Meta AI suddenly started showing up in my app, and now it keeps popping into search and chats when I’m just trying to use things normally. I’ve looked through the settings but can’t find a clear way to disable it. I need help figuring out how to turn off Meta AI or at least limit it because it’s getting in the way and making the app harder to use.
You usually do not get a full off switch for Meta AI. Meta added it into Facebook, Instagram, Messenger, and WhatsApp in different ways, and most apps do not offer a true disable option right now.
What you can do:
Mute or hide the Meta AI chat
Open the AI chat thread.
Tap the name at the top.
Look for Mute, Archive, Delete, or Hide.
This stops it from sitting in your chat list, though it might come back after updates. -
Limit it in search
In some apps, the search bar routes into Meta AI by default.
There is often no setting to remove this.
Your best workaround is to avoid the AI prompt and search through older menus like Explore, account search, or chat search if those still show up. -
Check app settings
Look in:
Settings
Privacy
Chats
Search
New features
If Meta added a toggle in your version, it will usually be there. For most users, there isnt one. -
Update or roll back
Some users report the AI appears after an app update.
If you are on Android, installing an older app version sometimes removes it for a while.
On iPhone, rollback is much harder unless you already use backups or test builds. -
Clear the chat history with Meta AI
If the issue is the bot popping into suggestions:
Open the Meta AI chat.
Delete the conversation.
Clear search history in the app.
This helps a bit, but not forever. -
Send feedback
Inside the app, use Help or Report a problem.
A lot of people are complaining about this. If enough users push back, Meta tends to tweak placement.
Short version, there is no clean universal ‘turn off Meta AI’ button right now. You can hide it, mute it, delete the chat, and reduce how often you see it. You cant fully remove it in most cases. Kinda dumb, but taht’s where things stand.
There really is not a proper master off switch, and @jeff is mostly right about that. Where I kinda disagree is the rollback idea. That is usually more hassle than it’s worth, and older app versions can break stuff or create security issues.
A couple other things to try that are a bit different:
- Log out and back in after deleting the AI thread. Sometimes the shortcut vanishes for a while because the app rebuilds your recents.
- Turn off app personalization/ad topics if your version shows those. It does not disable Meta AI, but it can reduce how agressively it gets suggested.
- On Android, disable app shortcuts and notification categories tied to assistant/chat suggestions. That won’t remove AI, but it can stop some of the popups.
- If Meta AI is in the search bar, try using the web version for a bit. Weirdly, some desktop/web layouts are less pushy than mobile.
- If you use Messenger or Instagram a lot, pin the chats you actually want. That can push the AI junk lower so it stops hijacking the top of your list.
So yeah, short answer: you probably can’t fully turn it off rn. Best bet is reduce visibility, kill notifications, and use alternate entry points in the app untill Meta changes it. Annoying? Yep. Very.
One thing I’d add to @jeff’s point: before fighting the app, check whether your account is in a server-side rollout. If it is, no local toggle will stick for long. That’s why some “fixes” seem to work for a day, then Meta AI comes right back.
A couple methods that are different:
Clear in-app search history completely.
Sometimes the AI prompt is tied to recent searches and suggested results. -
Restrict background activity for the app.
On Android: App info > Battery > Restricted.
On iPhone: turn off Background App Refresh.
This can cut down on surprise AI resurfacing. -
Remove microphone and contact permissions if you do not need them.
Not a disable switch, but it can reduce assistant-style nudges. -
Use Lite or browser-based variants if available in your region.
I slightly disagree with the idea that web is only a temporary workaround. For some people, it is the cleanest long-term option.
Pros for the ‘’: quick readability, easy testing of each workaround.
Cons for the ‘’: no true off switch, results vary by account and app version.
Bottom line: if Meta placed AI at the account level, you are mostly managing exposure, not actually turning it off.
