Need help using Perchance AI story generator for my projects
I’ve been trying to use the Perchance AI story generator for some creative writing projects, but I’m struggling to understand how to get consistent, high‑quality results. Sometimes the stories are great, other times they’re random or off‑topic. Can someone explain the best settings, prompts, or tips to make the generator more reliable and useful for longer storytelling? I’d really appreciate any guidance or step‑by‑step advice from people who’ve gotten good results with it.
Perchance is kind of “slot machine output” unless you clamp it down hard with structure. To get more consistent results, treat it like a template engine, not a magic author.
Stuff that helps a lot:
  1. Lock in your format
    Tell it exactly what you want, every time. Same wording.
Example prompt:
“Write a 1200 word story. Past tense. Third person limited from [CHARACTER NAME].
Sections:
  1. Hook (1 paragraph)
  2. Setup (3 paragraphs)
  3. Conflict escalation (4 paragraphs)
  4. Climax (3 paragraphs)
  5. Short resolution (1 paragraph).
    Tone: grounded, low humor, no meta jokes, no talking to the reader.”
Save that structure and reuse it. Change the content, keep the “rules” the same.
  1. Use constraints, not vibes
    Bad: “Make it emotional and cool.”
    Better:
    • “Max 3 named characters.”
    • “No scene changes without a blank line.”
    • “Dialogue in double quotes only.”
    • “Avoid internal monologue longer than 3 sentences in a row.”
Constraints give you more consistent pacing and style.
  1. Pre-write the skeleton yourself
    Before you ask Perchance for the full story, give it a bare outline.
Example:
“Use this outline:
  1. Jake misses the last train and gets stuck in the station.
  2. He meets an old classmate who remembers him, he does not remember her.
  3. Power outage, they get locked inside.
  4. They argue about their shared past.
  5. He realizes he treated her badly in school.
  6. They decide not to exchange contacts.”
Then say “Turn this into a story following the earlier format rules.”
You keep control of plot, it handles prose.
  1. Reuse a “style block”
    If you like one story, copy the parts of the prompt that influenced style and paste them into all future prompts.
Stuff like:
“Style reference: grounded prose, similar to a midlist contemporary novel.
Short sentences during action.
No more than 2 metaphors in the whole story.
Avoid slang.
No moral lecture at the end.”
Keep this as a reusable block. Add it every time.
  1. Fix weak outputs with short edits, not full reruns
    If the story feels off, try a short follow-up prompt instead of starting over.
Examples:
• “Rewrite the dialogue to sound more natural, keep the plot the same.”
• “Condense the middle section to half the length, keep the ending.”
• “Change the POV to third person limited from Sarah only.”
This way you keep the parts that worked and nudge the parts that did not.
  1. Control randomness
    If Perchance lets you set “temperature” or similar, use it.
    • For consistent tone, use lower values like 0.3 to 0.6.
    • For wild brainstorming, higher.
    For production stories, stay in the low to mid range.
  2. Build a stable “series bible”
    If this is for a project with recurring characters or a world, keep a separate doc with:
    • Names, ages, core traits
    • Setting rules
    • What they never do
    Paste that into the prompt as “Series bible” in short bullet form.
    Tell it “Do not contradict the series bible.”
Example:
“Series bible:
• Setting: near future US city, no magic, low tech.
• Anna: 29, paramedic, hates guns, panic in tight spaces.
• Rules: no time travel, no supernatural events.”
  1. Evaluate like a checklist
    After each output, score it on 1 to 5 for:
    • Plot coherence
    • Voice consistency
    • Character behavior
    • Ending satisfaction
If you see the same weak area often, add a rule for it in your base prompt.
Example:
If endings keep rushing, add:
“Spend at least 2 paragraphs on resolution after the climax. Do not end immediately after the fight or twist.”
  1. Save your “best seed prompts”
    Whenever you get a story you like, copy that entire input prompt somewhere.
    Label it “WORKS WELL FOR [GENRE]”
    Next time start from that, edit only details.
    Most people keep changing prompts too much and lose the consistency they had.
  2. Have two modes
    • Draft mode: fast, loose, higher randomness, short outputs. Use it to test ideas and outlines.
    • Final mode: strict format, detailed rules, lower randomness, longer outputs. Use it when you want something you can polish and keep.
If you post a sample of a prompt you used and a story you liked vs one you hated, people can help tighten the instructions even more.
