How To Stop Screen Recording On Mac
I started a screen recording on my Mac using the built-in tools, but now I can’t figure out the proper way to stop it without risking losing the recording. The controls disappeared from my screen and I’m not sure if there’s a shortcut or menu option I should use. Can someone explain the correct steps to stop a Mac screen recording safely so the video saves correctly?
Happens a lot, macOS hides the controls in a kinda dumb way.
Try these in order:
  1. QuickTime screen recording
    If you started it from QuickTime Player:
  • Look at the top of your screen in the menu bar
  • Find a small solid circle icon with a square inside it (looks like a stop button)
  • Click it.
  • QuickTime opens a window with your recording where you can save it from File > Save.
  1. Screenshot toolbar recording (Shift + Command + 5)
    If you started it with Shift + Command + 5:
  • Same deal, small stop button in the top menu bar on the right side
  • Click that to stop
  • A thumbnail of the recording pops up in the bottom right
    • Click the thumbnail to edit or save
    • If it disappears, the file is already saved, by default in your Desktop or Downloads (check both).
  1. Keyboard shortcut if toolbar vanished
    Sometimes the toolbar is hidden:
  • Press Command + Control + Esc
  • That stops an active screen recording started from the screenshot toolbar.
  1. If nothing works and you want to avoid losing the file
  • Do not force shutdown
  • Press Command + Option + Esc and see if QuickTime Player is “Not Responding”
    • If it is, wait a bit, recordings often finalize after a short pause
  • If you started it from QuickTime and you force quit, the current recording is usually lost.
Quick way to check if it stopped:
  • Look again at the top menu bar
  • If the stop icon is gone, recording ended
  • Check default save folder: Desktop, Documents, or Downloads
    • File name is something like “Screen Recording 2026-02-16 at 4.32 PM.mov”.
Next time you start a recording:
  • Before you start, click Options in the Shift + Command + 5 toolbar
  • Set “Save to” to a known folder so you always know where it goes.
Couple extra angles that might help, especially if the little stop icon @shizuka mentioned is just not showing up anywhere.
  1. Check if the recording is actually still running
    Sometimes macOS bugs out and the screen recording is already finished but the UI never told you. Quick checks:
  • Open Activity Monitor (Spotlight → type “Activity Monitor”)
  • Look for “screenrecordingd” or “QuickTime Player” using a lot of CPU
    • If you don’t see anything heavy like that, the recording may already be finalized
    • Then search your Mac for .mov files created “Today” via Finder → File → Find → Kind: Movie, Date: Today
  1. Use the Touch Bar (if you’ve got it)
    If you’re on an older MacBook Pro with a Touch Bar:
  • When recording, there’s often a tiny stop button in the Touch Bar itself
  • Tap that to cleanly stop the recording
    This is easy to miss, because Apple thought hiding critical controls in a tiny strip was a great UX choice.
  1. Full-screen apps / multiple displays issue
    If you started the recording in one ‘space’ and then switched:
  • Swipe between desktops/spaces with Control + left/right arrow
  • The floating controls or the stop button might be on a different desktop than the one you’re staring at
  • Also check the menu bar on every screen if you’re using multiple monitors
  1. Prevent data loss if things feel frozen
    If QuickTime or the recording service looks hung, I actually disagree a bit with just “wait it out” forever:
  • Give it 1–2 minutes
  • If your Mac sounds like a jet and apps are lagging, plug into power so it does not die mid-finalization
  • Avoid force restart. Instead:
    • Try logging out: Apple menu → Log Out (this can sometimes close the UI while letting background tasks finish)
    • Then log back in and check the usual folders (Desktop, Documents, Downloads) for a fresh recording file
  1. Future-proof trick: shorten the risk window
    Next time you record, reduce how long you’re risking one giant file:
  • Record in segments: stop and restart recordings instead of doing one mega session
  • Or, in QuickTime, do shorter clips and stitch them together later
    If things crash, you only lose the last chunk, not the entire thing.
