How To Backup Android Phone
I’m trying to properly back up my Android phone and I’m a bit confused about the best method. I’ve got photos, app data, texts, and settings that I really don’t want to lose, especially after almost losing everything when my previous phone died unexpectedly. Should I use Google’s built-in backup, a third-party app, my computer, or all of the above? I’d really appreciate clear, step-by-step advice on the safest and most complete way to back up an Android phone.
Short version so you do not lose stuff again:
  1. Google backup
    • Settings > Google > Backup
    • Turn on “Backup by Google One”
    • Make sure it backs up: Apps, SMS, Call history, Device settings, Photos & Videos (if shown)
    • Plug in, WiFi on, hit “Back up now”
    This saves: app list, some app data, WiFi passwords, wallpapers, texts (on newer phones), etc.
  2. Photos and videos
    Use Google Photos.
    • Open Google Photos > your profile > Photos settings > Backup
    • Turn it on, set “Original quality” or “Storage saver”
    • Leave phone on WiFi until backup finishes
    For extra safety, also copy DCIM folder to a PC:
    • Connect by USB, set file transfer mode, copy DCIM and Pictures to a hard drive.
  3. SMS and call logs (if your Google backup does not handle them)
    Use “SMS Backup & Restore” from Play Store.
    • Backup to Google Drive or OneDrive
    • Schedule automatic backups, like once per day
    This helps a lot when switching phones.
  4. WhatsApp and similar apps
    Each app has its own backup. Example WhatsApp:
    • Settings > Chats > Chat backup
    • Backup to Google Drive, pick frequency, include videos if you want
    Check for other apps with cloud options, like Signal, Telegram, etc.
  5. Local full backup to PC (for control freak mode)
    Use:
    • Samsung: Smart Switch
    • Xiaomi: Mi PC Suite or local backup in Settings
    • Others: “ADB backup” is possible but messy and old
    At minimum, copy: DCIM, Pictures, Movies, Music, Downloads, Documents.
  6. Test restore once
    If you get a spare phone or old phone, log in and see what comes back.
    You spot gaps fast that way. Missing notes, 2FA, authenticator codes, etc.
  7. Extra tip for 2FA
    Move from SMS codes to an authenticator app that has its own backup.
    • Google Authenticator with account sync
    • Microsoft Authenticator
    • Authy
    Otherwise, factory reset hurts a lot.
If you set:
• Google backup on
• Google Photos backup on
• SMS + WhatsApp backup
• Periodic PC copy of files
You will survive a dead phone or lost phone with minimal pain.
@sonhadordobosque pretty much nailed the “standard” setup, so I’ll avoid rehashing all the same steps and add the stuff people usually find out after they lose data.
1. Don’t trust only one backup location
Cloud is nice, but things go wrong: account lockouts, sync bugs, accidental deletions. Aim for at least two of these:
  • Google cloud (what they described)
  • Local PC / external drive
  • Optionally another cloud (OneDrive, Dropbox, Syncthing, etc.)
If all your eggs are in the Google basket and that basket glitches, you’re kinda toast.
2. Use a folder‑sync app instead of only “copy once”
Instead of manually copying DCIM now and then, use a sync app that mirrors specific folders to another place:
  • Apps like FolderSync, Syncthing, etc.
  • Point it at DCIM/, Pictures/, Documents/, Download/
  • Target: home NAS, PC, or another cloud
Benefit: it keeps things up to date, not just “whenever I remember to plug in a cable.”
3. App data is the messy part
This is where I slightly disagree with relying too heavily on Google backup: it does not reliably save everything for every app.
Better approach:
  • Check your most important apps one by one
    • Notes, budgeting, password managers, health apps, authenticator apps, etc.
    • Go into their settings and see if they have their own backup / cloud sync.
  • Turn those on, or export manually:
    • Many note/finance apps have “Export backup” to a file. Save that to your PC or cloud.
    • Calendar/contacts: make sure they sync to your Google account, not just “Phone” storage.
Treat each “critical life app” as its own backup project.
4. Passwords & 2FA deserve separate attention
Totally agree with moving off SMS 2FA, but don’t just swap to any random authenticator and call it a day.
  • Use something that:
    • Syncs across devices and
    • Lets you export or has recovery methods (recovery codes, backup password, etc.)
  • Store recovery codes in:
    • A password manager, or
    • An encrypted file you also back up
People lose 2FA and then lose access to the accounts that they’d need to restore everything else. That’s the real “factory reset hurts a lot.”
5. Don’t ignore contacts & calendars
Weirdly easy to mess this up:
  • In Contacts, check where a new contact is being saved:
    • Make sure it says “Google account” and not “Phone” or “SIM”
  • For calendar, confirm you’re using a Google calendar that shows up under your account, not some local-only calendar.
If you back up “perfectly” but all your contacts lived on the SIM or local phone profile, you’ll still feel like everything vanished.
6. If you care about everything, look at full-system solutions
For people who want almost “image-level” backups:
  • Some brands have better built-in tools:
    • Samsung: Smart Switch (mentioned already) can back up more than just media and a settings list.
  • If you’re less scared of technical stuff:
    • Use adb to pull entire folders like /sdcard/ to your PC
    • It’s not pretty, but at least you own the backup
I’m not a big fan of the old adb backup command anymore, it’s flaky and abandoned, so I’d rather copy directories than rely on that.
