the exact filename
  • search by file extension like .docx, .pdf, .xlsx
  • check Finder Recents
  • check /Users/yourname/Library/Containers/
  • check /Users/yourname/Library/Autosave Information/
For Word specifically, AutoRecovery can save your butt. For Preview and Pages too, sometimes.
If none of that hits, then yeah, Disk Drill is a reasonable Mac option for emptied Trash recovery, especially on APFS. Just don’t recover back to the same drive. That part people mess up allll the time.
And if you want a simple walkthrough, this video is pretty watchable:
Mac data recovery software comparison and recovery steps
If it’s an internal SSD + TRIM, be realistic. Recovery may be partial or zero. Annoying, but true.
One angle not covered enough by @voyageurdubois, @andarilhonoturno, and @mikeappsreviewer is metadata recovery, not just file recovery.
If the actual files are gone, you may still recover the work faster by rebuilding from traces:
  • open Recent Items from the Apple menu
  • check Office recent documents lists
  • inspect Quick Look cache thumbnails
  • search mailboxes for the original attachments
  • check printer/scanner app history if those docs were exported or scanned
  • look in browser download history for the source URLs
I slightly disagree with the blanket “power off immediately” advice. On SSD Macs, yes, minimize writes. But if the documents were from Word, Pages, Slack, Mail, or Adobe, a fast check of in-app recents and cloud/web trash can beat a shutdown.
If you do need recovery software, Disk Drill is a reasonable option on Mac.
Pros:
  • good APFS support
  • easy preview before recovery
  • simple interface
  • can recover to external storage
Cons:
  • SSD TRIM can still make results poor
  • scan results can be noisy
  • not cheap if you need full recovery
  • no software can guarantee recovery from an emptied Trash
One more practical thing: if you use FileVault and the Mac has been heavily used since deletion, set expectations low. In that case, stop DIY quickly and decide whether the files justify a lab.
