I’m overwhelmed by so many budgeting software options and don’t know which one actually works best for tracking monthly bills, savings goals, and shared expenses. I’ve tried a few free apps, but they either feel too complex or don’t sync well with my bank. Can anyone recommend reliable, easy-to-use budgeting software and explain what makes it work well for you?
I hit this same wall a year ago. Too many apps, too many “systems”. What worked for me was picking based on use case, not features.
Here is a simple breakdown for what you asked.
- Monthly bills
Goal: predict cash flow, avoid surprises.
Option A: Calendar style
App: Google Calendar or Apple Calendar
How
• Create a “Bills” calendar
• Add each bill as a repeating event on its due date
• Put the amount in the title
• Color code fixed vs variable bills
This keeps it dead simple. You see what hits when. Pair this with your bank app for actual balances.
Option B: Spreadsheet
Tool: Google Sheets
Tabs:
• “Bills” with columns: Name, Due date, Amount, Auto-pay (Y/N), Paid?
• Filter by month
Takes 10 minutes to set up. Zero learning curve.
- Savings goals
Goal: see progress fast, avoid mental math.
Use an online bank with “sub-accounts” or “buckets”
Examples: Ally, Capital One 360, SoFi, etc.
Set up one bucket per goal: “Emergency”, “Vacation”, “New Laptop”
Then:
• Auto transfer every payday
• Name each bucket with target amount, like “Vacation 2025 1500”
You check one screen and see progress for each goal.
If your current bank has buckets, use that. If not, open a separate savings account only for goals and track the breakdown in a simple sheet with 3 columns: Goal, Target, Current.
- Shared expenses
Goal: stop arguing, make math obvious.
Best option: Splitwise
Why it works
• You enter each shared cost and pick who owes what percent
• It keeps a running total of who owes who
• You settle once a month with a single payment
Set a rule with your partner or roommate
• Groceries 50/50
• Rent fixed split
• Utilities fixed split
• Dining out, add only over X dollars to avoid clutter
Alternative if you want total simplicity
• One shared credit card for all shared stuff
• At month end, download the statement
• Divide by your agreed ratio
• One person pays the card, the other sends their share
This keeps all shared costs in one place.
- All in one budget app
You said apps felt too complex or too basic.
Three that tend to click for different brains:
YNAB (You Need A Budget)
• Best if you like rules and envelopes
• Strong for planning every dollar
• Steeper learning curve, but solid once set
• Great for combo of bills, goals, and shared if you both commit
Simplifi by Quicken
• Good if you want automation and clean visuals
• Tracks bills, savings targets, and spending plans
• Lighter than full Quicken, more structured than free apps
EveryDollar (free version)
• Zero based budget with simple categories
• Manual entry unless you pay
• Good if you want control and no noise
If you feel overwhelmed, try this setup for 2 months:
• Calendar for bills
• Online savings buckets for goals
• Splitwise for shared
• No “full” budget app at first
If that works and feels stable, then move to one integrated app like YNAB or Simplifi. Import your categories and habits there. If it feels annoying after a week, drop it and go back to the simple stack above.
Key tip
Any tool works if
• You check it at the same time every day
• You do a 15 minute “money check” once a week
The routine matters more than the software.
I got stuck in the same loop of “this app is too dumb / this app is too much like a part-time job.” I like @waldgeist’s breakdown by use case, but I’ll go a slightly different route: instead of 3+ tools, try to find one “good enough” setup and lower your standards a bit on perfection.
Here’s what worked for me after burning through like 8 apps:
1. Start from your brain type, not the feature list
Roughly:
- If you like lists and checkboxes → pick a category-based app.
- If you think in numbers & tables → pick a spreadsheet or a minimalistic tracker.
- If you think in timelines → use something calendar-ish and ignore the rest.
You sound like you get overwhelmed by knobs & toggles, so I’d avoid YNAB-level complexity at first, even though it’s powerful.
2. One simple tool that handles all 3: my short list
All of these can track monthly bills, savings goals, and shared stuff without you needing three systems.
Option A: Monarch Money
- Handles: bills, cash flow, savings goals, and basic shared budgeting.
