My Canva app on both desktop and mobile has started glitching and crashing whenever I try to edit or export designs. I’ve already logged out, reinstalled the app, and cleared cache, but the problems keep happening and I’m worried I’ll lose client work. Can someone explain what might be causing this and what else I can try to fix the Canva app issues quickly?
Had the same Canva chaos a few weeks ago. Desktop and mobile both crashing on edits and exports, even after reinstall and cache clear. Here is what fixed it for me and what support suggested.
Check Canva status first
Search “Canva status page” and see if they list outages or degraded performance. When export kept failing, their status page showed rendering issues for some regions. -
Test in browser vs app
Open Canva in Chrome or Edge instead of the desktop app.
Log in, then try:
• Incognito window
• Different browser
If browser works and app fails, issue is with the app install or OS environment. If both fail, it is your account, design, or their servers. -
Turn off hardware acceleration
Desktop app uses the same engine as Chrome. GPU issues cause crashes.
In Chrome:
• Settings > System > turn off “Use hardware acceleration when available”
• Relaunch
For the Canva desktop app:
• Close the app
• Right click shortcut > Properties > in Target field, add a space then “–disable-gpu” at the end
Example:
‘C:\Users\You\AppData\Local\Programs\Canva\Canva.exe’ –disable-gpu
Then open Canva again and test.
If it stops crashing, your GPU or driver is the problem. -
Update graphics drivers and OS
On Windows:
• Windows Update
• Then update GPU driver from Nvidia, AMD, or Intel app
On macOS:
• Update macOS
Older drivers caused export crashes for a lot of users when designs had video or animations. -
Check design size and content
Huge designs with lots of elements or videos break exports. Try this:
• Open a small blank design, like 1080x1080, add 1 shape, export as PNG or MP4- If this works, your problem design is too heavy or corrupt
• In the broken design, duplicate it and delete half the pages, then try export
• Export as PDF instead of PNG/MP4 and see if it works
If smaller or split designs export, you hit a resource limit.
Clear app data deeper than cache
You said you cleared cache, but try full data reset.
Desktop:
• Log out of Canva
• Close app
• Delete Canva folder in:
- Windows: C:\Users[you]\AppData\Roaming\Canva and \AppData\Local\Canva
- Mac: ~/Library/Application Support/Canva
• Reinstall from Canva site, not Microsoft Store
Mobile:
• Delete app
• Restart phone
• Reinstall
Then log in and test a small design.
Disable extensions and overlays
If you use browser:
• Turn off ad blockers, script blockers, grammar tools for canva.com
• Try in a clean Chrome profile
On desktop:
• Disable screen overlay tools like MSI Afterburner, Discord overlay, Xbox Game Bar
They often crash GPU-accelerated apps. -
Check network and export location
Exports sometimes hang or crash with unstable network.
• Switch Wi‑Fi to mobile hotspot and test
• Use a different network if possible
If export completes but download fails, it is network.
On mobile, also check you have storage free. -
Log out of extra devices
Canva Pro shared accounts sometimes glitch when the same account is active on several devices.
Log out everywhere, then only log in on one device and test. -
Contact Canva support with data
If none of that helps, collect:
• Device model and OS version
• App version on desktop and mobile
• Browser and version if you tested
• Exact steps before crash
• Screen recording if possible
Then send it to Canva via their Help > Report a problem. Their support once told me they flagged my account for a corrupted brand kit and fixed it on their end, crashes stopped right away.
For a quick test path, I would do this order:
- Test in browser incognito
- Disable hardware acceleration or use the “–disable-gpu” flag
- Try a blank small design export
- Reinstall after deleting config folders
That should narrow if it is device, account, or a single messy design.
Had almost this exact Canva meltdown a couple months ago: desktop & phone both freaking out on any edit/export, even after all the “standard” fixes. @caminantenocturno already covered a ton of stuff, so I’ll skip all the GPU flags and browser/incognito gymnastics and focus on the other weird causes I ran into.
What actually ended up mattering for me:
- Account‑level weirdness
My issues followed me across every device and browser. That usually screams “account problem,” not install or hardware.
Quick check:
- Log into a different Canva account on the same devices (even a fresh free account).
- Open a blank template and try a quick export.
If the other account works fine on the same device, your profile, brand kit, or some asset in your account is corrupt. I know support is a pain, but in my case they literally had to “repair” my account on their end.
- Brand kit & uploads as the hidden villains
Canva support admitted to me that busted fonts or images in Brand Kit can crash edit/export silently. What finally fixed mine:
- Temporarily switch to designs that do not use Brand Kit (no branded fonts, no brand colors).
- Create a new test brand kit with just 1 system font and 1 color.
- Avoid any uploaded fonts for a bit.
Also check your Uploads tab. I had one corrupted PNG: any design that used it would crash on export. Removing that file and re-uploading a fresh version stopped a lot of chaos.
- Fonts causing random crashes
This one felt fake until it worked:
- Remove any recent custom fonts you added just before problems started.
- Re-open Canva and replace those fonts in one broken design with a default Canva font.
- Try to export that design.
If it exports, the font file is bad. It might still preview okay and only blow up when rendering.
