Motion App Review
I’m considering using the Motion app to manage my schedule and tasks, but I’m unsure if it’s really worth the subscription cost. I’ve read mixed reviews about its AI scheduling, reliability, and learning curve. Can anyone share real-world experiences, pros and cons, and whether it’s actually improved your productivity or just added more hassle?
I used Motion for about 6 months for work and personal stuff, here is how it went for me.
What works well:
  1. Auto scheduling
    • If you have 10 to 30 tasks per day and lots of meetings, Motion helps.
    • It reschedules tasks when meetings move or run over.
    • It keeps priorities visible so you stop rearranging your calendar by hand.
  2. Good for “too many inputs”
    • If your work is reactive (Slack, email, random requests), Motion helps you re-plan fast.
    • You drop tasks in a backlog, set priority and deadline, it finds a time block.
  3. Team features
    • Shared projects and task assignment are decent.
    • Helpful if your team already lives in Google Calendar.
    • You see when people have realistic time for deep work, not only empty slots.
Where people hate it:
  1. AI scheduling feels aggressive
    • If you like fixed blocks, Motion will annoy you. It keeps moving tasks when conflicts appear.
    • If you do not trust it, you end up fighting the tool and lose time.
  2. Reliability
    • I had 2 sync issues with Google Calendar in 6 months.
    • One time it created overlapping events. Took 10 minutes to clean up.
    • Some users report more issues, so I would test on a “low stakes” week first.
  3. Learning curve
    • Expect 1 to 2 weeks of friction.
    • You need to set realistic task durations and strict working hours.
    • If you enter vague tasks like “work on project” with 2 hours, it breaks your day.
Pricing and “is it worth it”:
  • If you bill by the hour or your time is expensive, the cost is fine. I saved 20 to 40 minutes a day on planning.
  • If your days are flexible, with few deadlines, a simple to do app plus calendar might be enough.
  • If you are already deep in tools like Todoist, ClickUp, or Notion, switching hurts unless you commit hard.
Who I think Motion suits:
  • People with a lot of meetings, plus 10 or more tasks daily.
  • Managers, consultants, agency folk, freelancers with many clients.
  • People who like structured days and are okay letting software re-plan things.
Who it does not suit:
  • People who hate auto moving events.
  • People with highly unpredictable work, like constant emergencies.
  • People who like paper planners or manual time blocking.
How to test it without wasting the sub money:
  1. Do the trial and go all in for 7 days.
  2. Put your entire task list into it, not only a few items.
  3. Lock your working hours tight and set all meetings in one calendar.
  4. At the end of each day, check:
    • Did you follow the schedule at least 70 percent.
    • Did you feel less mental load about planning.
    • Did tasks with deadlines actually get done.
If the answer is “yes” to those three, the sub is likely worth it.
If you keep ignoring its schedule and rearrange things by hand, the tool is not a fit and you are better with a manual time blocking template or a cheaper task manager.
For me, Motion was worth it during a busy client-heavy period. After my workload calmed down, I went back to Todoist plus Google Calendar, since the automation felt like overkill.
Using Motion right now for my consulting work, and I both like it and kinda resent it, so here’s the non‑hyped take.
I mostly agree with @shizuka, but I think they’re a bit optimistic on who it’s “for.”
Where I differ:
  1. The AI “aggressiveness”
    For me this wasn’t just “annoying,” it actually made me ignore the calendar. When tasks keep hopping around, I started mentally treating them as optional. That’s dangerous if you already struggle with following a schedule.
    If you’re neurodivergent or easily overwhelmed by changing plans, Motion can feel like whiplash more than help.
  2. Reliability
    I didn’t get huge sync disasters, but I did see smaller glitches: tasks disappearing from the visible day, then popping back after a refresh, or recurring tasks not scheduling when I expected. Individually small, but it chipped away at my trust in the system.
    If you’re the kind of person who needs a calendar to be “source of truth,” any glitch is a big mental cost.
  3. Learning curve vs payoff
    I’d say it’s more like 2 to 3 weeks before it really “clicks,” not 1 to 2. The tool kind of punishes vague thinking. If you don’t know how long your stuff takes, you’ll spend extra time tuning estimates and priorities. That can be good, but it’s work.
    If you’re already tired of productivity tinkering, Motion will feel like yet another system you have to babysit.
When it actually shines (for me):
  • I have 4+ client projects going, plus meetings, plus hard deadlines.
  • I dump 30–50 tasks into it, give them priorities and deadlines, and it turns chaos into something I can execute.
  • On those weeks, the cost is 100% worth it because I literally avoid dropping paid work.
When it flops:
  • Slow weeks, or when I mostly have one big project. Then Motion is massive overkill and honestly just in the way. A simple to‑do list + manual time blocking in Google Calendar felt cleaner.
  • Creative/deep work days where I need 3–4 unbroken hours on one thing. Motion kept trying to chop it into little blocks unless I really micromanaged it.
A couple angles that might help you decide:
  1. Think in “salary minutes”
    Rough calc:
    • Take your hourly rate (or rough value of your time).