- Why it works for overwhelmed people:
- Clean interface with “Plans” for goals and “Recurring” for bills.
- You can invite a partner so you both see the same dashboard instead of juggling Splitwise + spreadsheets.
- Weak spot: subscription cost, and if you hate connecting bank accounts, it loses its magic.
Option B: Spendee (with a shared wallet)
- Set up:
- One “wallet” for all household stuff (rent, utilities, groceries).
- One “wallet” just for you if you want to track personal spending.
- Categories for bills, goals (e.g. “Savings – Emergency”), fun, etc.
- Benefits:
- Shared wallet works decently for couples/roommates.
- You can keep goals as categories and just watch totals per month.
- Weak spot: goals are not crazy detailed, but that’s kind of the point. Fewer knobs to touch.
Option C: Minimal spreadsheet + one tracking app
Here I kind of disagree with @waldgeist on splitting everything into 3 different tools. For some people that’s ideal, but I found it made me check nothing because it felt scattered.
Instead:
- One Google Sheet with only 3 tabs:
- “Bills overview”
- Columns: Bill, Amount, Due date, Account it’s paid from.
- “Goals”
- Goal, Target, Current, Monthly contribution.
- “Summary”
- Monthly income minus:
- Total bills
- Total planned savings
- Flex spending
- “Bills overview”
- Then use any cheap / free tracking app (like Money Lover, Spendee free, or PocketGuard) just for daily transactions. Don’t let it manage goals or bills; the sheet does that.
So the app is basically your receipt log, and the sheet is your brain.
3. Monthly bills: keep this stupid simple
Instead of separate “bill” apps, use:
- One “Bills” section / view inside your chosen app, or
- One small area in your spreadsheet where you plug:
- Paycheck dates
- Bill due dates
- Auto-pay or not
Key rule: if a bill is auto-pay and fixed, you honestly do not need to interact with it every week. Just make sure it fits in the monthly plan.
If you try to micro-manage every bill in three tools, you’ll bail in 2 weeks. Ask me how I know.
4. Savings goals that don’t require a second career
You do not need perfect bucket features. You just need clarity. Two workable paths:
If your bank has sub-accounts:
- One account per goal, auto-transfer on payday.
- In your app or sheet, list the goals with target & deadline.
If your bank stinks:
- One high-yield savings account called “Goals”
- Spreadsheet:
- Emergency – Target 3000 / Current 1400
- Travel – Target 1500 / Current 300
- When you add money, split it virtually in the sheet, not in the bank.
The important part: you can see “I’m 40% to Emergency, 20% to Travel,” not the exact penny-perfect breakdown.
5. Shared expenses without a PhD
Since @waldgeist already suggested Splitwise and shared cards, I’ll throw one more option:
Shared pot with fixed monthly transfer
- Open one joint account or one shared card.
- Both of you send a fixed amount on the 1st (say 1,000 each).
- All shared stuff comes from that single place.
- At the end of the month:
- If money is left → rolls to next month or goes to shared savings.
- If it runs short → raise the amount for next month instead of Venmo’ing back and forth.
No constant math, no “who owes who” debates. You’re either both overfunding or underfunding the pot, and you adjust together.
6. How to actually pick one without testing 20 apps
Try this 30-minute process:
Decide:
- “I want automation” → pick Monarch or something similar.
- “I want control, not auto imports” → pick Spendee with manual entry + your bank app.
Set a timebox:
- You’re going to try one setup for 30 days. No switching, no “just checking” other apps.
Define success before you start:
- “I can answer these 3 questions any Friday in under 5 minutes:”
- What bills are due in the next 2 weeks?
- How much have I added to savings this month?
- How much is left for fun spending?
Whichever tool lets you answer those without anxiety is the “best” one for you, even if some YouTube finance person says another app is objectively superior.
If you want, drop what you’ve already tried and what specifically annoyed you (too manual, too many categories, connection bugs, etc.), and I can be brutally honest about which ones to avoid next so you don’t keep speedrunning the app store.
Skip the hunt for “perfect” budgeting software and solve the overwhelm problem first: your setup should survive a tired Sunday night, not just day-one enthusiasm.
