Need help coming up with fresh narrative ideas
I’m stuck trying to develop new narrative ideas for a writing project and everything I draft feels repetitive or flat. I’ve tried brainstorming, outlining, and freewriting, but none of it is clicking into a compelling story arc. Can anyone share practical tips, prompts, or frameworks that actually help generate original, engaging narrative concepts that are strong enough to build a full story around
You are not blocked on ideas. You are blocked on inputs.
Right now your brain keeps recycling the same stuff, so your drafts feel flat. You need new fuel, not more effort.
Concrete things to try:
  1. Change the source, not the method
    You tried brainstorming, outlining, freewriting. Those are all process tweaks. Shift what you feed your brain.
• Read 3 things outside your usual genre.
Example mix: one memoir, one crime short story, one weird sci fi flash piece.
Take one thing from each and twist it: a structure, a tone, or a type of scene.
• Watch or read a plot summary of a movie you have never seen.
Steal the structure, throw away the setting and characters, then rewrite in a totally different context.
  1. Force constraints
    No open “write whatever” sessions. Constraints reduce the noise.
Try these:
• Only 2 characters. One location. Real time. No time jumps.
Write a scene where one wants something simple, the other refuses for a specific reason.
• Pick a random job from a list. Pick a random problem from another list.
Example: “elevator mechanic” + “witnessed something they should not”.
Your story must center on that tension.
• Use a “rule of 3”:
Character wants X.
If they fail, Y happens.
If they succeed, Z happens.
Write those as one sentence each before you start.
  1. Steal narrative engines, not plots
    You do not need ideas, you need engines that produce scenes.
Common engines that work:
• Secret: Someone hides something important. Someone else gets close to finding it.
• Deadline: Something bad happens in 24 hours if nothing changes.
• Mismatch: Character thinks they are one thing, world treats them as something else.
• Power shift: One person has power at the start of the scene. By the end, the other person has it.
Pick one engine and apply it to whatever draft you hate most.
Rewrite only one scene through that engine.
  1. Use data from your own drafts
    Take 5 old pieces. Do a quick tally.
For each, note:
• POV used
• Setting type (modern city, small town, fantasy castle, etc)
• Central relationship (romantic, rival, family, stranger, etc)
• Type of tension (physical danger, emotional conflict, mystery, etc)
You will see patterns.
Example outcome: “I always write first person in modern settings about romantic tension”.
Then do the opposite on purpose: third person, historical or future setting, no romance allowed.
  1. Separate “idea generation” from “quality judgment” by time
    If you judge while ideating, your brain stalls.
Try:
• Day 1: Generate 30 “story seeds”. One sentence each. No filtering. Timebox to 20 minutes.
Use formats like:
“X must do Y, but Z.”
Example: “A sleep tech must fake dream data for a politician, but the machine starts showing their own childhood.”
• Day 3: Revisit the list. Circle only the ones that cause a specific image or line in your head. Do not pick what seems smart. Pick what makes your brain start adding details without effort.
  1. Use remix formulas
    If blank page is killing you, use a simple formula.
Some options:
• “X story in Y setting.”
“Office comedy in a space station.”
“Courtroom drama inside a family WhatsApp chat.”
• “Take a myth or fairy tale, remove the magic, keep the structure.”
e.g. Little Red Riding Hood as a corporate whistleblower story. Hood is the intern. Wolf is the department head.
  1. Set a low bar “pilot episode”
    Do not try to birth a whole novel. Aim for a 1500 word “pilot” that proves:
• Who wants what
• What stands in their way
• What kind of situation repeats and creates episodes
If reading the pilot makes you see 3 more potential episodes, keep it. If it feels like a dead end, dump it and move to the next seed.
  1. Change where you physically ideate
    Your brain links locations with tasks. If you always draft in the same spot, the same mental patterns fire.
Try:
• Idea list at a cafe or on a walk with a notes app.
• Structural thinking at a desk with no internet.
• Line edits at home.
Small change, but studies on context dependent memory suggest it affects recall and pattern use in your thinking.
