I used to rely on the Mint budgeting app to track expenses, set budgets, and get alerts, but now that it’s gone I’m struggling to find a replacement that’s as simple and effective. I’m looking for a secure app that can link to multiple bank and credit accounts, categorize transactions automatically, and give clear budget insights without being overly complex or expensive. What apps are you using that feel closest to Mint, and what do you like or dislike about them?
I went through the same Mint death spiral, so here is what I landed on after way too much testing.
Short version
If you want closest to Mint with bank sync and alerts, look at Monarch or Copilot.
If you want control and privacy and do not mind some manual work, look at YNAB or a spreadsheet.
Here is a breakdown.
Monarch Money
• Very Mint like, but cleaner.
• Bank and card syncing, investments, loans, net worth.
• Budget by category, rollovers, alerts for large transactions and bill due dates.
• Web and mobile both solid.
• Subcription: around 8–10 USD per month if you pay yearly.
• Data lives on their servers, uses Plaid for connections.
Good if you want simple, automated, Mint style. -
Copilot Money
• iOS and Mac only, no Android, no web.
• Great auto categorization, learns from edits.
• Nice trends and cash flow charts.
• Good for people who mainly live on iPhone.
• Sub around 8–10 USD per month.
Feels fast and modern, but the Apple lock‑in is a big downside if you are cross‑platform. -
YNAB (You Need A Budget)
• Different mindset. You give every dollar a job.
• Strong for people who want to control spending and plan ahead.
• Sync with banks, but manual input still helps.
• Great for envelope style budgeting.
• Sub around 14 USD per month, cheaper yearly.
• Learning curve. Takes a week or two to click.
Best if you want to change behavior, not only see charts. -
Simplifi by Quicken
• Feels like “Mint 2.0” in some ways.
• Bank sync, goals, watchlists, alerts.
• Web and mobile apps.
• Sub around 3–5 USD per month with promos.
Quality is a bit hit or miss. Some people have sync bugs, others say it works fine. -
Tiller + Google Sheets or Excel
• No app. Everything in a sheet.
• Tiller fills your sheet every day with bank data.
• You build or copy a budgeting template.
• Privacy is decent, you can control sharing inside your Google account.
• Sub around 80 USD per year.
Best if you like spreadsheets and want full control. Worst if you hate spreadsheets.
If you care a lot about security and privacy
• Use strong unique passwords with a manager.
• Turn on 2FA for the budgeting app and your banks.
• Prefer providers that use Plaid or similar aggregators, not direct scraping with your bank login.
• Read their security page, look for SOC 2 and encryption details.
If you want something simple and effective that feels close to Mint, start this way:
• Step 1, trial Monarch for 7 days.
Connect 2–3 main accounts, set 5–10 core categories, turn on alerts.
If it feels natural in a week, you likely found your Mint replacement.
• Step 2, if Monarch feels heavy or pricey, try Simplifi for a month.
Compare sync reliability and alerts.
• Step 3, if you want more control and you are ok retraining your brain, do YNAB’s 34‑day trial and follow their quick start videos.
Expect the first few days to feel weird.
For my own setup, I use Monarch for automation and net worth tracking, and a simple Google Sheet for high level monthly goals.
That mix gave me Mint style simplicity plus more control without me spending hours every week.
I went through the Mint funeral too and tried half the internet, so I’ll add a slightly different angle to what @himmelsjager already wrote.
If your priorities are:
- simple like Mint
- strong alerts
- decent security
- not a full‑time hobby
here’s what I’d look at that hasn’t been covered as much:
1. Cube Money (envelope style with cards)
If you liked Mint’s budgets but always felt they were too “after the fact,” Cube is interesting.
- You get virtual “cubes” (envelopes) and a debit card.
- You fund cubes and spend from them in real time.
- Strong behavior change without YNAB’s learning curve.
Caveat: You have to be okay routing some spending through their card, which some people hate from a security/control standpoint.
2. Actual Budget (more private, lighter than YNAB)
- Envelope style, but simpler UI than YNAB.
- Sync is optional; you can keep it mostly offline and enter stuff manually or import.
- Good if you’re anxious about giving yet another aggregator access.
Downside: Less automation than Mint, so it’s more “hands on.” If you want set‑and‑forget with alerts, this might feel like work.
3. PocketGuard (for “how much can I spend?” people)
Mint was great at saying “here’s what you actually have left.” PocketGuard leans hard into that.
- Focuses on “safe to spend” after bills and goals.
- Connects to accounts, auto tracks like Mint.
- Their free tier is usable, paid unlocks full categories and exports.
Security is similar to the others (aggregators, encryption, etc.), but check that your specific banks play nice, because some folks report spotty connections.
4. Split solution: alerts app + light budgeting
This is where I kinda disagree with @himmelsjager. You do not have to cram everything into one tool.