You already got great, detailed systems from @sonhadordobosque and @waldgeist. I’ll go in a different direction: lean into constraints instead of features.
1. Pick your one “home base”
Instead of multiple tools, decide where your money truth lives:
- Option: one dedicated budgeting app
- Option: one spreadsheet + your bank apps
- Option: one joint account / card for shared, bank for the rest
Everything else is “reference.” If a bill isn’t reflected in your home base, it doesn’t exist.
I actually disagree slightly with the “stack multiple tools by use case” approach. It is elegant, but in practice, most people stop checking three places. You want one main dashboard you trust.
2. Ignore “budget apps” that try to do too much for you
A lot of free apps fail you because:
- They auto-categorize badly so you waste time fixing them
- They spam you with “insights” you did not want
- They hide the simple question: “What can I safely spend this week?”
Focus on apps that:
- Show a clear “available to spend” or “left this month”
- Treat recurring bills as just that: a recurring total to plan around
- Let you turn most “features” off
3. Single-app suggestions that fit your use case
You mentioned monthly bills, savings goals, and shared expenses. Instead of listing another dozen tools, I’d think in terms of “budget brain” types.
A. If you hate manual entry and want automation
Look for something like Monarch Money or similar all-in-one tools that:
- Aggregate accounts
- Show a clean cash flow calendar
- Have simple goal tracking
Pros:
- Great overview of everything in one place
- Good for couples if you want shared dashboards
- Bill & goal handling is visual
Cons:
- Subscription cost
- If bank connections are flaky in your country, it is frustrating
- Easy to end up “watching charts” instead of changing behavior
Competitors like what @sonhadordobosque mentioned (YNAB, Simplifi, EveryDollar) are solid, but they either lean into more rules (YNAB) or more structure than some people want. If that already felt like a part-time job, step back toward something cleaner.
B. If you prefer numbers and control
Here I’m closer to @waldgeist, but I’d compress it further:
- One Google Sheet as the master plan
- Your bank’s own app for real balances
- A very lightweight tracker if you like seeing categories
Sheet structure:
- Tab 1: Bills list with monthly total
- Tab 2: Savings goals with target, current, monthly plan
- Tab 3: A “plan vs actual” that is basically:
- Income
- Minus bills
- Minus savings
- Result is “guilt-free spending”
Then let any simple tracking app just dump transactions by “Bills / Needs / Wants” instead of 30 categories.
4. Shared expenses: choose a rule, not just a tool
You already saw Splitwise and shared-card options. They both work. What matters more is the rule you agree on.
I’d suggest one of these models:
Fixed shared pot
- Both pay a fixed amount into a joint account on payday
- All joint expenses come from there
- Review the pot once a month and adjust the contribution
“You own X, I own Y” split
- One person fully owns groceries and utilities
- The other owns rent and subscriptions
- You revisit once a year if it feels unfair
Pros of a shared pot / shared card model:
- Zero “who owes who” calculations each week
- Easy to see if lifestyle is creeping up
Cons:
- Requires trust and clear communication
- One person might feel less in control if you do not both watch it
5. Savings goals: avoid over-optimizing
You do not need a perfect “goals engine” with charts. You need:
- A visible list of goals
- Auto transfers where possible
- A quick view of “how far along am I”
Whether you use your bank’s buckets, a simple savings account plus spreadsheet, or goal features in something like Monarch or Simplifi, the key is: you see the numbers without hunting through menus.
6. How to stop bouncing between apps
Make a mini contract with yourself:
- Choose one setup today.
- Commit to 30 days, no switching.
- Weekly ritual: 15 minutes to
- Check next 2 weeks of bills
- Update savings numbers
- See how much is left for non-essentials
If at the end of 30 days you can answer, in under 5 minutes:
- What fixed bills hit between now and your next paycheck?
- How much did you add to savings this month?
- How much is safe to spend on non-essentials this week?
Then your setup “works,” even if some feature junkie on YouTube says another app has better graphs.
If you want to narrow choices further, list the last two or three apps you tried and precisely what annoyed you: too manual, too gamified, confusing categories, partner refused to use it, etc. That pattern is usually more revealing than the feature lists on any product page.
