Has anyone else had problems with the Liven app, like missing rewards, slow customer support, or issues posting honest reviews? I’m trying to figure out if it’s just me or a wider problem before I keep using it, and I’d really appreciate advice, recent experiences, or tips on how to resolve complaints effectively.
Had some of the same issues with Liven, so you are not imagining it.
Here is what I have seen over the last 6–8 months:
Missing rewards / points
- Sometimes points do not track after paying.
- Happens more often when:
• The venue has weak internet.
• You switch between cards in the app. - What helped me:
• Screenshot the payment screen and receipt every time.
• If points do not appear after 24 hours, open a ticket with: venue, time, amount, last 4 digits of card, and screenshots. - Success rate: support fixed about 80 percent of my missing points when I had proof. Without proof they usually said nothing they coud do.
Slow customer support
- Response time for me:
• Best case: 1 day.
• Worst case: 10–14 days. - They tend to respond faster if you:
• Reply to your own ticket with “any update” after 3–4 days.
• Keep everything in one thread, do not open lots of new tickets. - I stopped chasing small amounts and only log tickets if it is a bigger reward.
Issues posting honest reviews
- I had 2 negative reviews not show up in the app.
- Both were:
• 2-star reviews with clear reasons, no swearing, no insults. - Pattern I noticed:
• Positive reviews go live quickly.
• Low-star ones sometimes stay “pending” or vanish. - To test it I did this:
• Posted a 5-star review, it appeared in minutes.
• Edited the same review later to 3 stars and added mild criticism, it stopped showing publicly. - So it looks like some kind of filter on negative reviews or heavy moderation.
Things to do if you keep using it
- Treat Liven as a “nice extra”, not as something you rely on.
- Record everything: receipts, dates, and points balances.
- Cash out rewards sooner instead of stockpiling a big balance.
- Before trusting reviews in the app, cross check with Google Maps or other review platforms.
When I decided to stop
- I stopped using it as my main dining app after:
• 3 missing reward issues in one month.
• 2 negative reviews removed or hidden. - I still use it sometimes if there is a big promo and I am ok with the risk.
Short answer from my experience.
Rewards work most of the time but break often enough to be annoying.
Support works but moves slow.
Negative reviews do not seem to get equal treatment.
If you expect occasional loss of rewards and treat the app as secondary, it is manageable. If you want reliable cashback and transparent reviews, it will frustrate you.
Not just you. I’m in a similar boat and my experience lines up with what @cazadordeestrellas said, with a few differences.
For me:
Missing rewards: I don’t actually think it’s always “technical issues.” In my case, I noticed it happened way more on promo-heavy days (big % back, special campaigns) than on regular days, even at the same venue with perfect internet. That could be coincidence, but it happened enough times that I stopped assuming it was just bad wifi. I wouldn’t bother for tiny amounts, but if a big promo “disappears,” I treat that as a red flag, not just a glitch.
Support: Yeah, slow. I’ve had 2 tickets basically die in the void with generic replies like “our team is looking into this” and then nothing. Personally I disagree a bit with the whole “keep everything in one thread” approach; I’ve actually had better luck opening a fresh ticket when an old one stalled for 2+ weeks, because it felt like the original just fell into a black hole.
Reviews: This is the bit that really bothered me. I don’t mind the odd reward going missing as much as I mind the curated reality vibe. I had a 1-star review with specific details just never appear. I toned it down to 3 stars, more “constructive”, still nothing. When I later posted a glowing review for another venue, it went live fast. Coincidence? Maybe. But as a user, I can only go off what I see: the review ecosystem doesn’t feel neutral. So I basically treat in-app reviews as marketing, not as a proper review platform. I rely on Google/Maps for actual sentiment.
Whether to keep using it:
- If you like “bonus” cashback and are ok with the occasional loss, it can still be worth it.
- If you hate chasing support or you care a lot about transparent reviews, it’s going to annoy you long-term.
- I now only use it when:
- The promo is big enough that even if it fails once in a while, I still come out ahead overall.
- I’m not choosing the venue because of Liven’s ratings. I decide based on other sources, then if Liven is available, cool, I use it.
So no, it’s not just you, and it’s not purely bad luck. It looks more like a pattern of “works enough to be tempting, inconsistent enough to be frustrating.” If you keep using it, treat the rewards as a lottery ticket, not a contract.
Quick analytical take, building on what @vrijheidsvogel and @cazadordeestrellas already laid out:
You’re not imagining a pattern, but I’d separate your decision into three angles: reliability, incentives, and alternatives.
1. Reliability & “trust cost”
The real cost with the Liven app is not just missing rewards, it is the mental overhead of tracking and chasing. Every time you think “Do I need a screenshot for this in case it breaks?” that is friction. If an app makes you behave like an auditor to get what is advertised, that is already a signal.
I’m a bit less forgiving than @vrijheidsvogel here. When a system reliably works for small, low‑promo transactions and becomes “flaky” on big promos, that is a pattern you should treat as risk, not random noise, regardless of what the root cause actually is.
2. Reviews & curation problem
I agree with both of them that the biggest red flag is not the occasional lost reward, it is the review layer. Once you suspect that negative reviews are filtered or slowed while positive ones are fast‑tracked, the whole in‑app rating system stops being useful.
Personally, if I cannot trust the distribution of reviews, I treat that feature as pure marketing. In other words: use Liven for payments / rewards if you want, but pretend the review section does not exist. Do venue discovery and due diligence on independent platforms first, then only check if Liven happens to support that venue.
3. How to frame your use of Liven
A slightly different angle from what was said already:
Think in expected value per month, not per transaction.
If you gain, say, $20 worth of rewards in a month and lose $5 worth to “glitches,” you might still be net positive. The issue is whether the annoyance and time spent chasing support is worth that $15. -
Decide your personal tolerance threshold in advance.
For example: “If I have more than 2 unresolved reward issues in a month or any ticket goes unanswered for 14+ days, I downgrade Liven to ‘only use on huge promo days’.” -
Do a 4‑week experiment.
Use it normally, but do not over‑optimize. At the end of the month, ask:- How much did I actually save?
- How many times was I irritated or had to chase support?
- Did it influence me to choose worse venues just to earn rewards?
If the emotional and time cost outweighs the savings, treat the app as an occasional tool, not a core part of how you eat out.
4. Pros & cons of sticking with Liven app
- Good when promos stack and everything tracks correctly.
- Can be a decent “nice extra” on venues you already like.
- Occasionally surfaces deals you might not find elsewhere.
- Inconsistent tracking on some payments and promos.
- Support is slow and sometimes non‑resolving.
- Review system feels curated, so ratings are of limited informational value.
- Requires you to be unusually vigilant if you care about every cent of reward.
5. Competitors / alternatives
Without recommending anyone as “better,” it is worth at least comparing behavior against alternatives in your area:
- Other dining or cashback apps that tie into card‑linked offers.
- Bank or credit card reward programs, which are often more boring but more predictable.
- Simple strategy of using a high‑cashback card plus independent review platforms for venue choice.
Comparing your real monthly net benefit from Liven to a plain, no‑headache cashback card can be revealing. If the “fun” app with flashy promos is not clearly beating a boring card in both money and convenience, that’s your answer.
Bottom line: it is not just you, and what you are seeing fits a repeatable pattern. I would not build my dining decisions around Liven. I would only layer it on top of choices I would make anyway, and only when I am comfortable treating any promised reward as “probable” rather than guaranteed.
