Need help with the Exeter Finance app
Has anyone else had issues using the Exeter Finance app to manage their auto loan account? I’m having trouble logging in, checking my balance, and making payments through the app. I need advice on whether this is a known issue, how to fix it, or if there’s a better way to manage my Exeter Finance account from my phone.
Yeah, the Exeter app is kinda flaky for a lot of people, you are not the only one.
Stuff to try first:
  1. Delete and reinstall the app.
  2. Make sure your phone OS and the app are both up to date.
  3. Turn off VPN if you use one. Their system hates VPNs.
  4. Try on WiFi and on mobile data, sometimes one works while the other fails.
Login issues:
• If it keeps looping or saying “invalid credentials” even though you know they are right, use “Forgot Username/Password” on the login screen and reset from scratch.
• Clear cache for the app in your phone settings if you are on Android. That fixes a lot of their weird login bugs.
Balance not showing:
• Log in through their website in a browser. If the site shows the correct balance and the app does not, the problem is the app, not your account.
• Take a screenshot of the broken app screen and the working web screen. If you call support, that helps.
Payments:
• If the app will not process payments, do it through the website instead. Their site is way more stable.
• Set up autopay on the web portal so you are covered even if the app dies again.
• Check your bank for pending transactions before you retry, their app errors out but sometimes still sends the payment request.
Known issues people report:
• Random logouts and “session expired” messages.
• Face ID or fingerprint not working after an update.
• Payment screen freezing or timing out.
If nothing works:
• Call Exeter support and ask if your online access is locked or flagged. Sometimes one failed login too many triggers a security lock.
• Ask them to “reset online profile” and then create a new password while on the phone.
• If you keep getting blocked, use the web portal only and treat the app as read only, or uninstall it.
Last point, always grab a confirmation number or email for payments, app or web. Their system is slow to update and it freaks a lot of people out when the balance or due amount looks wrong for a day or two.
Yeah, this is pretty common with Exeter’s app. I’ll add a few angles that @mike34 didn’t hit.
First, yes, it’s a known issue. If you check recent app store reviews, a lot of folks mention login loops, payment failures, and balances not refreshing for days. So it’s not just your phone.
Couple of things to focus on that are more “account side” than “phone side”:
  1. Check if your online profile is partially locked
    Exeter sometimes flags accounts after:
    • multiple failed logins
    • a card decline
    • an address/phone change or recent loan modification
    The weird part is they don’t always show a clear “your account is locked” message in the app. You just get generic errors. Call them and specifically ask:
    • “Is my online access or mobile access restricted, locked, or under review?”
      If yes, the app will act broken until they clear that.
  2. Payment method issues that look like “app issues”
    If your card or bank account info has:
    • expired card date
    • new debit card number from the same bank
    • changed billing address
    the app sometimes fails silently or gives a vague error instead of asking you to re‑enter everything. Try this:
    • Log in on the website
    • Completely delete the saved payment method
    • Re‑add it from scratch
      After that, try the app again. A lot of “payment failed” bugs are actually stale payment profiles.
  3. Multiple profiles / duplicate accounts
    If you ever:
    • refinanced with Exeter
    • had a co‑borrower also register online
    • changed the email tied to your login
    you can end up with two online profiles pointing to the same loan. The website usually handles it better; the app sometimes freaks out and won’t display the balance or history at all. Ask support:
    • “Do I have more than one online profile or username tied to this loan?”
      If yes, have them merge or delete the extra one.
  4. Timing issue with balances & payments
    Exeter’s system is not real‑time. A few common gotchas:
    • Payment posts at the bank, but Exeter shows old balance until the next business day
    • Late in the evening or on weekends, the “amount due” can look off, like it still wants the payment you literally just made
      Before panicking about the balance:
    • Check your bank for a pending or posted ACH
    • Wait until the next business morning and refresh on the website
    If the site is correct and the app is still wrong after a day or two, that’s on their app, not your loan.
  5. Security settings on your side
    Some people have issues if:
    • they use aggressive content blockers / “secure” DNS on WiFi
    • they have super strict device security / work profiles on Android
    Try:
    • Using a different device entirely (friend’s phone, tablet)
    • Using a different network (neighbor’s WiFi, work WiFi, etc.)