  1. Use “problem first” thinking
    Instead of “I need a fresh narrative idea”, phrase it as:
“I want a story that lets me explore X problem through Y tone.”
Examples:
• “Explore envy through dark comedy.”
• “Explore burnout through a thriller.”
That gives you a tighter search area.
  1. Set a quota, not a goal of “one good idea”
    Pick a number like “15 bad ideas a week”.
    You hit the quota, you are done, whether you like them or not.
Over a month you get 60 seeds. You only need one to click. The odds improve fast once you stop waiting for the single perfect thing.
Last thing. Feeling flat often tracks with low input in life. If your days are all the same, stories will echo that. Even small changes help. New route, new hobby for a month, short volunteer thing. More input, more material for your brain to remix.
You’re not actually out of ideas, you’re out of energy for the ones you already have.
@kakeru is right about inputs, but I’d push a bit: changing inputs alone often just gives you more stuff to feel blocked about. You also have to change how much weight you’re putting on each idea.
A few different angles:
  1. Stop trying to invent, start trying to notice
    Most “fresh” concepts are just people noticing something specific and uncomfortable.
Instead of: “What’s a cool premise?”
Try: “What’s something that keeps bothering me that I never say out loud?”
Write 10 answers. Each becomes:
“Character who believes X, in a world that demands the opposite.”
That’s already a narrative engine.
  1. Use your own boredom as data
    Take one of your “flat” drafts and autopsy it:
  • Highlight all the parts you skim while rereading. Those are places you don’t actually care.
  • Put a star by any sentence or line where you go “ok that’s not terrible.”
Keep only the starred parts. Throw away everything else.
Now ask: “What kind of moment is this?” Confession? Threat? Joke? Collapse?
Build a new story that is basically 80% that kind of moment.
  1. Write something you’d be slightly ashamed to show people
    A lot of “flatness” is you sanding off anything that feels too weird, horny, angry, childish, whatever. Your internal censor is very “professional,” your ideas are not.
Prompt yourself with:
“I want to write a story that would mildly horrify [specific person you know].”
Not in an edgelord way, just: what would make them go “…why would you write that?”
Draft 500 words of that and don’t aim to make it good. Make it too much.
  1. Narrow the target to something tiny
    Instead of “new narrative idea,” try:
  • “A story that is basically one long awkward apology”
  • “A story where every scene has food in it”
  • “A story where no one answers a direct question honestly”
Those aren’t plots, they’re filters. Run any half-baked premise through one of those and it changes shape.
  1. Steal from structure you hate
    You probly already steal from stuff you like. Flip it.
Grab a book, show, or trope you roll your eyes at. Ask:
“What is ONE thing they do structurally that I avoid?”
Maybe it’s:
  • Super on-the-nose internal monologue
  • Big melodramatic confrontation
  • A twist that re-frames everything
Force yourself to use that thing once, but in your own voice. The clash between your taste and that structure often spits out something odd and alive.
  1. Let the idea be “small” on purpose
    You might be trying to birth a 300-page-worthy premise. Lower the bar:
Write something that ONLY aims to:
  • capture the feeling of being stuck at work at 4:48 PM
  • show two people who love each other but are absolutely done talking
  • portray someone trying to impress a person who is barely paying attention
If a small emotional slice feels true, it’s more compelling than a big “cinematic” premise you don’t actually care about.
  1. Use contradiction as a generator
    Freshness often lives in collision.
Write a list of 5 “I am…” statements about yourself and 5 “I am not…” statements.
Example:
I am patient / I am not confrontational / I am ambitious / etc.
Pick one from each side and give them to a character together: “I am ambitious and I am not confrontational.”
Ask: “In what situation would that combination absolutely fail?”
There’s your story.
Final thing: stop trying to feel “excited” at the idea stage. Treat ideas like clay, not like finished sculptures. Measure them only by: “Can I see one interesting conflict here?” If yes, write 1 page, not a whole outline. If no, ditch without ceremony. The drama is in the work, not in the lightning bolt.
