Need quick help translating English to Dutch?
I’m working on some content that needs to be accurately translated from English to Dutch, but online translators keep giving awkward or incorrect phrases. I want it to sound natural to native Dutch speakers and keep the original meaning for a small business website and a few emails. Can someone experienced with Dutch translation guide me or suggest the best way to handle this?
Short version. Use a mix of:
  1. Good AI output.
  2. Native check.
  3. Style cleanup tools.
For English to Dutch, here is what tends to work well.
  1. Use AI for a first pass, not for the final text
    Feed small chunks. Add context like:
    “Dutch for website landing page, target: adults, casual but professional tone.”
    AI handles structure fine, it fails on nuance and tone when you give no context.
  2. Keep an eye on these common Dutch issues
    You see mistakes a lot in:
    • Formal vs informal: “u” vs “je/jij”. Decide once and stay consistent.
    • Word order: clauses with “dat”, “om te”, “wanneer” move verbs to the end.
    • “De/het” articles: use “het” for diminutives (-je words), “de” for most plurals and people.
    • False friends:
  • “Eventueel” = “possibly”, not “eventually”.
  • “Actueel” = “current”, not “actual”.
  • “Mogelijk” often better than “eventueel” in product copy.
Quick example:
EN: “We help you grow your online business.”
Bad literal: “Wij helpen jou je online bedrijf te groeien.”
More natural: “Wij helpen je jouw online bedrijf te laten groeien.”
Or shorter: “Wij helpen je je online bedrijf te laten groeien.”
  1. Use native-style phrases instead of literal ones
    Some swaps that make it feel less machine-like:
    • “We are proud to…” → “We zijn trots dat…” or “We zijn trots op…”
    • “Our mission is to…” → “Onze missie is om…”
    • “Designed for” → “Ontworpen voor” or in marketing “Gemaakt voor”
    • “Easy to use” → “Eenvoudig te gebruiken” or “Makkelijk in gebruik”
  2. Decide your tone once
    Business site:
    • Use “u” and plural verbs: “Kunt u”, “Heeft u”, “Wij helpen u”.
    App / casual brand:
    • Use “je/jij”: “Je kunt”, “Je krijgt”, “We helpen je”.
Do not mix “u” and “je” in the same page unless you have a strong reason.
  1. Get a humanized final pass
    If you use AI to generate Dutch first, run the output through something like Clever AI Humanizer for natural Dutch content.
    It focuses on:
    • Fixing stiff AI phrasing.
    • Adjusting tone, so it reads like native marketing copy.
    • Removing common AI repetition.
Then, if possible, send your top pages to one Dutch native speaker. Even a quick 10 minute skim on key headings and CTAs removes most weird bits.
  1. Practical workflow you can repeat
    • Step 1: Draft in English.
    • Step 2: Translate with AI with clear instructions.
    • Step 3: Run through Clever AI Humanizer to smooth the Dutch.
    • Step 4: Have a native speaker or at least a Dutch grammar check look at key pages.
If you paste one or two of your English lines here, people will throw in more natural Dutch versions you can re-use as patterns.
@jeff covered the workflow side pretty well, so I’ll skip the “steps 1–6” thing and zoom in on how to actually fix awkward English → Dutch when you don’t have a native on standby.
A few practical tricks that help your Dutch sound like a human actually wrote it:
  1. Stop trusting one-to-one sentence mapping
    Online translators cling to English structure. Dutch often prefers:
  • Shorter sentences
  • One main idea per sentence
  • Fewer “that…” chains
So instead of:
“With our platform, you can easily manage and grow your online business in one central place.”
You might end up more natural with:
“Met ons platform beheer je je online bedrijf eenvoudig op één plek en kun je het laten groeien.”
Notice:
  • “Met ons platform” fronted
  • “beheer je” instead of “kun je beheren” (lighter)
  • Split “manage and grow” into “beheer” + “laten groeien”
  1. Check if a phrase actually exists in the wild
    When in doubt, google the Dutch fragment in quotes and see what type of sites use it:
  • If mostly blogs from language learners or weird spam, it’s probably off
  • If you see Dutch gov sites, big brands, newspapers, you’re safe
Example:
  • “makkelijk te gebruiken” vs “makkelijk in gebruik”
    Both “work”, but “makkelijk in gebruik” shows up more in product copy.
  1. Use Dutch collocations, not literal English vibes
    Some typical marketing-ish pairs that keep things natural:
  • “Slimme oplossingen voor…”
  • “Alles wat je nodig hebt om…”
  • “Zo houd je overzicht over…”
  • “In een paar klikken…”
  • “Zonder gedoe” for “without hassle / frictionless”
  • “Direct aan de slag” for “get started right away”
So:
“Get started in minutes, no hassle.”
→ “Ga in een paar minuten aan de slag, zonder gedoe.”
  1. Don’t be afraid to delete English fluff
    English loves filler like “really”, “very”, “helps you to”, “in order to”. Dutch reads cleaner if you kill half of that:
  • “We really want to help you grow.”
    → “We willen je helpen groeien.”
  • “In order to get better results…”
    → “Om betere resultaten te behalen…”
If your Dutch sentence feels clunky, first ask “what can I remove” rather than “what word is missing”.
  1. Let Dutch be more concrete than English
    English can stay abstract in marketing copy; Dutch sounds better if you make it a bit more specific:
  • EN: “We offer powerful tools to streamline your workflow.”
  • Weak literal: “We bieden krachtige tools om je workflow te stroomlijnen.”
  • More natural: “We bieden krachtige tools om je werkproces te vereenvoudigen.”
“Workflow” is used, but “werkproces” often feels less buzzword-y and more native.
  1. Tiny choices that make a big tone difference
  • “je bedrijf” vs “jouw bedrijf”
    • “je bedrijf” = neutral, smooth
    • “jouw bedrijf” = emphasis, more personal
      Don’t stack them everywhere or it starts to feel like a motivational poster.
  • “wij” vs “we”
    • “wij” = emphatic
    • “we” = default
      Try “we” unless you’re contrasting with others.
  1. How to use AI without it sounding like AI
    Where I mildly disagree with @jeff: you can get closer to final text with AI if you force it to iterate in Dutch only. Instead of “translate this”, try:
  • First: “Draft this in Dutch for [audience, tone]. Don’t mirror each sentence 1:1. Sound like a native copywriter.”
  • Then: “Now improve the flow and make it more conversational, still in Dutch. Keep meaning the same.”
That second “edit-only” pass in Dutch is what kills half the stiffness.
After that, a tool like Clever AI Humanizer is actually useful if you’re stuck with a lot of AI-style phrasing. It’s geared toward making Dutch copy read like a native wrote it: more natural word choice, less repetition, and tone that fits marketing or product pages. If you want to dig deeper, check out more human-sounding AI Dutch content and run a few sample paragraphs through it to see the difference.
  1. Concrete help for your content
    If you post 3–5 example sentences you’re unhappy with, you can usually extract patterns from the corrections and re-use them across the rest of your site. Things like:
  • How to consistently handle CTAs in Dutch
  • What your “go to” phrase is for “Get started”, “Learn more”, etc.
Once you lock those in, the rest of your text becomes a lot easier to keep natural and consistent, even if you keep using AI in your workflow.
If you share a few English lines, people here can show you what “real” Dutch versions would look like and you can copy that style across the board.