    • Motion price / hourly rate = minutes per month it has to save you to be worth it.
      If saving 15–20 minutes a day of planning/stress would already “pay” for it, then it’s easy to justify. If not, it’s a nice‑to‑have, not a no‑brainer.
  2. Personality fit check
    Motion fits if you:
    • Like external structure more than flexibility.
    • Are okay letting software “boss you around” a bit.
    • Actually follow a time‑blocked calendar already or want to.
    It’s a bad fit if you:
    • Live in organized chaos and somehow make it work.
    • Constantly react to emergencies where today’s plan is meaningless by 10 a.m.
    • Get stressed when your calendar changes a lot.
  3. How to trial it differently from what @shizuka said
    Instead of just “go all in 7 days,” try this experiment:
    • Pick your busiest upcoming week. If you use it on an easy week, it’ll feel useless.
    • Before you start the trial, write down how you currently plan (paper, Notion, whatever).
    • During the trial, do zero manual time blocking in your normal tool. Let Motion own your schedule.
    • End of the week, ask:
      • Did you actually execute more important tasks, or just feel “organized”?
      • Did you feel calmer or more controlled, or more annoyed?
      • Would you be upset if Motion vanished tomorrow?
If your honest reaction at the end is “ugh, I’d miss this,” then the subscription is worth it.
If your reaction is “nice idea, but I kept checking my old system,” I’d cancel and stick with a cheaper combo like Todoist + Google Calendar or even a solid paper planner plus time blocking.
TL;DR: Motion is powerful, not magical. It’s worth the money only if you (1) already care about time blocking, (2) have a real volume/complexity problem, and (3) are willing to let it actually drive your day instead of fighting it.
Using Motion App for about 6 months here; I land a bit differently than @shizuka and the other commenter, so here’s another angle.
Where I think Motion is actually strong
  • Hard‑deadline juggling
    If you run multiple projects with real external deadlines, Motion App is basically a constraint solver for your week. That part works well: it forces you to confront “this literally does not fit” earlier than a normal to‑do list would.
  • Decision fatigue reduction
    I slightly disagree that the moving tasks always make them feel optional. For me, the benefit is that I do not have to decide “what next” every 30 minutes. The calendar view becomes a conveyor belt. I only override it when something is clearly wrong.
  • Calendar + tasks in one place
    Compared to using a Trello / Todoist + Google Calendar combo, Motion App cuts out the mental tax of syncing two systems. This is subtle but real if your day is packed.
Where it bites
  • Control freak tax
    If you are very particular about when certain types of work happen, you will spend a lot of time pinning, locking, and tweaking. At that point the AI is not saving you time; it is arguing with you. In that case I would honestly recommend a plain calendar plus a task manager instead of Motion App.
  • Energy & context are mostly ignored
    Motion App is great at time math, not at human energy. If your afternoons are low‑focus and it keeps dropping deep work blocks there, it looks “efficient” but you end up procrastinating. You can hack this with custom work hours and task durations, but that is extra config work the app does not really guide you through.
  • Trust is fragile
    I agree with the other reply that even small glitches hurt trust. Once you catch it mis‑placing something important, you stop relaxing into it and start double‑checking. At that point, the automation value plummets.
Who I think Motion App is secretly “for”
  • People who already live inside a calendar and just want the task scheduling automated.
  • Freelancers / consultants with several clients and deliverables in parallel.
  • Managers who bounce between meetings and need their remaining time sliced efficiently.
Who should probably skip it
  • Students or solo creators with one giant priority and lots of flexibility. You can get 90 percent of the benefit from manual time blocking.
  • People in reactive roles where your day is destroyed by noon. Constant reprioritization can feel like watching a Tetris board in fast‑forward.
Pros of Motion App
  • Strong at turning a big backlog into a time‑bound schedule.
  • Reduces “what do I do now” decisions if you let it.
  • Integrates meetings and tasks into one daily plan.
  • Can surface that you have overcommitted earlier than most tools.
Cons of Motion App
  • Feels overbearing if you like to keep your days flexible.
  • Learning curve is real if you never estimated task durations before.
  • Small reliability quirks have a big psychological cost.
  • Handles time constraints better than human energy or context switching.
How I would actually test it
Instead of just “busiest week” or “all in for 7 days,” I would:
  1. Pick a week that is busy but somewhat typical for you, not a crisis week.
  2. Load Motion App with only your non‑negotiables and critical tasks; leave “nice to haves” in your old system.
  3. Let it schedule, then resist the urge to micromanage for 3 days. Only intervene for obviously wrong placements.
  4. At the end, measure two things, not just vibes:
    • Did more deadline‑bearing tasks get done earlier than usual?
    • Were your evenings mentally quieter, or did you feel constantly second‑guessy?
If the answer is “yes, my critical stuff happened sooner and my brain felt lighter,” the subscription is probably worth it. If instead you spent half the time arguing with the AI and still checked your old tool, then Motion App is adding cleverness, not clarity, and a simpler stack will serve you better than Motion in the long run.
