How To Screen Record On Android
I’m trying to record my Android screen to capture an app demo and some gameplay, but I can’t figure out the built-in options or the best free apps to use. My phone’s settings are confusing, and online guides don’t match my device. Can someone walk me through the easiest way to screen record on Android and recommend any trusted apps or settings I should use?
Short version first.
  1. Try built in recorder
  2. If missing or limited, use a free app
  3. Tweak settings for resolution, fps, audio
Now details.
  1. Check if your phone has built in screen record
On most Android 11+ devices:
• Swipe down twice from the top to open the full Quick Settings shade
• Look for “Screen Record” or “Screen Recorder” tile
• If you do not see it, tap the pencil / edit icon, drag “Screen Record” into the active tiles
Then:
• Tap “Screen Record”
• Choose:
– Record audio: device audio, mic, or both
– Show touches on screen: on if you do a tutorial
• Hit Start, wait for countdown
• To stop, tap the red notification or the floating bubble
On Samsung (One UI):
• Same pull down, look for “Screen recorder”
• First time, it asks audio source:
– No sound
– Media sounds
– Media sounds and mic
• You can also set video quality in Settings app
Settings → Advanced features → Screenshots and screen recorder
On Xiaomi / Redmi / Poco:
• Pull down QS, find “Screen Recorder”
• If missing, edit tiles and add it
• You can open the Screen Recorder app to tweak:
– Resolution
– Video quality bitrate
– FPS (often 30 or 60)
On OnePlus:
• Pull down QS, look for “Screen Record”
• Edit tiles if missing
• Tap the small settings icon on the Screen Record tile to change resolution, bitrate, and audio
If none of this matches your menus, check your Android version:
Settings → About phone → Android version
Android 10+ usually has built in recording. On some older phones the vendor hid it or removed it.
  1. If your phone has no built in recorder
Grab one of these from Play Store:
• XRecorder (InShot Inc)
– Free with ads
– No watermark by default
– Supports internal audio on some devices on Android 10+
– Good for gameplay
• AZ Screen Recorder
– Popular, simple UI
– Needs mic for audio on older Android versions
– Settings for resolution, bitrate, fps
• Mobizen
– More focused on tutorials, has facecam option
– Watermark unless you tweak settings or pay
For gameplay, XRecorder usually works better.
For app demos, AZ is simple and stable.
  1. Get internal audio for gameplay
This depends on your device and Android version.
• Android 10+ added support for internal audio capture
• Many apps expose it as “Internal audio” or “Audio from system”
• On some brands, internal audio only works for media, not calls or DRM content
Steps in XRecorder for example:
• Open XRecorder
• Go to Settings
• Audio source → choose “Internal” or “Internal and mic”
• If internal is missing or greyed out, your phone or Android version blocks it
If internal audio does not work, use:
• Headphone splitter or external recorder, or
• Record game sound with mic, but turn off room noise like fans
  1. Fix lag and bad quality
For smooth gameplay:
• Resolution: 720p is enough for most demos. 1080p can lag on weak phones
• FPS: 30 fps for tutorials, 60 fps for fast games
• Bitrate: 6–10 Mbps for 1080p, 4–6 Mbps for 720p
If recording stutters:
• Lower resolution first
• Close other apps in recents
• Disable high graphics settings in the game
• Keep storage over 3–5 GB free
  1. Fix no sound or low sound
If you use built in recorder:
• Before recording, check audio option:
– Device audio only for clean game sound
– Device audio and mic for commentary
• Make sure Do Not Disturb is on if you do not want notification sounds in the video
If your voice is too low:
• Turn mic volume up inside the app if it has that slider
• Keep the mic hole on the phone uncovered
• Move your mouth closer if you record commentary
  1. Where to find recordings
Typical locations:
• Google Files or My Files app → Videos
• Or Internal storage → Movies → Screen recordings
• Or the app specific folder like /Movies/ AZScreenRecorder or /Movies/XRecorder
Open your gallery, look for an album called “Screen recordings” or the app name.
  1. Extra tips for clean app demos
• Turn off notifications
Settings → Notifications → Do Not Disturb
• Change wallpaper and hide personal icons if you record your home screen
• Turn on “Show taps”
Developer options → Show taps
If Developer options is hidden:
– Settings → About phone → tap Build number 7 times
– Back out, Developer options appears under System or Additional settings
That makes your touches visible in recordings, which helps viewers.
  1. Summary setup example for you
If you have Android 12 stock or Samsung:
• Pull down shade → tap Screen record
• Audio: Device audio and mic
• Turn on Show touches
• Record your app demo
• Hit stop in notification bar
• Edit clip in Google Photos to trim start and end
If your phone has no built in:
• Install XRecorder
• Open it, grant overlay and storage permissions
• Set 1080p, 30 fps, 6 Mbps
• Audio source: Internal and mic (if available)
• Start game, tap floating record button
• Stop from notification when done
If you reply with phone brand and model, plus Android version, people can give more exact tap by tap paths.
