I’ve started noticing new AI-style results and suggestions in various Google services (search, Gmail, maybe even Chrome), and they’re changing how I normally use them. I’m worried about privacy, unwanted auto-generated content, and losing the classic layout I’m used to. I’ve tried digging through settings but I’m not sure what actually disables these AI options versus what just hides them temporarily. Can someone explain, step by step, how to fully turn off or minimize AI features across Google Search, Gmail, Chrome, and any account-level Google AI settings?
Short version. You cannot fully kill all AI in Google products. You can only turn off pieces in each product, and avoid some features.
Here is what you can do today.
- Web and App Activity and personalization
This controls how much data feeds those AI features.
• Go to https://myaccount.google.com/activitycontrols
• Turn off
- Web & App Activity
- Include Chrome history
- Personalized ads: https://adssettings.google.com
• Also on https://myaccount.google.com/privacycheckup disable ad personalization and “Help improve” stuff.
This reduces training on your data, but does not stop all AI behavior.
- Google Search AI features
You likely see AI Overviews, “Things to know”, auto summaries, etc.
On desktop Search:
• Go to https://myactivity.google.com/product/search
• Turn off “Search customization” and “Search history” if you do not need it.
• In results page, look for “More” or “Hide AI overview” if Google shows that option. It shows only in some regions and accounts.
• Use “private search” alternatives for sensitive stuff. Example: DuckDuckGo, Startpage.
No single global “off switch” for AI Overviews right now.
- Chrome
Chrome experiments and suggestions feed into AI style behavior.
• In Chrome, open: chrome://settings/syncSetup
- Turn off syncing stuff you do not want used.
• Go to chrome://settings/privacy - Turn off “Make searches and browsing better”
- Turn off “Help improve Chrome”
- Turn off page prediction / preloading.
• Go to chrome://flags and search for things like “AI”, “side panel search”, “Search Companion”. Set to Disabled. These flags change a lot, so you need to recheck after big updates.
• Avoid logging into Chrome with your Google account if you do not want browser data tied to your profile.
- Gmail
Smart Reply and Smart Compose are AI driven.
In Gmail web:
• Click gear icon > See all settings
- General tab
- Smart Compose: off
- Smart Compose personalisation: off
- Smart Reply: off
- Nudges: off
- “Smart features and personalisation” section: choose the option that disables smart features in Gmail, Chat, Meet.
Turn off “Smart features and personalisation in other Google products” too if you see it.
- Google Docs, Sheets, Slides
The “Help me write” stuff and smart chips are partly AI.
• Open one of them > Settings > Manage “Smart features” and “Personalization”. Turn off if present.
• Watch for menu items called “Help me write”, “Help me organize”. Avoid enabling experiments like “Labs”.
- Google Assistant and Gemini
Assistant, Gemini and Voice input feed a lot of AI.
• Go to https://myactivity.google.com/assistant and delete old assistant history. Turn off saving voice/audio activity.
• In the Google app on phone
- Tap profile picture > Settings > “Search, Assistant & Voice”
- Turn off personal results.
- Turn off “Hey Google” if you do not want mic triggers.
• If your account has Gemini in Search, look for “AI features” or “Labs” toggles in the Google app and disable them.
- Android specific stuff
On Android, Google pushes extra AI into system features.
• Settings > Google > Personalization
- Turn off “Personal results” and similar toggles.
• Settings > Google > Ads - Turn off “Ads personalization” or reset ad ID.
• Gboard - Settings > Text correction
- Turn off “Show suggestion strip”, “Personalized suggestions”, “Improve voice and typing”.
- Turn off “Share snippets” or similar data sharing options.
- Data deletion and training
If you worry about training on past data.
• Visit https://myactivity.google.com
- Delete Search, Location, Voice, YouTube history.
• Set auto delete to 3 months for all categories.
• Use guest mode or different browsers for tasks where you do not want data linked.
- General habits to reduce AI effects
These are more “operational” than UI toggles.
• Use logged out search for normal queries.
• Use a different default browser if Chrome keeps showing AI stuff.
• Use extensions that hide AI blocks in search results. For example, uBlock Origin with custom rules to remove AI boxes.
• Do not click the “Try AI” or “Labs” buttons when they appear in products.
Important part. Google does not provide a global “No AI anywhere” switch. Every product exposes only partial control. For strict privacy, you need a mix of:
• Turning off every “smart” and “personalized” toggle you see
• Deleting history
• Reducing account linkage
• Using non Google tools for sensitive or critical workflows
It is annoying, and you have to recheck settings sometimes after new features roll out, but this gets you close to “minimum AI exposure” in Google products right now.