      If it works elsewhere, something on your primary device/network is blocking part of their traffic.
  6. Treat the app as optional, not required
    Personally, I stopped relying on the Exeter app after it ate one of my payments and then “found” it two days later. What I do now:
    • Use the website only for payments
    • Keep screenshots of every confirmation page
    • Turn on whatever email / text alerts they offer for “payment received”
    The app is fine for a quick peek sometimes, but I don’t trust it for anything time‑sensitive like a due‑date‑day payment.
Last bit: if you’re up against a due date and the app is acting dumb, do not keep hammering the Pay button over and over. Either use the web portal or call in the payment. Otherwise you risk multiple pending charges showing up on your bank before Exeter’s system catches up.
If the Exeter Finance app is giving you grief, I’d treat it as a “nice to have” and not the main way to manage your auto loan.
What I’d add to what @stellacadente and @mike34 already covered:
  1. Prioritize the web portal over the app
    They are right that the website is more stable, but I’d go further: build your whole routine around the browser version and use the Exeter Finance app only for quick checks.
    • Use the browser on your phone and save a shortcut to your home screen. Functionally it feels app‑like but runs on the actual site logic, which breaks less.
  2. Separate “access problem” from “account problem”
    Before fighting with the app:
    • Confirm in the browser that:
      • your due date is correct
      • no holds, recent reversals, or “returned payment” notes
        If anything looks off on the site itself, that is not an app bug, that is an account issue and only support can fix it.
  3. Stop chasing real‑time data
    Exeter’s system is batch‑y. Trying to refresh the Exeter Finance app 20 times an hour for a new balance will just stress you out. I disagree slightly with the idea of waiting “next business morning” only. In practice:
    • Assume 24 to 48 hours for balances and payoff amounts to look fully right, especially around weekends or holidays.
    • Use your bank’s posted ACH as your “source of truth” for whether you actually paid.
  4. Use redundancy near your due date
    If your due date is close, do not rely on a single channel. My approach:
    • Primary: pay through the website 2 to 3 business days early.
    • Backup: have your bank’s bill pay set up to Exeter as a separate method in case their systems are flaky.
      This protects you if both the Exeter Finance app and site start erroring the same day.
  5. Screenshot everything and keep your own log
    Both @stellacadente and @mike34 mentioned confirmations, and I’d double down:
    • Maintain a simple note or spreadsheet with:
      • date you paid
      • amount
      • method (web, phone, bank bill pay)
      • confirmation number
        When Exeter’s numbers do not match, that log plus screenshots is what gets late fees reversed.
  6. Watch out for “partial success” on payments
    A nasty edge case:
    • The app errors out.
    • Your bank shows a pending debit.
    • Exeter shows “no recent payments.”
      In that situation, do not immediately send another payment. Call Exeter, give them the pending transaction info, and ask if it is sitting in their system waiting to post. Duplicate payments can trigger temporary overpayments and weird “next due date” calculations.
  7. If you use multiple devices, pick one primary
    Constantly hopping among tablet, work phone, personal phone can create confusing sessions on a flaky app. Pick one device for app access, use the browser on others. That limits random “session expired” messages.
  8. Escalate when the story does not add up
    If support keeps telling you “everything looks fine” but:
    • your web portal contradicts the Exeter Finance app
    • your bank shows correct debits but Exeter shows missed payments
      ask for:
    • a supervisor review
    • a written account history or payment research ticket
      You are not asking for a favor, just for reconciliation of data that does not match.
Pros of using the Exeter Finance app for your auto loan:
  • Convenient when it works for quick balance glances.
  • Built‑in access to basic account info without logging in through a browser each time.
  • Can be a backup view if the website is slow.
Cons of using the Exeter Finance app:
  • Stability issues: login loops, broken biometric login, payment screens freezing.
  • Balance and due amount often lag behind reality.
  • Error messages are vague, so it is hard to tell if it is a lock, a bug, or a payment problem.
  • Can lead to duplicate payments if you keep retrying after vague failures.
Both @stellacadente and @mike34 gave solid app and account troubleshooting tips. I would combine their device‑level fixes with a mindset shift: treat the Exeter Finance app as secondary, rely on the website plus your own records as the main system, and use phone support when money has moved but Exeter’s numbers have not caught up.