If online guides don’t match your menus, you’re probably running into two issues at once: manufacturer skin + Android version weirdness. @jeff covered the “normal” path pretty well, so I’ll hit the stuff that usually actually trips people up.
1. Confirm if your phone is secretly blocking features
Vendors love hiding or breaking Google’s built‑in recorder:
  • Go to Settings → About phone → Software information (or similar)
    • Check Android version
    • Check if you’re on something like MIUI, One UI, ColorOS, etc.
If you’re on Android 10+ and still see no Screen Record tile after editing Quick Settings, your OEM might have removed it or tied it to some “Game Mode” or “Game Booster” app.
2. Check “Game Mode” / “Game Tools”
For gameplay recording specifically, a lot of phones put the recorder inside a “game” overlay instead of the pull‑down tiles:
  • Launch your game.
  • Look for:
    • Floating icon on the edge of the screen
    • A small “G” or “rocket” icon
    • Swipe from the side to open a game toolbox
Inside that, you’ll often see:
  • Record or Screen capture
  • Sometimes a toggle for mic / internal audio
This is especially common on:
  • Samsung (Game Launcher / Game Tools)
  • Xiaomi / Poco (Game Turbo)
  • Oppo / Realme (Game Space)
  • Vivo (Ultra Game Mode)
If that works for games, you can still use a separate app recorder for app demos.
3. When free apps act weird
Everyone recommends AZ, XRecorder, Mobizen, etc., but here’s what usually causes the “why is this so bad” moment:
  • Overlay permission not granted
    • You’ll never see the floating button
    • Fix in Settings → Apps → Special access → Draw over other apps
  • Battery optimization killing the recorder
    • Mid‑recording stops, missing footage
    • Go to Settings → Battery → App battery management
    • Set your recorder app to Unrestricted or Don’t optimize
  • MIUI / ColorOS / EMUI aggressive killers
    • Sometimes you have to lock the app in recents (long press → Lock) so it doesn’t die
This is where I slightly disagree with @jeff: sometimes the built‑in recorder is more unstable than a good third party app, especially on heavily customized ROMs. If your built‑in one just randomly stops or corrupts clips, I’d go straight to XRecorder or AZ and tune those instead.
4. Avoid the “video is crisp but everything lags” problem
Instead of cranking resolution first, try this order:
  1. Start with:
    • 720p, 30 fps, medium bitrate
  2. Test your heaviest game for 1–2 minutes.
  3. If it’s smooth:
    • Then try 1080p, keep 30 fps
  4. Only if your phone is decent (Snapdragon 7xx/8xx or equivalent) bump to 60 fps.
If you start at 1080p 60 fps, lots of midrange devices basically melt and you end up with a slideshow.
5. Internal audio vs mic reality check
On some phones:
  • Internal audio is blocked for 3rd party recorders for “security/DRM reasons.”
  • The built‑in recorder can capture internal audio but XRecorder / AZ only see the mic.
So if:
  • Built‑in recorder captures clean game sound, but
  • XRecorder only gives you “Microphone”
Then your only reliable way to get game audio is:
  • Use built‑in for gameplay
  • Third party app only for app demos where you don’t care about perfect internal audio, or you just talk over it.
6. Quick setup that usually works when nothing else does
If I had to give a single “works on most phones” path:
  1. Install XRecorder.
  2. In Android settings:
    • Turn off battery optimization for XRecorder
    • Allow overlay / draw over apps
  3. In XRecorder:
    • Resolution: 720p or 1080p
    • FPS: 30
    • Bitrate: medium or around 6 Mbps
    • Audio source: Internal & mic if it exists, otherwise mic.
  4. Start the app/game first, then tap the floating record button.
If you post your phone brand + model + Android version, people can usually map it 1:1 to the right menus, because half the problem here is that every manufacturer thinks they have to rename “Screen record” to something cute and useless.
If @jeff covered the “how it’s supposed to work” path and the follow‑up about OEM quirks is the “why it doesn’t,” I’ll hit the stuff that bites you after you finally get a recorder running: getting usable, repeatable results for app demos and gameplay.
1. Decide first: app demo vs gameplay
Treat these as two different jobs:
  • App demo
    • Priority: clean UI, readable text, your voiceover
    • You can live with 720p, 30 fps, mic audio only
    • Vertical orientation is often fine
  • Gameplay
    • Priority: motion smoothness and in‑game audio
    • 1080p is only worth it if the game itself runs well
    • Internal audio is much more important than resolution
If you try to use one “maxed out” config for both, you usually end up with laggy games and bloated files for simple app walkthroughs.