You’re basically trying to do something Google really doesn’t want you to do: use their stuff without feeding or seeing their AI. You’ve already seen from @himmelsjager’s post that there’s no global “nuclear off” switch, and I agree with that part. Where I’d push a bit further is: if you truly want minimal AI, the answer is less “tune Google” and more “contain Google.”
I’ll skip repeating their step‑by‑step toggles and focus on different angles:
1. Stop thinking in terms of “turn off AI” and start thinking “sandbox Google”
Google is baking AI into core behaviors. That means:
- You can’t fully trust any new UI control labeled “off” to stop all AI processing.
- The real control you still have is:
- What identity you use
- Where you’re logged in
- What data ever reaches Google in the first place
So the strategy is more like:
Use Google where you must, in a tightly fenced area, and use non‑Google where you actually care.
2. Split your life into two accounts: “junk” and “real”
This helps more than hunting 20 different toggles.
A. “Junk” Google account
Use this for:
- YouTube
- Random searches when you do not care about privacy
- Testing new AI junk if you’re curious
This account is the “fine, train your models, whatever” identity. Do not connect it to your phone number, main email, or real name if you can avoid it.
B. “Real” Google account
Use this only for:
- Stuff you absolutely must keep in Google world: Drive, Calendar, maybe Gmail if you are stuck
Rules for this account:
- Do not stay logged in while general web browsing
- Do not use it in Chrome sync
- Use it in a separate browser profile or a different browser entirely
This identity separation matters more than flipping yet another “smart thing off” switch.
3. Use browser-level blocking so you don’t depend on Google’s knobs
Instead of trusting Google’s “hide AI” buttons:
- Use uBlock Origin or a similar blocker
- Add cosmetic filters that literally remove AI panels in Search and Gemini blocks
Example idea (rough, not exact CSS):
- Hide containers that match classes like
ai-overview,sg-result, “Generative AI” labels
That way, even if Google re-enables something, you just never see it. Is the AI still technically running on their servers? Yes. But your practical experience is “old‑school Google-ish search page.”
Also consider:
- Use a different default browser (Firefox, Brave, etc.) for general searching
- Keep Chrome only for the bare minimum of stuff that truly needs Google integration
I disagree slightly with relying heavily on chrome://flags. Those keep changing, can break, and are not privacy controls. Treat flags as “bonus tweaks,” not your core defense.
4. Replace instead of fight in a few key places
If you are serious about privacy and anti‑AI behavior, you want less Google in your stack:
Search
- Use DuckDuckGo, Startpage, Brave Search as default
- Keep Google only as a “secondary engine” for specific queries, preferably logged out or in a throwaway account
- If Gmail’s AI creep really bothers you, consider:
- Fastmail, Proton Mail, Tutanota, etc.
- Even if you keep Gmail:
- Route only low‑sensitivity mail there
- Use a custom domain that you can move elsewhere later
Browser
- Let Chrome be your “Google island” browser for stuff like Docs and Meet
- Use a different browser as your everything‑else browser, not signed in to Google at all
This isolation is more effective long term than fighting each small AI widget.
5. Local-only tools to keep content out of Google entirely
If you do not want your text feeding AI:
- Write email drafts in a local editor first (Notepad, VS Code, Obsidian, whatever)
- Only paste the final version into Gmail, with Smart features off like @himmelsjager described
- For docs, write locally and only upload exports when needed
Same for notes, brainstorming, journaling, etc. Keep that out of Drive and Docs if you are paranoid about model training.
6. Network-level and OS-level tricks
If you want to go a bit further:
- Use DNS‑based blocking (Pi‑hole, NextDNS, AdGuard DNS) to block:
- Some of Google’s tracking and telemetry domains
- Extra AI‑related experiment hosts if they become known
- On Android:
- Consider using a de-Googled ROM (GrapheneOS, LineageOS, etc.) on a secondary device if you are really all‑in on this path
This is more hard‑core, but that is the kind of thing you need if “no AI anywhere” is your actual goal.
7. Accept that “completely off” is not realistic with Google
Harsh version: if you use a free ad‑funded platform in 2026, you are living in someone’s ML training dataset. There is no magic wording in a setting panel that reverses the business model.
So your realistic options look like:
Minimize AI impact on your experience
- Hide panels, disable smart stuff, kill history, split accounts
Minimize the data they can train on
- Use isolation, alternative tools, local apps
Exit the ecosystem gradually
- Move the most sensitive / important pieces of your life off Google first
- Leave the low‑importance stuff (YouTube, throwaway searches) for last
If your goal is “I never want to see the AI stuff again,” browser extensions, alternative search, and separate accounts do more work than yet another toggle in a Google settings page.
