Need help understanding how to use Revid Ai effectively
I recently started using Revid Ai for my projects, but I’m struggling to understand its main features, best settings, and ideal workflow. I’ve checked the basic documentation, but I still feel lost about how to integrate it smoothly into my daily tasks. Can anyone explain how they use Revid Ai in real-world scenarios, and share any tips, tricks, or common pitfalls to avoid so I can get better results?
I went through this a few weeks ago with Revid AI and took some notes while I figured it out. Here is what helped me turn it from “wtf is this” into something useful in a normal workflow.
I do not know your exact use case, so I will split it into general patterns.
  1. Core idea of Revid AI
Revid works best when you treat it like a step in a pipeline, not as a magic one click app.
Typical flow looks like:
• Get source content
• Feed structured input to Revid
• Review and tweak outputs
• Export and integrate in your real tools
If you try to do everything inside Revid, it gets messy fast.
  1. Set up your “project template” first
Before you throw a real project at it, build one “dummy” project and treat it as a template.
Key things to set:
• Brand / voice profile
– Define tone: casual, formal, technical, etc
– Add writing samples from your past work
– Add banned words or style no‑nos
• Default output formats
– Examples: blog + social posts + email draft
– Name these presets clearly, like “Tech blog 1500w” or “Short LinkedIn post”
• Default structure
– Headings you expect
– Sections you always need: intro, main points, CTA, summary
Once this template feels right, clone it for future projects. It saves a lot of time.
  1. Feeding it good input
Garbage in gives you garbage out. Minimum good input:
• Goal
– What you want: “Explain X to junior devs”, “Write sales copy for Y”
• Audience
– Level: beginner / intermediate / expert
– Context: internal team, external clients, management
• Constraints
– Word range
– Things you must mention
– Things you must avoid
I usually paste a short structured brief like:
Goal:
Audience:
Format:
Length:
Must include:
Avoid:
Revid responds much better to that than to vague prompts.
  1. Key features that matter in daily use
Names differ a bit across versions, but look for these:
• “Modes” or “Tasks”
– Writing, rewriting, summarizing, outlining, etc
– Pick the exact task instead of a generic prompt
• “Memory” or “Context”
– Turn on project memory so it remembers brand and tone
– Use it for multi step work on the same project
• “Version history”
– Duplicate versions before big changes
– Keep v1, v2, v3 as you refine outputs
– Helps you compare tones and lengths
• “Document linking”
– If it lets you link multiple docs, use one doc for notes and one for final output
– Keeps your mess separate from the polished piece
  1. Settings that tend to work well
Term names differ but look for these knobs:
• Creativity / randomness
– For first drafts: medium
– For technical or precise stuff: low
• Strictness / adherence to instructions
– For marketing copy: medium
– For specs, docs, legal-ish content: high
• Length controls
– If it keeps writing too long, set a hard cap like “600–800 words” in both settings and prompt
– Ask for “short paragraphs” to avoid huge walls of text
  1. Practical workflows by project type
A) Blog posts or articles
  1. Use Revid to create an outline from your topic and bullets
  2. Edit outline manually until it matches how you think
  3. Generate section by section, not all at once
  4. After full draft, run a “clarity pass” prompt like
    “Shorten long sentences. Make this clearer for a non expert. Keep structure.”
  5. Export to your normal editor for final edits
B) Technical docs
  1. Give Revid bullet specs, error messages, code snippets
  2. Ask it to turn bullets into structured sections
  3. Force it to keep code unchanged using explicit instruction
  4. Run a second pass to add examples and edge cases
  5. Manually check anything that sounds confident but wrong
C) Social media batches
  1. Paste core idea and a link or key data
  2. Ask for 10 variations per platform
  3. Lock tone and character counts
  4. Keep a “best hooks” document and feed those as examples to Revid
  1. Integration with your existing tools
What tends to work:
• Draft in Revid
• Export to:
– Docs or Notion for collaboration
– Your CMS for formatting
– Git or internal wiki for technical content
Try not to do formatting inside Revid. Treat it like text generation, not layout.
  1. Quality control loop
This helped me dial it in:
  1. After each project, note what annoyed you
    Example: “Too fluffy intros” or “Repeats itself in conclusions”
  2. Add anti patterns to your brand / style profile
    Example: “Avoid generic openings like ‘In today’s world’”
  3. Save prompts that work in a “Prompt library” doc
  4. Reuse and tweak, do not start from scratch every time
  1. Quick “starter prompt” you can adapt
You can paste this into Revid and fill in blanks:
You are helping me with: [type of project].
Audience: [who they are, level of knowledge].
Goal: [what you want the reader to do or understand].
Tone: [e.g. concise, technical, friendly, etc].
Length: [range].
Structure: [numbered list of sections you want].
Constraints:
– Use my brand voice from this example: [paste sample text].