Skip the “fresh idea” hunt for a second and look at the shape of what you are trying to make. Right now you are tweaking inputs (like @kakeru says) and engines (like @cazadordeestrellas lays out), which is useful, but both still start from: “I need a concept.” I would flip that.
Think in patterns of movement, not in plots or themes.
1. Start from motion, not premise
Ask only: “What is the primary motion of this piece?”
Examples:
  • Drifting apart
  • Spiraling deeper
  • Climbing toward a reveal
  • Circling the same argument, each time slightly worse
Pick one, then force every beat of the draft to obey that motion. If you pick “spiraling,” each scene must be some version of “same problem, higher stakes / less control.” Once you commit to a motion, even a cliché premise stops feeling flat, because the reader feels pulled.
This is where a lot of “blocked on ideas” actually lives. The premise is fine; the motion is mush.
2. Abandon novelty, chase intensity
You might be overvaluing originality. A lot of very “fresh feeling” stories are built on incredibly old ideas, they just commit harder.
So instead of “new narrative idea,” try:
“Take a basic situation and push it two steps further than I am comfortable.”
Example: “ex wants closure conversation in a café.” Old as dirt. Push it:
  • They are both wearing mics for a dating podcast
  • One of them has exactly 20 minutes before their wedding ceremony
    You did not invent a new genre. You just increased intensity in a specific, visual way.
3. Reverse engineer from one formal trick
Steal not a trope, not a vibe, but a formal decision. One per draft.
Stuff like:
  • Dialogue only, no tags, no description
  • Every paragraph starts with “Today I learned…”
  • The story moves backward in time, but the character does not know it
  • Scene breaks only when someone lies
Pick one constraint that affects the format on the page. Do not worry if it is “marketable.” This tends to short circuit the “I’ve done this before” feeling, because you literally have not used that shape yet.
4. Diagnose why your drafts feel repetitive
Not feelings, patterns. Grab 3 of your “meh” pieces and ask:
  • Where do I always start? Waking up, traveling somewhere, in-dialogue, in-action?
  • Where do I always end? Epiphany, loss, ambiguous open door?
  • How long do I hover before the first clear conflict appears?
Then deliberately break your own habits:
  • If you always start quiet and build, begin in the loudest possible moment and write only the aftermath.
  • If you always end with a soft fade, end on a hard, unresolved decision.
You do not need new ideas if you stop ending them the same way.
5. Use “structural theft” instead of “idea mining”
Find a story or episode outline you respect structurally but do not care about thematically. Ignore the genre. Boil it down to beats:
  1. Character resists change
  2. External pressure increases
  3. Character tries a bad workaround
  4. Workaround blows up
  5. Forced choice
Now replace every beat with a totally different surface situation, but keep the sequence and timing. Your brain stops panicking about invention, because the skeleton is there. You can be weird in the details.
6. Let yourself write one ugly draft whose only goal is “surprise myself once”
Set a tiny target:
  • 1000 words
  • At least once, you must write something that makes you go, “Wait, am I allowed to do that?”
Does not have to be sex or gore or edginess. It might be:
  • Breaking POV for one shocking sentence
  • Having a character say what you never let them say
  • Jump cutting across decades mid scene with no warning
Do not outline this piece. Give it 90 minutes, then stop. The point is to retrain the part of you that expects every idea to be tidy.
Where I disagree a bit with them
  • @kakeru leans heavy on “more / different inputs,” which works once you already have a handle on your own patterns. If you do not, more input just feeds the same groove. So I would first map your defaults before you flood yourself with new stuff.
  • @cazadordeestrellas puts good weight on “what bothers you,” which I like, but if your internal voice is currently numbed out, that question can feel blank. In that case, starting from motion or format is easier than starting from emotion.
Last thing: stop aiming for a capital-I “Idea.” Treat each piece like a lab test of one variable. “Today I test: backward structure.” “Today I test: only escalation, no resolution.” Stack enough of those experiments and something will suddenly feel like a project, not a prompt.