If your goal is “I don’t want my life feeding Google’s models,” then the honest answer is: use Google less, and fence it in hard where you still have to use it.
Short version: you are not going to win a “no AI at all inside Google” fight, so shift to “AI containment” and “AI visibility control.” @viaggiatoresolare and @himmelsjager already nailed the knobs and switches. I will focus on what happens around those knobs.
1. Treat Google as untrusted infrastructure, not a “home base”
Both previous replies work from the idea: “tune Google so it behaves.” I think that is backwards.
Practical mindset:
- Assume everything routed through Google can be logged or used for models, regardless of toggles.
- Use your Google account like you would use a work VPN: for specific tasks only, then disconnect.
So:
- Log in to your Google account only inside a dedicated browser profile or separate browser.
- Do not let that browser be your main “surf the web” tool.
You are not turning off AI. You are walling it off.
2. Stronger isolation than just “junk vs real” accounts
Splitting accounts is good, but I would strengthen the model a bit compared to what was suggested.
Set it up like this:
Work / dependency profile
- Dedicated browser profile (or entire different browser).
- Only for services where you are locked in: Gmail, Drive, Calendar, Meet.
- No general web search, no random tab wandering.
Disposable search profile
- Another browser or profile, logged out of Google.
- Default engine: privacy‑focused search (DuckDuckGo, Brave Search, etc.).
- Use Google Search there only when absolutely needed, still logged out.
Quarantine profile (optional)
- For testing new AI experiences to see what is changing, without polluting the others.
This is stricter than what was described before, but it reduces the “oops I did my whole browsing while signed in” problem.
3. Don’t overestimate account settings for privacy
I actually disagree a bit with how much trust people put in:
- Activity toggles
- Ad personalization settings
- “Help improve” checkboxes
Use them, sure, but treat them as “compliance UI,” not real isolation. They are useful for:
- Slightly reducing individual profiling
- Slightly reducing ad creep
- Maybe keeping you out of certain experiments
They are not a guarantee that your data is not used for aggregate training or that back‑end AI isn’t touching your stuff.
So:
- Turn them off, but then behave as if they only helped at the margins.
- The serious privacy gains come from avoiding sending data in the first place.
4. Visual and UX hygiene: remove AI so you don’t interact with it
The others talked a lot about switches. I would put more emphasis on visual / UX filters, which they only touched briefly.
Use a good content blocker and customize it so you:
- Hide generative boxes in Search results.
- Hide “AI suggestions” panels in Gmail, Docs, and other web UIs where possible.
Why this matters:
- It reduces the chance you accidentally click or feed text into AI tools.
- It returns your mental model to “classic web,” which is honestly half the battle.
The AI may still run on Google’s side, but you are not engaging with it, which also limits personalization paths.
5. Do more work offline before touching Google
If you are especially worried about content feeding models:
- Draft emails in a local editor.
- Write documents, notes, and outlines in an offline app or a non‑Google cloud.
- Paste only the final, minimal version into Gmail or Docs.
Even better:
- Keep sensitive long‑term stuff like journals, research notes, or business strategy documents out of Google entirely and store them locally or in a privacy oriented service.
You are not going to “turn off AI” here, but you can starve it of the most sensitive content.
6. Gradual exit plan instead of permanent tuning
Constantly hunting for new AI toggles gets tiring. Instead of playing whack‑a‑mole forever:
Prioritize what to move first
- Cloud files
- Photos
- Search
Pick non‑Google alternatives
- Privacy focused email providers.
- Independent search engines.
- Open source note apps and storage.
Migrate slowly
- Forward email.
- Sync files out of Drive into a neutral location.
- Change the search engine in your “real” browser and keep Google as a backup only.
You end up using Google mostly as a compatibility layer or for legacy reasons, not as the default environment that sees everything.
7. About the “How do I completely turn off AI features in Google products?” idea
Pros of chasing this:
- You will learn a lot about your settings and history.
- You can reduce some personalization and visible AI clutter.
- You gain a bit more control over what is explicitly used.
Cons:
- No realistic way to verify that AI is truly “off” anywhere.
- Google can and does change defaults and experiment flags silently.
- You spend time tweaking an ecosystem that is structurally moving in the opposite direction of what you want.
The previous posts from @viaggiatoresolare and @himmelsjager are great for the “turn every dial to minimum” route. I just would not stop there. The more important layer is how, when, and if you use Google at all, rather than which individual switch you flipped last week.