Perchance is kind of a gremlin: give it freedom and it eats your plot. Since @sterrenkijker covered structure and constraints really well, I’ll hit some different angles that helped me tame it a bit.
  1. Let it discover the story, then you clean it
    Instead of demanding a perfect story in one go, use it like this:
  • First prompt: “Give me 5 high‑level story concepts in this genre with a one‑paragraph summary each.”
  • Pick 1, then: “Expand this into a detailed scene outline with beats for beginning, middle, end.”
  • Only then: “Write the full story from this outline.”
You’re basically forcing Perchance to think in stages instead of hallucinating a full plot from vibes.
  1. Make it rewrite itself with different “jobs”
    The first pass is rarely “the one.” Treat later prompts like you’re hiring a different AI to edit the first AI’s story.
    Examples:
  • “You are a line editor. Improve clarity and flow. Do not change plot events.”
  • “You are a dialogue punch‑up writer. Improve only spoken lines, keep narration the same.”
  • “You are a continuity checker. List any contradictions or dropped threads in this story.”
Then paste the story in. That last one is super underrated: you get a cheap continuity report you can directly fix in a final rewrite.
  1. Use “negative prompting” more aggressively
    People underuse the “do NOT do this” part. Go beyond “no meta jokes.” Try clusters of stuff you hate seeing:
  • “Do not:
    • Use dream sequences.
    • Use ‘it was all a dream’ or similar twists.
    • Resolve the main conflict with a speech that convinces everyone instantly.
    • Introduce new major characters in the last 20 percent of the story.”
This doesn’t make it perfect, but it dramatically cuts the worst habits.
  1. Force it to track time & space
    A lot of inconsistency comes from scenes feeling floaty. Add small rules like:
  • “Each scene must establish where the characters are in the first 2 sentences.”
  • “Mention time passing if more than an hour goes by between scenes.”
  • “If a character is injured, reference the injury at least twice later unless treated.”
You get a much more grounded story with fewer ‘teleporting’ characters.
  1. Let it self‑critique before you accept the draft
    One thing I slightly disagree with from @sterrenkijker is only using your checklist. I’d also make the model judge its own work:
    Prompt after the story:
    “Critique the story you just wrote. In 5 bullet points, list the biggest weaknesses in:
  1. pacing, 2) character motivation, 3) stakes, 4) clarity, 5) ending. Be harsh.”
Then:
“Rewrite the story addressing those exact weaknesses, keep core plot and characters.”
It often improves itself in ways you wouldn’t have thought to request.
  1. Lock your opening instead of just the whole format
    Perchance tends to set its own tone in the first 3 sentences. If you’re getting wild variability, decide on a “universal opener pattern” and reuse it. Example pattern:
  • Sentence 1: concrete action.
  • Sentence 2: sensory detail.
  • Sentence 3: hint at the main problem.
You can literally instruct:
“First paragraph must follow this pattern:
  1. Start with physical action by the protagonist.
  2. Add one sensory detail (sound, smell, or touch).
  3. End with a sentence that hints at the central problem but does not explain it.”
This alone makes the stories feel like they belong to the same project.
  1. Teach it your personal quirks
    If you want “consistent high‑quality” in the sense of “this sounds like me,” give it a sample of your own writing and say:
    “Analyze this excerpt. Summarize my style in 5 bullet points focusing on sentence length, dialogue patterns, description level, and typical emotional tone.”
Then copy those 5 bullets and paste them into future prompts as your “author style notes.” You’re not just cloning a random ‘midlist novel’ vibe; you’re steering it closer to your voice.
  1. Use partial regeneration instead of full do‑overs
    When one section sucks, don’t burn the whole thing down. Literally say:
    “Rewrite only the section between [START] and [END] to improve tension and character conflict. Do not touch anything outside those markers.”
Then paste the whole story, but bracket the bad middle. This saves the parts you liked and keeps continuity more intact.
  1. Accept that “consistent high quality” might mean “shorter”
    Perchance tends to lose coherence as the word count climbs. If your 3k stories are a mess but 800 word ones are solid, work with that:
  • Generate in 800–1000 word chunks per “chapter.”
  • At the top of each new chunk, paste a short recap:
    “Previous events, summarized in 4 bullet points: … Continue the story from here.”