- Animations & page transitions
I disagree slightly with @caminantenocturno on only “design size” being the main issue. In my case, the design wasn’t huge, but:
- A few pages with page transitions + multiple animated elements would crash export every time.
Try this: - Duplicate the problem design.
- Remove all page transitions and most element animations.
- Export as MP4.
If that works, re-add animations slowly. One of them might be the trigger.
- Audio & video format issues
If your design has audio or video:
- Remove the audio track, export again.
- Replace any videos you screen‑recorded on phone with exported MP4 from a converter. Some phone formats made Canva choke for me.
Also try exporting as GIF or PDF. If those work but MP4 fails, it’s usually audio/video codec related.
- Folder & asset overload
Super random, but my account had thousands of items in a couple folders and I noticed Canva became glitchy only when those assets were used:
- Move some older assets out of your “main” folders.
- Make a new folder, copy only the essential graphics you need, and rebuild a smaller test design with just those.
The UI became more stable as soon as I reduced the clutter.
- Mobile specific: background processes & storage
You already reinstalled and cleared cache, but two extra bits helped me:
- On mobile, force stop every heavy app (TikTok, IG, games, etc) before editing/exporting in Canva. It’s a RAM hog.
- Make sure you’ve got at least 3–5 GB free space, not just a few hundred MB. On my phone, exports “crashed” at 90% when storage was nearly full.
- Kill sync conflicts
If you tend to have the same design open on desktop and phone at the same time, try this:
- Close Canva completely everywhere.
- Open it on only one device.
- Open a copy of the design (use “Make a copy” first), work on the copy, and export.
I had some cursed versioning issue that only disappeared once I worked on a clean copy in a single session.
- What to send support so they don’t waste your time
If it’s still glitchy, contact Canva but give them things they can’t easily ignore:
- Link(s) to 1–2 specific designs that always crash.
- Explicit note if another account works on the same device.
- Mention if removing a specific font / upload / animation suddenly fixes export.
That signals “this is reproducible and likely on your side, not mine.”
If I were in your shoes right now, quick sequence I’d try:
- Log in with a different Canva account on same device, test tiny design export.
- Open your broken design, “Make a copy,” strip all Brand Kit, custom fonts, audio, and transitions, test export.
- Remove recently added uploads and re-upload them one by one, watching for when it starts failing again.
- If it’s still cursed, send Canva a detailed ticket and, yeah, annoy them a little until they check your account backend.
Also, don’t assume “if it crashes on both mobile & desktop, it must be my devices.” When the glitch survived a full PC reinstall and a new phone, the only common factor left for me was the account, and that’s exactly where the fix came from.
Quick angle they did not dig into yet: system-level conflicts and account hygiene.
- System user profile vs app
Sometimes it is not Canva itself but your OS user profile. Create a new user account on your computer, install Canva fresh there, log in, and test a tiny design.
- If it behaves on the new OS user, your original profile has corrupted permissions or conflicting settings.
- If it still glitches, you are back to app/account/server territory.
- Time / region quirks
I have seen export crashes tied to:
- Wrong system date or time zone.
- VPNs routing traffic through far regions.
Set your system clock to automatic, disable VPN for a bit, restart, and try again. Sounds trivial, but Canva’s sync and licensing checks can freak out if your clock is way off.
- Parallel heavy apps
Canva is more RAM hungry than it looks. Instead of only killing overlays like @caminantenocturno mentioned, try a full lean session:
- Reboot desktop
- Open only Canva, no browser with 20 tabs, no streaming / game launchers
- Then export the same design
If crashes stop, you are starved for RAM or hitting GPU VRAM limits.
Broken clipboard / drag and drop
If you often paste assets from other apps: screenshots from design tools, copied SVGs, etc., test a design built only with items from Canva’s own library. External clipboard content can carry weird metadata that corrupts pages, especially SVGs. -
Version freeze tactic
When Canva on desktop autoupdates into a buggy build, sometimes the browser is fine, and sometimes the reverse. If you find one environment that works, stick to it for a while and avoid updating or switching devices until the project is delivered. Not pretty, but reliable. -
About the “product title”
Using Canva as your main “app product” has pros and cons:
Pros:
- Same interface on desktop and mobile, so workflows translate easily.
- Strong template ecosystem and brand tools when they behave.
- Decent rendering quality for social, slides, and lightweight video.
Cons:
- Very sensitive to GPU, fonts, uploads, and network hiccups.
- No real offline safety net; if servers or your connection wobble, exports die.
- Complex, multi-page animated projects can hit invisible limits quickly.
- Comparing with what @stellacadente and @caminantenocturno said
They both focused a lot on GPU flags, brand kit, and asset corruption, which are all valid. I would not rely only on disabling hardware acceleration though. If turning the GPU off is the only way Canva runs, that usually means you should actually fix or update drivers instead of living in software rendering forever, because performance and stability will both suffer.
If you want a direct next move that avoids repeating what they covered:
- New OS user profile
- No VPN, clock on auto
- Clean session with only Canva open
- One test design that uses only built-in fonts, no brand kit, no uploads, no clipboard content
If that path works, start adding your usual pieces back in until something breaks. That gives you a clear culprit to send Canva support, and you will not be stuck trying the same reinstall / cache clear loop again.
