Need help choosing the right personal finance apps
I’m trying to get better at budgeting and tracking my spending, but I’m overwhelmed by all the personal finance apps out there. I’ve tried a couple, but they either feel too complicated or don’t sync well with my bank accounts. Can anyone recommend reliable, easy-to-use personal finance apps that are good for budgeting, saving goals, and tracking subscriptions, and explain why you like them?
I went through this same mess last year. Here is what ended up working and what did not.
  1. If you want simple auto tracking
    Use: Mint replacement type apps
    Examples
    • Monarch Money
    • Copilot Money (iOS only)
• Auto sync with banks and cards
• Auto categories that you tweak over time
• Clean budget view by month
• Bank sync breaks sometimes for a day or two
• Subscription cost, usually 5 to 15 per month
Best use
Set up all accounts.
Spend one hour fixing categories for the last 1 or 2 months.
Then each week spend 10 minutes recategorizing new stuff.
Do not chase perfect categories. Aim for 10 to 15 total.
  1. If you want strict budgeting and control
    Use: Envelope or zero based style
    • You Need A Budget (YNAB)
    • EveryDollar
• Forces you to tell your money where to go
• Great if you want to stop overspending fast
• Learning curve
• Feels annoying at first
• Manual thinking even with sync
Best use
Start with only checking + main credit card.
Ignore savings accounts in the app for the first month.
Do a “money date” once a week to assign every dollar that is not assigned.
  1. If you want manual input and less syncing drama
    Use
    • Spendee
    • Spending Tracker
    • Simple spreadsheet in Google Sheets
• No sync issues
• Makes you more aware of each purchase
• Takes time every day
• Easy to quit if you get tired
Best use
Track only variable spending.
Ignore bills that are the same each month.
Log once per day for 3 minutes, not in real time.
  1. What I do now
    • Copilot Money for auto tracking and net worth
    • YNAB for planning and behavior
    • One Google Sheet for high level goals
  2. How to pick for you
    If you want “set it and mostly forget it”
    Start with Monarch or Copilot.
If you want behavior change and strict control
Start with YNAB and commit to 30 days.
If you feel overwhelmed by apps
Start with a Google Sheet.
Columns: Date, Store, Category, Amount, Need/Want.
Do this for one month, then move to an app if you still feel motivated.
  1. Quick setup rules that help a lot
    • Use broad categories: Housing, Food at home, Eating out, Transport, Shopping, Subscriptions, Fun, Other
    • Turn off most app notifications except low balance or big purchase alerts
    • Set one weekly reminder to review spending
    • Ignore “net worth” for the first 2 or 3 months, focus on spending only
If you share more info, like Android vs iOS, number of accounts, and whether you hate subscriptions, people here can point you to something more specific.
I’m gonna slightly disagree with @sognonotturno on one thing: I don’t think the first decision is “which app,” I think it’s “how much brainpower do you actually want to spend on this every week.”
The sync issues and overwhelm you mentioned are usually symptoms of trying to use a tool that expects more attention than you really want to give it.
Here’s a different way to slice it that might help:
Step 1: Pick your “effort level”
Be honest with yourself:
  1. 5 minutes per week max
    • You just want to see where money goes, not micromanage.
    • Best fit: “Automatic tracking, light budgeting.”
  2. 15–30 minutes per week
    • You’re willing to tweak, review, and adjust.
    • Best fit: “Behavior change & planning.”
  3. You like messing with numbers
    • You don’t mind manual entry and custom views.
    • Best fit: “Spreadsheet / hybrid setup.”
Once you pick the effort level, the “right” app usually becomes obvious.
Step 2: Match specific tools to your situation
I’ll skip repeating Monarch / Copilot / YNAB / EveryDollar since @sognonotturno already covered those well. Here are some alternatives and different angles:
A. If bank sync is your pain point
You already said sync has been flaky. In that case:
  • Simplifi by Quicken
    • Solid middle ground between Mint-style and full-on YNAB.
    • Sync is not perfect (none are), but tends to be a bit more stable than some smaller apps.
    • Good “spending plan” view without forcing hardcore zero based rules.
  • Tiller + Bank’s own app
    • Tiller pulls data into Google Sheets or Excel automatically.
    • It’s not pretty out of the box, but extremely flexible.
    • Use your bank’s own app for quick balance checks, Tiller for trends and monthly totals.
This combo avoids a lot of the “my app thinks I’m broke” sync bugs, because you can directly see and fix weird imports in the sheet.
B. If apps feel too complicated
Instead of “find the perfect app,” try this constraint:
“If I can’t understand it in 20 minutes, I delete it.”
Then try this progression:
  1. Start with your bank’s built in tools
    • A lot of banks now have automatic categorization and simple charts.
    • Not amazing, but dead simple and no extra logins.
    • Use it for 1 month just to SEE: groceries vs eating out vs shopping.
  2. Then add one simple layer
    • Example: Use PocketGuard or Emma just for “how much can I safely spend” this week.
    • Don’t touch goals, investments, or net worth features at first.
You can always “graduate” to something like YNAB later if you decide you want more control.
C. If you want budgeting without living in the app
YNAB style is great, but some people bounce off it hard. An in‑between option:
  • Use a “macro budget” + one enforcement tool
    • Example:
      • Decide: “I get $X per month for non-essentials.”
      • Move that amount into a separate checking account or prepaid debit card.
      • Use any simple tracker (even your phone notes app) just for that card/account.
    • The account becomes the budget, not the app.
This avoids category obsession but still controls spending.
Step 3: Make syncing less painful no matter what you use
A lot of overwhelm comes from trying to be too perfect. Quick rules that help:
  • Connect only 1–2 main accounts at first
    Checking + main credit card. Ignore savings, investments, retirement, etc.
  • Turn off 90% of notifications
    Keep only: low balance alert and big transaction alerts.
  • Accept that “yesterday’s numbers” are fine
    If the balance is off by a day, that’s normal, not a failure.
  • Give yourself a 2 week “messy” trial period
    Expect wrong categories, duplicates, weird stuff. Just use that time to learn how the app behaves.
Concrete suggestion based on what you wrote
Given:
  • You feel overwhelmed by apps
  • Sync has already annoyed you
  • You do want better tracking & budgeting, not just vibes
I’d test this path:
  1. Month 1: Super lightweight
    • Use your bank’s app categories + a tiny manual log:
      • Note app / Google Keep:
        • “Groceries: $xx, Eating out: $xx, Random: $xx” once per week.
    • Objective: Just get awareness.
  2. Month 2: Add a single app focused on spending
    • Try:
      • Simplifi if you want more automation.
      • Spendee or Money Lover if you’re ok entering stuff manually.
    • Ignore goals, net worth, and all the fancy graphs at first.
  3. Month 3: Decide if you want stricter control
    • If you feel like “ok, I know where my money goes, now I want to change it,” then try YNAB for 30 days like @sognonotturno suggested.
    • If not, just stick with the simpler setup and refine categories.
If you reply with:
  • iOS or Android
  • Country (because bank connections vary a lot)
  • Roughly how many accounts you have
it’s possible to narrow this to 1 or 2 specific apps instead of “here’s a buffet, pick one and cry later.”