7. Test a partial restore before you need it
You don’t always need a spare phone like @sonhadordobosque suggested, although that’s ideal. As a lighter test:
  • Sign into your Google account on another Android device (even a tablet or emulator)
  • Install a few of your key apps
  • Check if:
    • Contacts appear
    • Calendar matches
    • Photos are visible
    • Your “critical apps” can see their data / cloud sync
You’re trying to find “surprise, that app never backed up at all” before your phone dies.
8. Make a tiny checklist and repeat
Most people lose data not from one disaster, but from slowly drifting out of backup habit.
Write a stupidly short checklist like:
  • Google backup status checked
  • Google Photos shows “Backup complete”
  • Folder sync last run date
  • Key apps: exported / confirmed cloud sync
Do that once a month or whenever you do other digital housekeeping. Takes 5 minutes, saves a ton of regret.
If you set up what @sonhadordobosque described as your base layer, then add:
  • Per-app backup for critical stuff
  • A second location (PC / other cloud) with folder sync
  • A quick restore test
you’ll be in the “my phone died and it was mildly annoying, not life-ruining” category instead of the “I lost 8 years of my life in 10 seconds” category.
I mostly agree with @sonhadordobosque and the follow‑up you quoted, but I think people overcomplicate Android backups and then never actually keep them current.
Here’s a more no‑nonsense angle that complements what’s already been said, focusing on what really survives a dead phone, not just what should survive in theory.
1. Decide what you’re willing to lose
Harsh filter, but useful:
  • Must not lose
    • Authenticator / 2FA access
    • Passwords & recovery codes
    • Contacts & calendar
    • Irreplaceable photos & videos
    • Work stuff (docs, notes, finance apps)
  • Annoying but acceptable to lose
    • App layouts, home screen arrangement
    • Chat wallpapers, some app preferences
    • Games you barely touch
This matters because you don’t need full‑image backups if your real priorities are just a handful of data types. Otherwise you chase “perfect” and end up with nothing tested.
2. I slightly disagree on “image‑style” thinking
Trying to clone an Android phone 1:1 like a PC image is fragile:
  • Breaks easily after OS upgrades
  • Often needs root or brand‑specific tools
  • You restore old junk and bugs you should have left behind
I prefer a “clean reinstall plus data restore” model:
  1. Assume apps will reinstall from Play Store.
  2. Make sure data is independently backed up (Cloud, export, or synced account).
  3. Accept that rebuilding the home screen once every 3–4 years is not a tragedy.
For almost everyone, that is more reliable than chasing a mythical “full snapshot.”
3. Where Google backup actually bites people
What the others said is accurate, but here are the common gotchas:
  • WhatsApp / Signal / Telegram
    • They use their own backup systems. If you forget to turn those on or point them at Google Drive, Google’s system will not save your chat history.
    • For WhatsApp, do a manual backup and then confirm the backup exists in Drive.
  • Offline / local‑only notes
    • Any notes app that does not clearly say “syncing with X account” is suspicious.
    • If there is an export to .zip, .json, or .txt, do it and copy that file somewhere safe.
  • Health & fitness data
    • Check if it is syncing to Google Fit or Samsung/brand account or some third‑party cloud.
    • If not, expect it to vanish on reset.
Treat these as separate projects, just like the other post suggested, but be ruthless: if critical apps have no proper export or cloud option, consider switching apps before disaster.
4. Practical multi‑location strategy without going crazy
A realistic setup most people can maintain:
  1. Google account as baseline
    • System settings, basic app list, some app data, contacts, calendar.
  2. Photos & media: one automatic source + one manual archive
    • Automatic: Google Photos or a folder‑sync tool to NAS / PC.
    • Manual: Twice a year, copy /DCIM and important folders to an external drive. You can use adb pull /sdcard/ if you like commands, but a simple MTP drag‑and‑drop works too.
  3. Key apps: per‑app backup / export
    • Once a month:
      • Check that messengers show “backup recent.”
      • Export critical databases (budget, notes, journals) to a single “Android‑Backups” folder.
      • That folder gets synced or copied offphone.
This hits the same goals as the earlier replies but prunes a lot of overkill.
5. 2FA & passwords: treat them like your house keys
Where I am stricter than most:
  • Your password manager needs:
    • Strong master password
    • Export or recovery method
    • Backup of emergency kit or recovery codes to a second location
  • Your 2FA setup should be:
    • Not just SMS
    • Backed by recovery codes saved in the password manager
    • Tested at least once: log in on a second device and verify you can still reach your accounts
People often have perfect photo backups and still lose everything because they cannot sign in anymore.
6. Test in a low‑risk way
I agree testing is vital, but instead of playing with an emulator or spare phone, a simpler test:
  • Borrow a friend’s Android tablet / an old phone for a day.
  • Log into your Google account.
  • Install 3–5 critical apps.
  • Check what actually appears:
    • Contacts list
    • Calendar entries
    • Cloud‑synced notes
    • Messaging history if the apps are multi‑device
If it is missing there, it will be missing after a factory reset.
7. Pros & cons of this “layered but not obsessive” approach
  • Easier to keep up long term
  • Less technical, works even if you never touch adb
  • Focuses on data that matters, not cosmetic stuff
  • Survives phone loss, theft, or sudden death
  • You will not get a pixel‑perfect clone of your old phone
  • Requires some manual exports for niche apps
  • Needs a bit of discipline once a month or quarter
Bottom line: what you already read from @sonhadordobosque and the follow‑up is a strong “standard” blueprint. Trim it down to what you will actually maintain, double‑check a few risky apps, and verify you can log in and restore on a second device. If you can do that, a dead phone becomes an inconvenience instead of a catastrophe.
