I’ve been trying to track my budget, savings, and debts using spreadsheets, but it’s getting messy and time-consuming. I’d like recommendations for easy-to-use personal finance software that works on both desktop and mobile, supports basic budgeting, bill reminders, and maybe some investment tracking. What tools have actually worked well for you and why?
Spreadsheet fatigue hits everyone at some point. Moving to simple software is a good idea.
Here are options that fit “easy + desktop + mobile” and don’t feel like a full-time job.
YNAB (You Need A Budget)
- Platforms: Web, Windows, Mac, iOS, Android
- Best if: You want strict control of cash flow and debt payoff.
- Strengths:
• Zero‑based budgeting. Every dollar gets a job.
• Great for avoiding overdrafts and building savings on purpose.
• Strong education and tutorials. - Weak points:
• Subscription, around $99/yr.
• Learning curve for the “give every dollar a job” method. - Example: If you get paid on the 1st, you assign that income to rent, groceries, debt, sinking funds, etc. You see exactly what is safe to spend. No guessing.
Monarch Money
- Platforms: Web, iOS, Android
- Best if: You want something like Mint but cleaner and paid.
- Strengths:
• Connects to banks, credit cards, loans, investments.
• Good net worth view and simple budgeting.
• Strong for people with multiple accounts and goals. - Weak points:
• No native desktop app, only web.
• Subscription too, around $99/yr range. - Example: You plug in all your accounts, set goals like “Pay off card by December” or “Save 5k”, and watch progress bars.
Simplifi by Quicken
- Best if: You want automatic tracking plus basic planning.
- Strengths:
• Auto imports and categorizes transactions.
• “Spending plan” for the month, shows what is left for the rest of the month after bills.
• Simple overview for cash flow, subscriptions, recurring bills. - Weak points:
• Subscription.
• Less flexible than YNAB for envelope style budgeting. - Good for you if you want something closer to Mint without getting too nerdy.
Old‑school Quicken Classic
- Platforms: Windows, Mac, mobile companion
- Best if: You want a full desktop program and detailed control.
- Strengths:
• Strong reports for years of history.
• Good at tracking debts, assets, and investments in one place. - Weak points:
• Interface feels clunky for some.
• Overkill if you only want a simple monthly budget. - If you like “owning” a desktop file and backing it up yourself, this fits.
Free or almost‑free low‑friction options
a) Tiller Money- Google Sheets or Excel plus an add‑on.
- It pulls your bank data into a spreadsheet each day.
- You keep your spreadsheet style but you stop typing everything by hand.
- Needs you to be ok with spreadsheets but saves time.
b) PocketGuard - Mobile app focused on “what is safe to spend today”.
- Less detailed, more quick view.
- Works better if you do not need intense category rules.
If you want the least headache coming from spreadsheets
- Pick one of these two first
• YNAB if you want to actively plan every dollar and attack debt.
• Monarch or Simplifi if you want automation and clean overviews.
Suggested quick test plan for you
- List your must‑haves
- Sync with your banks or no sync.
- Debt tracking with payoff dates.
- Desktop use or phone‑only is ok.
- Trial order
- Try YNAB trial for one month.
- Try Monarch or Simplifi in parallel for a week, using the same accounts.
- Decide based on
- Which one you open without dread.
- Which one gives you a clear “this is what I can spend for the rest of the month” number.
- How fast you log and review stuff.
If you share more details, like number of accounts, if you share finances with someone, and how detailed your categories are, people here can narrow it down more and help you avoid something bloated or annoying.
Spreadsheet burnout is real. I hit the same wall a couple years ago.
I’ll riff off what @voyageurdubois said, but from a slightly different angle: instead of “what’s the best app,” think “what’s the least annoying system I’ll actually keep using.”
A few options that fit simple + desktop/web + mobile:
YNAB… maybe not
People love it, but honestly, if you’re tired of messing with spreadsheets, YNAB can feel like a fancier spreadsheet with rules. Great if you want to micromanage every dollar, but if you want “set it up, check in a few times a week,” it can feel like homework. I’d only pick it if you’re really motivated to do active budgeting and manual checking. -
Monarch Money for “Mint but grown up”
- Web on desktop, apps on phone.
- Very visual, very “big picture”: budget, savings goals, debts, net worth.
- Strong for tracking multiple accounts and giving you a clear snapshot.
- Feels calmer than YNAB: less “assign every dollar,” more “here’s where everything is going.”
If you want automatic tracking plus clear goals, this hits the sweet spot.
Simplifi for “keep it light”
- Also web + mobile.
- Good if you mainly care about:
• “What’s left for the month after bills?”
• “Where is my money actually going?” - Easier to live with than old-school Quicken, and a bit simpler than Monarch.
Great balance if your main goal is: “Stop overspending, keep an eye on debts, don’t think about it all day.”
Actual Budget (often overlooked)
- Zero based “envelope” style like YNAB, but simpler and cheaper.
- Desktop app plus mobile sync.
- Less polished than YNAB, but also less preachy and complicated.
If you liked the idea of cash envelopes and want clarity without the cult-like method, this is worth a look.
For debt + goals specifically: Copilot Money or similar
- Mac / iOS focused, very clean interface.
- Strong for visualizing debts and progress.
- Weak if you live on Windows, though, so that might be a dealbreaker.
Where I mildly disagree with @voyageurdubois: I wouldn’t start by trialing a bunch all at once. That can become its own spreadsheet project. I’d:
Decide your style:
- Want to plan every dollar and really change behavior fast: try YNAB or Actual Budget.
- Want automatic tracking + clear picture without lots of rules: try Simplifi or Monarch.
Pick ONE in each camp and run it for a full month:
- If you hate touching it after a week, that’s your answer.
Non negotiables I’d check for your situation:
- Syncs with all your banks and cards in your country.
- Can track your debts with payoff progress.
- Has recurring bills/reminders so nothing is “surprise” anymore.
If you share:
- Roughly how many accounts you have
- Whether you share money with someone
- Whether you want to track investments too or just cash / debts
…folks here can probably narrow it down to one or two specific picks instead of throwing 10 apps at you.