You’ll get more stable quality by chaining strong shorter pieces than begging it for one flawless 5k monster.
If you want, post one prompt where the result sucked and one where it kinda worked, plus a short snippet from each, and it’s possible to spot very precise phrasing tweaks that will help your specific use case.
Quick analytical breakdown of what you can add on top of what @stellacadente and @sterrenkijker already laid out:
  1. Stop chasing “perfect prompt,” start versioning
    They’re right about templates and constraints, but if you keep mutating one monster prompt, you eventually lose track of what helped. Treat prompts like code:
  • Keep a “v1 / v2 / v3” history for your Perchance AI story generator base prompt.
  • Change only one or two variables per version (like “remove negative rules about dream sequences” or “increase target word count”).
  • After 3–4 versions, compare outputs and permanently adopt the changes that actually improved consistency.
    This feels boring, but it turns “slot machine” into “tunable system.”
  1. Use “prompt layers” instead of one monolith
    Where I slightly disagree with both: giant all‑in‑one prompts get fragile. Try layers:
  • System layer: fixed, minimal rules like POV, tense, tone, genre. Never change this.
  • Project layer: series bible & world rules. Change only between projects.
  • Task layer: what you want right now (scene, chapter, rewrite, outline). Changes every run.
    You paste them as separate labeled sections. Perchance handles this more reliably than one huge slurry of instructions.
  1. Calibrate by failure examples, not just preferences
    They focused a lot on “tell it what you want.” Add the flip side:
  • Paste a short paragraph from a Perchance story you hated and say:
    “This is a bad example. Summarize in bullets what is wrong with it.”
  • Then:
    “In the next story, avoid these problems.”
    The model is surprisingly good at avoiding its own previous sins once you force it to name them.
  1. Force continuity with explicit “state” bullets
    For multi‑scene or multi‑chapter work, the biggest issue is drift. Solve it like this before each continuation:
    “Story state so far:
  • Emotional state of protagonist: …
  • Active goals: …
  • Known unresolved questions: …
    Continue the story and keep all of these consistent.”
    Shorter and more targeted than repeating the entire story, and it stops Perchance from randomly resetting motivations.
  1. Use contrasting dual prompts when the tone feels off
    If your output swings between melodramatic and flat, run a quick comparison:
  • Prompt A: “Write the next scene very restrained, minimal emotion, focus on actions.”
  • Prompt B: “Write the same scene with strong visible emotion, but no melodrama and no speeches over 3 sentences.”
    Compare, then tell it:
    “Combine the strengths of A’s pacing with B’s emotion. Rewrite the scene.”
    This triangulation gives you a much firmer, repeatable “house style” for your project.
  1. Build a tiny “house dictionary” of recurring phrases
    To get that “same author” vibe:
  • List 10–15 phrases you like for emotions, basic actions, or transitions.
    Examples: “He swallowed the words,” “The room went very quiet,” “Her shoulders untensed a fraction.”
  • Add to your base prompt:
    “When appropriate, prefer these phrases over inventing new ones. Do not overuse them, max once per story each.”
    You get recognizable texture without obvious repetition.
  1. Don’t always rewrite, sometimes trim
    Instead of asking Perchance to regenerate a weak passage, try:
    “Shorten the following text by 40 percent while keeping all plot beats and character decisions. Remove clichés and redundant metaphors.”
    Often the structure is fine and the bloat is what makes it feel low quality. Trimming preserves what worked.
  2. Pros & cons of using Perchance AI story generator for this
    Pros:
  • Very fast for multiple iterations, which is ideal if you adopt versioned prompts and layered structure.
  • Good at filling in prose once you control format and “state” as above.
  • Easy to treat like a modular engine for outlines, drafts, and rewrites.
Cons:
  • Quality drops sharply when you push for long, unstructured pieces in a single go.
  • Sensitive to subtle prompt noise: one vague sentence can override your careful rules.
  • Inconsistent “voice” unless you really commit to the style blocks, house dictionary, and layered prompts.
Compared with how @stellacadente leans into strict templates and how @sterrenkijker likes staged discovery & self‑critique, the sweet spot for you is probably:
  • A small, frozen system + project layer
  • Aggressive use of “story state so far” bullets
  • Rare but controlled tweaks via versioned prompts
    That gives you repeatable behavior without getting buried under a 2‑page mega‑prompt every time you just want a 1.2k story.