2. Built‑in recorder vs third‑party: pick a role for each
I don’t fully agree with the idea that you must bail on the built‑in recorder once it glitches. I tend to use them like this:
  • Built‑in recorder
    • Use when:
      • You want internal audio on a locked‑down device
      • You need maximum compatibility with weird OEM skins
    • Pros:
      • Usually better access to internal audio
      • Lower chance of overlays conflicting
    • Cons:
      • Fewer tuning options
      • Some block 3rd party mic + internal audio mix
  • Third‑party recorder (like XRecorder, AZ, etc.)
    • Use when:
      • You are making tutorials, app demos, or commentary
      • You want overlay buttons, facecam, countdown timers
    • Pros:
      • More control over fps, bitrate, orientation
      • Floating controls and quick pause
    • Cons:
      • More fragile with battery killers and permissions
      • Internal‑audio capture is hit or miss on some Android builds
So a practical split that works on a lot of phones:
  • Gameplay with sound: built‑in
  • App tutorials and talking over content: third‑party
3. Two separate “profiles” that actually cover 90% of use cases
Once you pick your recorder(s), set up two presets mentally, even if your app does not name them that way.
Profile A: App Demo
  • Orientation: Portrait (unless the app is landscape only)
  • Resolution: 720p
  • FPS: 30
  • Audio: Microphone only
  • Helpful toggles:
    • Show touches / taps
    • Lower system volume so notification pings are not deafening
Use this for:
  • Recording bug reports
  • Store listing videos
  • Tutorials for friends or coworkers
Profile B: Gameplay
  • Orientation: Landscape
    • If your game is intense or your phone is midrange, start with 720p
  • FPS:
    • 30 on most phones
    • 60 only if your device already plays that game at 60 fps without recording
  • Audio:
    • Internal only, or internal + mic if available
Use this for:
  • Anything you might upload or share publicly
  • Longer play sessions
Switching between these two “mental presets” avoids the classic “why does my UI look microscopic and my file is 4 GB for 5 minutes?” problem.
4. Storage and overheating: the stuff everyone forgets
Once you start capturing gameplay, problems change from “how do I record” to “why is my phone boiling and my storage full.”
  • Free space buffer
    • Keep at least 5–10 GB free before any long session
    • Screen recorders often fail silently when storage is close to full
  • Thermal issues
    • High resolution + 60 fps + mobile data + high brightness is the recipe for thermal throttling
    • If you see your fps tank after a few minutes:
      • Drop to 30 fps
      • Lower brightness
      • Turn off mobile data if you do not need it
  • File format
    • Prefer MP4 if there is a choice
    • WebM / MKV can be slightly more efficient but can confuse some older editors or file managers
5. Editing light vs editing heavy
If you plan to do any editing later, record in a way that makes your life easier:
  • Keep steady orientation
    • Do not rotate the phone mid‑record
  • Avoid piling on fancy overlays while recording
    • Simple cursor / taps are fine
  • Record a few seconds of “quiet” at start and end
    • Makes trimming easier without killing important content
If you want to keep it very simple, you can just trim the start and end inside Google Photos or your gallery app and call it done.
6. Pros & cons of using a generic “How To Screen Record On Android” setup
If you follow a generic “How To Screen Record On Android” recipe from random guides, here is what usually happens.
  • You end up with a single, repeatable path that you can remember.
  • You are likely using default resolutions and codecs that most phones handle well.
  • You spend less time fiddling and more time just capturing something.
  • It rarely addresses internal‑audio limitations on your specific OEM skin.
  • It may push you toward 1080p or 60 fps that your device cannot handle smoothly.
  • It often ignores battery optimization rules, so recording stops mid‑session.
That is where @jeff’s advice and the follow‑up about OEM issues are solid, but I would adjust those templates around the two‑profile approach above so you do not sacrifice performance when you only need a simple demo.
7. Quick sanity checklist before you hit record
Right before you record either an app demo or gameplay, walk through this extremely short list:
  1. Enough free space (5+ GB recommended).
  2. Orientation locked the way you need it.
  3. Correct profile:
    • Demo profile for apps
    • Gameplay profile for games
  4. Do not disturb mode on, if you care about hiding notifications.
  5. Test recording for 10–20 seconds and play it back.
That last test clip catches 90% of “no audio,” “wrong orientation,” and “screen is a stuttery mess” problems before you waste time on a long run.
If you post your exact model and Android version, you can map these profiles to whatever your OEM calls its recorder options, since every vendor insists on renaming the same three toggles into something different.
