I’m trying to choose business budgeting software for a small team and I’m overwhelmed by all the options. We need clear budgeting, forecasting, and expense tracking that syncs with our accounting tools and bank feeds. What tools are you using, what features really matter in daily use, and which platforms should I avoid based on your experience?
I went through this same mess for a 6 person team last year. Short version, pick based on your accounting tool first, then features.
Here is what worked and what sucked for us.
If you use QuickBooks Online
Look at Float or LivePlan.Float
- Tight 2 way sync with QBO. Pulls invoices, bills, bank feeds.
- Great for cash flow forecasting by day and week.
- Lets you build scenarios. Example: hire 2 people, drop marketing 10 percent, see impact.
- Expense categories map to your chart of accounts, so no double work.
- Weak on detailed departmental budgets. Good by category and high level.
LivePlan
- Good if you want budgets and simple financial forecasts plus nice reports for investors.
- Sync with QBO is slower. Often a few hours behind.
- Better for annual and quarterly planning than day to day control.
- Expense tracking is more “summary” level, not receipt level.
If you use Xero
Look at Float or Fathom.Fathom
- Strong reporting and KPIs and variance analysis.
- You set budgets in Xero or Fathom, then track performance vs budget.
- Good for board decks, not great if you want hands on expense approvals.
If you want tight control of spend
Look at Divvy, Ramp, or Spendesk, depending on your country.Example with Ramp
- Corporate cards per employee or per vendor.
- You set budgets by team, vendor, or project.
- Real time alerts when someone tries to go over budget.
- Auto syncs receipts and transactions to QBO or Xero.
- Strong for expense tracking and approvals, weaker for full 3 statement forecasting.
This works well if your biggest headache is “people buying random stuff” and you want caps and rules.
If you want a pure budgeting tool
For a small team, YNAB for Business or LivePlan are ok, but they feel a bit clunky with multiple users. -
How to choose in 1 hour
List must haves:
• Sync with: QBO, Xero, Sage, etc
• Bank feed sync
• Multi user with permissions
• Export to Excel or CSV -
Pick 3 tools that integrate natively with your accounting app. Ignore the rest.
For each, test these in the free trial:
- Create a budget by department and by expense type.
- Sync bank and see how long it takes to show a new transaction.
- Create 2 scenarios, best and worst case, and check how fast you can adjust assumptions.
- Run a report: Actual vs budget, last month and quarter.
If you want simple and your accounting is QBO, Float is the least painful in my experience. If you want tight expense control with cards, Ramp or Divvy plus simple Excel forecasting works better.
Do not try to get one tool to do forecasting, FP&A level reporting, expense approvals, and board decks perfectly. For a small team, one forecasting tool that syncs cleanly with QBO or Xero plus one spend tool with cards covers 90 percent of use cases without driving you nuts.
I’m gonna slightly disagree with @boswandelaar on one thing: I would not always start from the accounting tool first. For a small team, I’d start from: “Who actually uses this daily and what problem hurts the most?”
Roughly three common setups that actually work in the wild:
1. “We live in spreadsheets, just make them not suck” stack
If you already use Google Sheets / Excel a lot and your team is tiny:
- Use:
- LiveFlow or G‑Accon to pipe QBO/Xero data straight into Sheets
- Simple budget + forecast models in Sheets
- Why:
- You get fully custom budgeting, quick forecast tweaks, and you’re not locked into someone else’s report layout.
- Bank feeds still come via your accounting system, then flow to Sheets.
- Downside:
- No slick UI, and you need one person who’s not terrified of formulas.
- When this wins:
- You want clear forecasting and “what if” scenarios, but not yet a full FP&A tool.
- Cheaper and way more flexible than many SaaS tools.
2. “Budget + cards + approvals in one place” stack
If your main pain is “we lose track of who spent what where” and you also want budgets:
- Look at: Ramp, Divvy, or Spendesk like they said, but pair them with a lightweight planning tool:
- Example: Ramp + Jirav (QBO / Xero)
- How it plays:
- Ramp handles card spend, approvals, and real time alerts.
- Jirav handles top‑down budgets, forecasts, and department views.
- Why this can be better than trying to do it all in one app:
- Spend tools are great at controlling expenses, but almost always mediocre at genuine forecasting and scenario modeling.
- FP&A tools are the reverse. So combine them and stop expecting magic.
3. “I want structured budgeting without going full enterprise”
If you want something more “FP&A-like” than Float / LivePlan but not Netsuite‑level:
- Consider:
- Jirav, Helm (for cash flow), or Fathom if you’re Xero heavy.
- Why:
- Better for departmental budgets, headcount planning, and multi scenario forecasts than the simpler tools.
- Still syncs to QBO/Xero and bank feeds via the accounting system.
- Downside:
- Slightly steeper learning curve than Float.
- Overkill if all you want is “are we under/over budget this month.”
Key questions that will narrow this down fast:
Biggest pain right now?
- a) “We can’t see future cash clearly” → Float, Helm, Sheets + LiveFlow
- b) “Team is spending randomly” → Ramp / Divvy first, forecasting second
- c) “We need board‑level reports & variance by department” → Fathom, Jirav
Who will actually log into this?
- Only founder / finance: more advanced tool is fine.
