I just started using Photoshop AI tools and I’m confused about how to actually use features like Generative Fill and AI editing the right way. I tried following a few tutorials, but my results look off and I’m not sure what I’m doing wrong. I need simple step-by-step help so I can edit photos faster and get better results.
Start simple. Most bad Photoshop AI results come from bad selections and vague prompts.
Use this workflow.
Make a clean selection.
Feather 2 to 5 px.
Leave a little extra room around the object.
If the selection is messy, Generative Fill gets weird fast. -
Work on a duplicate layer.
Keep your original.
AI edits fail a lot. You want an easy rollback. -
Write short prompts.
Bad: ‘make this look awesome and cinematic’
Better: ‘red brick wall’, ‘wooden table’, ‘remove person’
Short prompts tend to give cleaner resluts. -
Match the scene.
Look at light, angle, color, and depth.
If your photo has soft light from the left, ask for edits tht fit that. AI does poorly when the new object fights the scene. -
Generate 3 versions, then refine.
Don’t keep rewriting from scratch.
Pick the closest one, reselect small areas, run it again. -
Use Remove Tool for small stuff.
Use Generative Fill for bigger changes.
People mix these up a lot. -
Fix the AI output by hand.
Clone Stamp.
Healing Brush.
Layer masks.
AI gives you 70 to 80 percent. You finish the last part.
Best beginner practice:
Remove objects from clean backgrounds.
Extend backgrounds.
Replace small areas.
Do not start with hair, hands, glass, or crowded scenes. Photoshop AI still messes those up.
If it looks fake, check shadows first. Then edges. Then color temp. That’s usally where it breaks.
A thing a lot of tutorials skip: Photoshop AI is not really a one-click ‘make image better’ button. It works best when you treat it like a rough concept artist, not a finisher.
I agree with a lot of what @reveurdenuit said, but I’d slightly disagree on prompts always needing to be super short. For object removal or simple replacements, yes. For style consistency, a little context can help. Stuff like ‘overcast outdoor lighting, realistic shadow’ can actually save you from weird plastic-looking results.
A few beginner tips that helped me:
- Check your document settings first. If the image is tiny or heavily compressed, AI results get mushy fast.
- Use reference layers mentally. Ask: where is the light coming from, what lens feel is this, how sharp is the background?
- Don’t accept all 3 generated options at full size. Zoom to 100 percent. Sometimes they look fine zoomed out and totally broken up close.
- If Generative Fill keeps inventing nonsense, make a larger or different shaped selection. Weirdly, giving it more context often helps.
- Use generative expand for canvas extension first. It’s one of the easiest AI tools to learn and less frustrating than object insertion.
- After the AI pass, use Camera Raw or simple color correction on the generated layer so it blends better. This is probly the missing step for a lot of people.
Also, don’t judge yourself by tutorial results. A lot of those demos are cherry-picked as heck. Real images are messier. If your edits look off, it’s usually because the AI patch is too sharp, too clean, or lit wrong. Not because you ‘used it wrong.’
Big thing I’d add to @reveurdenuit’s point: stop thinking in terms of “prompting well” and start thinking in terms of “selection design.” In Photoshop AI, your selection is half the instruction. A sloppy edge usually gives a sloppy result.
What works better for beginners:
- Make the selection slightly inside the object if you’re removing something. If you grab too much background, Photoshop guesses too much.
- Feather a little when needed, but not automatically. Too much feathering can create muddy borders.
- Put AI edits on separate layers and mask them manually after. The cleanup is where the edit becomes believable.
- Match noise and blur. This is the step people skip. Generated areas often look too perfect, so add a touch of grain or slight blur to fit the original photo.
- For faces, hands, text, and repeating patterns, expect to do manual repair. AI is still shaky there.
I slightly disagree with the idea that more context always helps. Sometimes extra wording makes Photoshop wander. If the result is weird, simplify first, then add one detail at a time.
Pros for Photoshop AI: fast ideation, great for extensions, decent object cleanup.
Cons: inconsistent realism, bad fine detail, can need more retouching than tutorials admit.
If you’re searching “How To Use Photoshop Ai,” the honest answer is: generate, mask, correct, repeat. That loop matters more than any magic prompt.