A combo that works weirdly well:
Use your bank’s own alerts plus a generic notifications tool for:
- big transactions
- low balance
- card‑not‑present purchases
Then use a lighter budgeting app just for categories & trends:
- For example, PocketGuard or even a manual Google Sheet / Excel template.
- You can automate imports with a once‑a‑month CSV instead of constant syncing.
Result:
- Alerts hit instantly from the source (bank)
- Your budget tool has “cleaner” data, and you are not relying 100% on some aggregator that breaks every time your bank changes its login flow.
Security thoughts specific to your concern
Everyone says “we use Plaid and encryption” but that does not help choose. I’d actually do this:
- Check if the app offers:
- read‑only connections
- ability to delete all data quickly from settings
- Google
appname data breachand see if anything nasty pops up. - In your bank settings, see if they show a list of connected third parties and whether you can revoke access per app.
Plaid and similar are fine, but the real power move is: once you have your accounts connected and stable, lock down your bank logins with a password manager and app‑based 2FA and stop logging in from random devices.
If you want something close to Mint’s “feel” without copying @himmelsjager’s exact flow
Try this order:
PocketGuard for 1–2 weeks
- Focus on “safe to spend” and simple categories
- Turn on all alerts and see if they’re actually useful or just noise
If you hate the UI or the ads/upsell vibe:
- Actual Budget if you lean privacy/low‑sync
- Cube Money if you want hard guardrails at the point of purchase
If none of those click, then yeah, Monarch / Copilot / YNAB are the “big three” and worth trying, but I’d start smaller and see how much automation you truly need vs how much Mint nostalgia is coloring it.
TL;DR:
You probably want a combo of:
- bank‑level alerts for security
- a lightweight app like PocketGuard or Actual Budget for the Mint‑style overview
instead of hunting for a single “Mint clone” that doesn’t really exist anymore.
You already got solid coverage of the “big names” from @suenodelbosque and @himmelsjager, so I’ll hit a different angle: how to choose, and what tradeoffs you’re actually making post‑Mint.
1. Start by deciding how much automation you really want
Mint made it feel like “automatic or bust,” but that came with messy categories and flaky sync. Before picking a Mint‑style budgeting app alternative, answer:
- Do you need every account synced daily, or are 2–3 main ones enough?
- Are alerts for fraud/security your priority, or budgeting discipline?
- Are you okay paying more for something you only log into a few times a week?
If you want near‑Mint automation with less chaos, Monarch and Copilot (as mentioned) are the obvious plays. Where I slightly disagree with them: I think most people overrate full aggregation and underrate the mental clarity of tracking just checking + primary card.
2. Use banks for security alerts, apps for insights
Instead of forcing your Mint replacement to be a security system:
- Turn on every relevant alert inside your bank and card portals
Large purchases, foreign transactions, card‑not‑present, low balance, failed login. - Then pick a budgeting tool mainly for:
- category trends
- cash flow view
- budget vs actual
Result: fewer missed fraud alerts, less reliance on Plaid/the aggregator layer.
3. Pros & cons mindset for a Mint‑style budgeting app alternative
Since you mentioned “simple and effective,” here is how to think about an unnamed Mint‑style budgeting app alternative in general:
- Automatic transaction import from banks and cards
- Auto‑categorization that improves over time
- Budget by category with rollovers and alerts
- Net worth view across accounts
- Mobile app so you can check spending quickly
- Data lives on a third‑party server
- Breakage risk when banks change login flows
- Paywall for “power features” like custom categories or exports
- Can tempt you to “set and forget” instead of actually reviewing
If privacy and security make you uneasy, you might be closer to the “YNAB or spreadsheet” camp than you think, even if it sounds like more work up front.
4. How I’d test in your position
Instead of cycling through endless trials, do a structured 1‑month experiment:
Week 1–2: One automated Mint‑style app
- Connect only your primary checking and main credit card.
- Create a small category list: Housing, Food, Transport, Utilities, Fun, Misc.
- Enable only 3 alerts: large transaction, low balance, budget overage.
Goal: see if the automation actually helps decision making or just looks pretty.
Week 3–4: Semi‑manual backup plan
Parallel to that, keep a dead‑simple spreadsheet or manual app for just 3 things:
- Income per month
- Total spent per month
- Amount moved to savings or debt
By the end of the month, compare stress level and clarity between the automated view and the minimal manual summary. Whichever one actually changed your behavior is what you should lean into.
5. Where I slightly diverge from @suenodelbosque and @himmelsjager
- They both lean into trying multiple full‑stack tools. I think that easily becomes “app tourism.”
- I’d lock into one Mint‑style budgeting app alternative and one manual backup tool, then stop experimenting for 60–90 days.
The real win you lost with Mint was not features, it was having a single, consistent place you checked money. Rebuilding that habit matters more than which logo is on the login screen.