– Avoid: [phrases, tone problems].
First, create an outline only. Wait for my approval before writing the full draft.
That little “outline first” line saves a lot of back and forth.
If you share what type of projects you run through Revid, I can write a more specific mini workflow for that case.
Revid is confusing at first because it looks like a content platform, but it behaves more like a weird hybrid between an AI editor and a preset engine.
I’ll riff off what @sonhadordobosque said and focus on stuff they didn’t really touch, plus a couple of things I actually disagree with.
1. Don’t over-template at the start
They suggested making a big project template first. Personally, that made me freeze. Revid then tried to bend every project into that one mold.
What worked better for me:
  • Start with one real project.
  • Keep settings light: tone + 1–2 output types, that’s it.
  • Let your actual annoyances drive what you add to the template later.
If you build some “perfect” template before you’ve done 2–3 real projects, you’ll overengineer it and spend more time fighting it than using it.
2. Learn the “panel” you’ll live in
Revid usually has 3 core areas that matter day to day:
  1. Input / reference panel
    Where you dump:
    • briefs
    • notes
    • client instructions
    • links
    Treat it like a scratchpad. Don’t try to keep it clean.
  2. Working doc panel
    This is your “main” doc. I use it for the actual article / script / email.
  3. Side actions / tools
    Stuff like:
    • “Improve this section”
    • “Shorten this”
    • “Change tone”
    • “Generate alternatives”
Instead of writing prompts from scratch every time, get used to right clicking / selecting text and choosing an action. That’s honestly where the time savings come from.
3. Build your own “macro” pattern
Revid’s real value for me was in repeating the same sequence on different inputs. Example workflow for content:
  1. Paste raw notes in an “Input” doc.
  2. Run: “Extract key points” on that doc.
  3. Move those key points into the main doc manually.
  4. Run: “Turn this into section outline.”
  5. Approve / tweak.
  6. Generate section-by-section with:
    • “Expand to 2–3 paragraphs”
    • “Make more concrete with examples”
You basically create your own “macro” process with 3–5 repeated actions instead of trying to do everything in one monsterr prompt.
4. Settings I’d actually tweak (and which to ignore)
Things I found worth touching:
  • Creativity
    • Ideation: mid–high
    • Final pass / technical: low
  • Instruction strength
    • If it keeps ignoring your constraints, crank this up first instead of rewriting the prompt 20 times.
  • Repetition / diversity
    • For social content, increase diversity so posts are not just the same line rewritten.
    • For documentation, LOWER it so phrasing stays consistent.
Stuff I usually ignore:
  • Any “auto format” magic
    Revid’s formatting guesses are meh. I turn off or ignore heavy styling and handle layout in Notion / Docs.
  • Overly aggressive length auto-settings
    I get better control just by saying “Keep this under 400 words, 3–5 paragraphs” in the prompt.
5. Single-doc vs multi-doc workflow
Tiny disagreement with the “use multiple docs” pattern:
  • For short work (emails, landing page sections, scripts under 1k words), I actually prefer a single doc with headings like:
    • Notes
    • Draft 1
    • Draft 2
    • Final
Revid’s actions work very well on isolated sections if you select them. It keeps context close and you don’t jump between docs.
  • For big work (guides, docs, multi-article stuff), then yeah, split:
    • /notes
    • /outline
    • /draft
    • /snippets (hooks, CTAs, key phrases)
Try both. One size doesn’t fit all.
6. How to integrate it into a “real” stack
Concrete way I use it with other tools:
  1. Research & rough bullets
    • I do this outside Revid (browser, notes app).
  2. Structure & drafting in Revid
    • Outline
    • Section-by-section drafting
    • Tone adjustment
  3. Final editing in my real editor
    • Google Docs for collab
    • Notion / Obsidian for knowledge base
    • Dev docs go into repo / wiki
Revid is basically my “ugly middle” stage: from messy notes to a solid v1. After that I don’t fight it on pixel-perfect formatting or comments.
7. A simple baseline workflow you can steal
Next time you open Revid, try this literal sequence:
  1. Create new project.
  2. In project settings:
    • Set tone: “clear, direct, slightly conversational”
    • Add 1 sample of your writing (just paste a paragraph).
  3. Add a doc called “Brief”:
    • Paste:
      Goal:
      Audience:
      Format:
      Length:
      Must include:
      Must avoid:
    Fill it once per project.
  4. Add a doc called “Main Draft”.
  5. Ask Revid:
    “Using the Brief doc as reference, create a detailed outline for the Main Draft. Output only headings and bullet points.”
  6. Review outline manually, edit it yourself.
  7. Then, for each section, highlight that section and run something like:
    “Expand this into 2 paragraphs. Concrete, no fluff, keep reading level around [your target].”
  8. Last step: select whole doc and run a “clean up” action:
    “Tighten, remove filler, keep structure identical.”