  1. Quick sanity test once you think you stopped it
    When you believe the recording is ended:
  • Lock your screen (Control + Command + Q) and unlock
  • If recording was still active, macOS sometimes complains or you’ll see performance jump back to normal
  • Then immediately search for “Screen Recording” in Finder to confirm the file exists before you start heavy work or shut down
Not gonna lie, Apple made screen recording way more opaque than it needs to be, so you’re not the only one hunting for a ghost stop button on a blank menu bar.
If the normal stop controls are gone and the stuff @shizuka suggested hasn’t solved it, here are a few different angles to try, plus how to avoid losing the file.
1. Use the menu bar icon properly (hidden in plain sight)
Even when the floating controls vanish, macOS should still show a tiny stop icon in the menu bar on the right side:
  • If you used Shift + Command + 5:
    • Look for a small solid square inside a circle in the top-right menu bar.
    • Click it once. Do not spam click. It can take a bit to finalize, especially for long recordings.
  • If you used QuickTime:
    • In the menu bar, click QuickTime PlayerStop Screen Recording.
    • Or right-click the QuickTime icon in the Dock → see if there’s a Stop Recording option.
Sometimes people just skim the icons and miss it because it looks like a status icon, not a button.
2. Use keyboard shortcuts to bring back controls
If the controls glitched away:
  1. Press Shift + Command + 5 again.
  2. If you see the screenshot/record bar reappear, look carefully:
    • If a recording is in progress, there should be a Stop icon in that bar.
    • Click that instead of starting a new recording.
If it only offers to start a new recording, macOS might already think the previous one ended and is just processing the file in the background.
3. Let macOS finish writing the file before you panic
Where I slightly disagree with the “just give it 1–2 minutes” advice: if you’ve recorded a long session (like 1+ hours, 4K screen, lots of motion), finalization can take way longer, especially on older Intel Macs.
  • Plug into power.
  • Close heavy apps, but avoid force quitting QuickTime Player or screenrecordingd.
  • Wait at least 5–10 minutes for big recordings.
  • During this, avoid logging out or shutting down; that can interrupt file writing.
If the file is huge, the OS might be writing it to disk even after the UI stops responding.
4. Use “Recent Items” to locate a silently finished recording
If it seems like everything’s “stuck” but not obviously recording:
  1. Click the Apple menu.
  2. Go to Recent Items.
  3. Check under Movies to see if a file with a recent timestamp appears.
  4. Open that; if it plays, your recording already ended and you’re safe.
This works when the UI never showed the “done” thumbnail preview.
5. Try a safe logout without killing the recording process
If the recording app froze visually but the Mac is otherwise usable:
  1. Save any critical work in other apps.
  2. Go to the Apple menu → Log Out.
  3. If macOS prompts that an app is blocking logout, do not force quit that screen recording process.
  4. Cancel logout, then:
    • Open QuickTime manually.
    • See if it offers to recover or display an ongoing recording window.
Logging out is a last resort, but it sometimes “reminds” background UI to flush state without a full reboot.
6. Future safety: avoid huge single recordings
To avoid this entire mess next time:
  • Record in segments: Stop and restart between major sections.
  • Use lower resolution or frame rate when possible. Smaller files finalize faster.
  • After every important section, stop, let it finalize, verify the file, then continue.
If you ever use a dedicated tool like a third-party screen recorder instead of the bare-bones macOS recorder, check for autosave / crash recovery features. That is a pro in those tools:
Pros:
  • Often have autosave or recovery of partial recordings
  • Live preview of recording status
  • More obvious stop buttons and keyboard shortcuts
Cons:
  • Extra background processes
  • Can be heavier on CPU/GPU
  • Some add watermarks or have limited free features
Compared with what @shizuka wrote, I’d be a bit more cautious about logging out early if your Mac is clearly grinding on disk/CPU, because that is exactly when the system might still be writing the video file. If the fans ramp up right after you hit stop, that is usually the “finalizing” window. Let it cook a bit before touching anything drastic.
In practice, the safest sequence is:
  1. Look for the menu bar stop icon.
  2. Hit Shift + Command + 5 to re-summon controls.
  3. Wait several minutes if it looks frozen but the machine is busy.
  4. Only then start experiments like logout, never force restart unless the Mac is totally unresponsive.