- Managers & non finance folks: pick whatever has the simplest UI and permissioning, even if the modeling is a bit weaker.
How allergic are you to Excel/Sheets?
- If “not very,” a hybrid of Sheets + a sync tool plus a spend tool will beat 90% of the “all in one” apps and be cheaper.
If you share:
- Your accounting system (QBO, Xero, something else)
- Country
- Biggest headache: cash visibility vs controlling spend vs reporting
people can probably narrow it down to 2 concrete options instead of “yet another giant list of tools.”
Short version: I’d pick a planning style first, then a tool, even if that slightly conflicts with @cacadordeestrelas’ “accounting-first” angle and @boswandelaar’s “pain-first” angle.
1. Three planning styles that matter more than the logo
A. Centralized finance brain
One person owns the budget, everyone else just submits numbers.
- Tools that fit: Float, LivePlan, Fathom, Jirav, Helm, simple Sheets + LiveFlow.
- Works if your team is <10 and managers are not super hands-on with the numbers.
- You can get by with one “source of truth” and keep approvals in email or a spend tool.
B. Collaborative, managers own their budgets
Each team lead should see their budget, tweak forecasts, and maybe approve expenses.
- Look for: strong role-based permissions, simple UI, and easy “department” views.
- Float is a bit light here, LivePlan slightly better, Jirav / Fathom better still.
- This is where a card platform (Ramp, Divvy, Spendesk) + separate forecasting app setup shines.
C. Cash-obsessed operator
You mainly care about “will I have cash in the bank on X date” more than perfect P&Ls.
- Float and Helm are stronger here than something like LivePlan.
- A spreadsheet model fed by QBO / Xero data via LiveFlow can also be ideal.
Once you pick A / B / C, half the tools fall away immediately.
2. Where I gently disagree with what’s already been said
- I would not underestimate spreadsheets. For a 5–10 person team with someone half-comfortable in Excel, Sheets + a connector often beats mid-tier SaaS on clarity and flexibility.
- I don’t entirely buy “one forecasting + one card tool covers 90% of cases.” If you have real headcount planning or multiple revenue streams, a more FP&A oriented tool (Jirav, Fathom, etc.) can save hours even at small scale.
- Also, starting “accounting-first” can box you into mediocre budgeting if your accounting app is older or you plan to change it soon.
3. How I’d pick in practice (different angle than the other posts)
Instead of listing features, literally run this 2-week experiment:
Decide your update rhythm
Weekly cash review vs monthly budget review.- Weekly → favor Float / Helm / Sheets + connector.
- Monthly / quarterly → LivePlan, Fathom, Jirav feel better.
Define 3 non-negotiables in a sentence each
Example:- “Marketing lead can see and adjust only their budget.”
- “Founder can flip two hiring scenarios in 5 minutes.”
- “Actual vs budget by department available by the 5th of each month.”
Any app that cannot do all 3 easily is out, no matter how pretty the charts are.
Time one realistic workflow in each trial
In each candidate tool, do this exact sequence:- Import chart of accounts and last 3 months of data.
- Build a simple 12‑month department budget.
- Add a best case and worst case scenario.
- Pull an actual vs budget report after re-sync.
If you are still reading help docs after 60–90 minutes, that tool will not survive real life.
4. Thoughts on what @cacadordeestrelas & @boswandelaar suggested
Both basically nailed the main stacks:
- QuickBooks Online: Float / LivePlan as solid out-of-the-box choices.
- Xero: Float / Fathom, plus Jirav if you want more structure.
- Spend control: Ramp / Divvy / Spendesk if your real issue is random spend.
My add-on: if you go the card + approvals route (Ramp / Divvy / Spendesk), you should mentally treat that as your transaction and control layer, and pick a separate planning layer that you know will scale with complexity, not headcount.
5. About the product title ‘’ (since you mentioned including it)
Because the product title is literally an empty string here, I’ll treat it conceptually, as in “your chosen budgeting app”:
Pros of using ‘’ as your primary budgeting hub
- Single place for budgets, forecasts, and expense visibility.
- Potential for direct sync with accounting and bank feeds.
- Easier onboarding for non-finance folks if UI is simple.
- Can reduce spreadsheet chaos when your team grows beyond 3–4 people.
Cons of relying only on ‘’
- If ‘’ tries to be “all-in-one” it often ends up average at both forecasting and spend control.
- You may still need a separate card / spend tool for approvals, per-employee cards, and real-time policy enforcement.
- Many such tools are opinionated: you bend your process to their layout, which can be painful if your business model is weird.
- When complexity grows (headcount planning, multiple entities, revenue streams), you may hit the ceiling and end up back in spreadsheets or an FP&A tool anyway.
Given what you described (budgeting + forecasting + expense tracking + sync with accounting & banks), treat ‘’ as a hub but be realistic that you might complement it with:
- A card-based spend tool if approvals and caps matter.
- Or a spreadsheet / FP&A layer if you need heavy scenario modeling.
Competitors like the ones discussed by @cacadordeestrelas and @boswandelaar generally slot into one of those categories rather than doing everything perfectly.
If you drop:
- Your accounting system,
- Where you’re based,
- And whether your main stress is “future cash” vs “runaway spend” vs “reporting for others,”
you can usually narrow this to two very rational options pretty quickly and ignore the rest.