That’s enough to make it feel useful instead of random.
If you share what type of projects you’re using it on (client content, internal docs, social, scripts, etc.), you can get even more surgical with the workflow and you probably won’t touch half the features in the UI.
Short version: Revid Ai gets useful the moment you stop treating it like a “write my whole thing” bot and start treating it like a controlled rewriting engine that lives between your rough notes and your final editor.
Here is a different angle from what @nachtdromer and @sonhadordobosque already covered.
1. Think “editing surface,” not “generation machine”
They leaned quite a bit on templates and project structures. I’d flip it:
Use Revid Ai mostly to change text, not to create it from nothing.
Examples:
  • Take a messy paragraph and ask:
    • “Make this punchier, same meaning.”
    • “Same idea, but for non technical managers.”
  • Take a decent draft and:
    • “Cut this by 40 percent, keep all key information.”
    • “Turn this section into a bullet list.”
This avoids the usual “this sounds nothing like me” problem and keeps your voice intact.
Pros of this approach with Revid Ai
  • You keep control of content, it just polishes.
  • Less hallucination compared to from-scratch generation.
  • Easier to maintain consistent voice across projects.
  • You must bring some kind of draft.
  • Not ideal if you want zero-effort ideation.
2. Use contrast, not templates, to tune it
Instead of building giant project templates first, I like to “teach” Revid Ai using contrast pairs.
Create a doc with short samples like:
  • “Too fluffy version”
  • “Fixed version you prefer”
Then tell it explicitly:
“When I say ‘Revid style A’, write like the fixed versions, not the original ones.”
Later prompt with:
“Rewrite this in Revid style A, keep technical details strictly unchanged.”
This is less rigid than templates and more forgiving early on. You can add new pairs whenever it does something annoying.
3. Let it disagree with you on structure
Both other posts basically say “outline first, then expand,” which is solid. I slightly disagree that you always need a full outline upfront.
A useful variant:
  1. Write a short, messy mini draft yourself: 3 to 5 chunky paragraphs.
  2. Ask Revid Ai:
    “Propose 2 alternative structures for this content. Use only headings and bullets.”
You then:
  • Pick the structure you like.
  • Paste your own text into that new structure.
  • Use Revid selectively to fix transitions and clarity.
This way Revid handles architecture while you still own the sentences.
4. Treat “modes” as safety rails
Instead of generic prompts, lean on whatever Revid Ai gives you as predefined tasks:
  • “Clarify”
  • “Shorten”
  • “Change tone”
  • “Add examples”
  • “Translate for [audience level]”
These built in rails are a bit underrated. You lose some flexibility, but you:
  • Get more predictable outcomes.
  • Spend less time rewriting prompts.
  • Can chain actions: Clarify → Shorten → Adjust tone.
Pros of relying on modes
  • Faster to learn.
  • Easier to repeat across a team.
  • Sometimes feels limiting for very niche tasks.
  • You may need to fall back to custom prompts for mixed goals.
5. Decide your “cutoff point” on every project
One thing that kills people is staying in Revid Ai too long.
Before you start, decide:
  • “Revid’s job stops at:
    • v1 messy draft”
      or
    • “Clean v2, ready for human polish”
      or
    • “Only subject lines and hooks”
Then force yourself to export to Google Docs / Notion / your IDE once you reach that point.
Trying to get Revid to produce publish ready content is usually where frustration appears. Let it handle the boring middle 60 percent, not the final 5 percent.
6. Where Revid Ai actually shines vs similar tools
In practice, Revid Ai is good at:
  • Repetitive rewriting tasks (tone / length / clarity).
  • Consistency across a batch of content when you have a pattern.
  • Acting as a “bridge” between raw research and presentable drafts.
Less great at:
  • Deep research that requires fact checking.
  • Designing layouts or complex formatting.
  • Acting as a project management tool.
Compared to workflows that rely only on generic AI chat tools like those used by people such as @nachtdromer or @sonhadordobosque, Revid Ai’s advantage is its preset and project structure layer. The downside is the extra learning curve and the temptation to overstructure everything.
7. Pros & cons of using Revid Ai as a core part of your stack
  • Strong for iterative refinement on the same doc.
  • Project memory helps keep voice relatively stable.
  • Good for teams once you lock a few patterns.
  • Nice middle ground between raw chatbots and rigid templates.
  • UI and feature set feel heavy if your projects are tiny.
  • Easy to lose time tweaking settings instead of just writing.
  • Not a replacement for your main editor or CMS.
  • Requires discipline on when to leave Revid and move on.
If you feel lost right now, pick one narrow job for Revid Ai this week, like:
  • “Rewrite my intros and conclusions”
    or
  • “Turn my bullets into readable paragraphs”
Once that one job feels smooth, then worry about templates, multi doc projects and more advanced workflows.
