I’m trying to pick business finance software to manage budgeting, invoicing, and cash flow for a small but growing company. I’m overwhelmed by options like QuickBooks, Xero, and various SaaS tools, and I’m worried about hidden fees, data migration headaches, and bad customer support. What tools are you using, what do you like or regret, and what would you recommend for a small team that needs room to scale?
Short version. For a small but growing company that needs budgeting, invoicing, and cash flow, pick one of these three setups and stick to it:
Easiest traditional route
• Tool: QuickBooks Online
• Best if: You are in the US, use a CPA or bookkeeper, and want something every accountant knows.
• Strengths:- Strong invoicing, bank feeds, basic budgeting
- Tons of integrations for payroll, payment processors, CRM
• Weak spots: - UI feels clunky to some
- Pricing creeps up as you add users and features
How to set it up cleanly:
• Use one bank account for operations and sync it only once. No double connections.
• Turn on recurring invoices for retainers or subscription clients.
• Set up classes or locations if you want to track departments or projects.
• Turn on automatic reminders for overdue invoices so you do less chasing. -
Cloud native and nicer UX
• Tool: Xero
• Best if: You prefer cleaner UX, work with multiple currencies, or have remote teams.
• Strengths:- Good bank reconciliation
- Strong for integrations and global use
- Decent budgeting features
• Weak spots: - Fewer US based accountants use it compared to QuickBooks
- Some reports feel limited unless you add apps
Setup tips:
• Create tracking categories for projects or business units.
• Use repeating invoices for retainers.
• Connect a cash flow app like Float or Fathom if you want more detailed forecasting. -
All in SaaS stack with specialized tools
• Core accounting: QuickBooks or Xero
• Invoicing and payments: Stripe Invoicing or Zoho Invoice
• Cash flow and budgeting: Float, Fathom, or LivePlanThis helps if:
• You need deeper cash flow modeling and budgeting than core accounting tools give.
• You want better client-facing invoices and pay links.Tradeoffs:
• More tools means more logins.
• More integration points to break.
About your worries:
Data lock-in:
• Check export options before you commit.
- QuickBooks and Xero let you export to CSV.
• Once a quarter, export key reports and a GL dump and keep them in your own storage.
Vendor risk:
• Pick tools with a big user base and solid support.
- QuickBooks, Xero, Stripe, Zoho all have large user counts.
• Avoid niche tools with no clear business model or tiny teams.
Scalability:
• If you expect to outgrow “small” within 3 to 5 years, pick something that integrates with mid-market stuff like NetSuite or Sage Intacct later. QuickBooks and Xero both have that.
Concrete suggestions by stage:
If you are under 10 employees and less than 1M revenue
• QuickBooks Online Simple Start or Essentials
• Use native invoicing
• Turn on basic budget vs actual reports
• Add a spreadsheet for higher level planning
If you are 10 to 40 employees or 1M to 5M
• QuickBooks Online Plus or Xero Growing
• Add:
- Float for cash flow forecasting
- Either Stripe or a proper invoicing tool if you want branded invoices and card payments
• Put your budget process in one place. Either in the accounting tool or a linked Google Sheet, not both.
Process tips so you do not drown:
• Close books every month by day 10.
• Look at three numbers each week.
- Cash in bank
- AR aging (who owes you)
- AP aging (who you owe)
• If you do projects, track gross margin by project.
If you want one single tool and no stack:
• QuickBooks Online Plus is the safest bet for most US small businesses.
• Xero is better if your accountant is already comfortable with it or you are not US focused.
Final practical step:
• Book a 30 to 60 minute call with a local or remote accountant who works with 20 to 50 small businesses.
• Ask them what they use for 80 percent of their clients in your size range and industry.
• Pick that, and commit to it for at least 18 to 24 months before you think about switching.
You’re not crazy for feeling overwhelmed. The “small biz finance stack” rabbit hole is endless.
I agree with a lot of what @mike34 said, but I’d tweak the decision-making angle a bit. Instead of starting from “which tool is best generally,” I’d start from 3 constraints:
- Who’s actually doing the day‑to‑day
- How ‘boring’ you want your system to be
- How often you expect to switch tools
Quick points on tools without repeating the whole QuickBooks vs Xero breakdown:
1. Decide by who will own the books, not by features
- If you personally will be in it a lot and you’re not an accounting nerd, value clean UI over “every accountant uses it.”
- Xero or even something like Zoho Books or Wave (if you’re super early and in a supported region) can be perfectly fine.
- If a bookkeeper / CPA will run everything, ask them what they insist on. I’d actually put more weight on that than on long feature lists.
- If you plan to in‑house a controller in 2–3 years, pick whatever integrates well with mid‑market (QuickBooks or Xero), but don’t overthink it.
2. All‑in‑one vs stack: I slightly disagree with the push to add lots of apps early
Mike suggests Float, Fathom, LivePlan etc, which are great, but for a “small but growing” shop it’s really easy to overtool.
My rule of thumb:
- Under ~1.5M revenue or <15 heads:
- Accounting + native invoicing + a single spreadsheet for higher‑level planning. That’s it.
- You can do surprisingly useful cash flow forecasts with:
- Last 6 months of bank transactions
- A simple 12‑week cash tab in Google Sheets
- Only bolt on a dedicated cash flow tool when:
- You have recurring revenue with churn / expansion you want to model, or
- You’re raising money / taking on debt and need nicer scenarios.
Otherwise you end up logging into six apps and still not looking at any of them.
3. Focus on 3 workflows, not “features”
Whatever tool you choose, test it on these before committing:
Send 3 real invoices
- How fast can you create a customer, send an invoice, attach terms, and accept card / ACH?
- If it takes more than 5 minutes once you know where stuff is, that UI will annoy you for years.
Categorize 50 bank transactions
- Connect your main bank
- Categorize a chunk of transactions
- If you feel like “this is torture,” pick the other tool. You will do this thousands of times.
Create a simple budget vs actual
- Add a 12‑month budget
- Run a budget vs actual report for at least one month
- If you need a video tutorial and a stiff drink to figure it out, that’s a red flag.
Do that in QuickBooks and then in Xero (trial accounts). Let the experience decide. On paper they’re both “good enough.”
4. About your worries:
Data lock‑in
- Don’t just check “export to CSV.” Try actually exporting a sample general ledger and re‑importing into a spreadsheet.
- If you cannot make sense of your own export, the data is practically locked even if technically available.
- Personally I snapshot: GL, AR aging, AP aging, and P&L monthly to my own storage. That’s your “off‑ramp insurance.”
Vendor risk
- I’d be more worried about tiny niche tools than about Intuit or Xero vanishing.
- Real risk is pricing creep and them shoving new “features” into your face. Budget for annual price hikes. They will happen.
Scalability
- Most people overestimate this. QuickBooks or Xero will comfortably carry you way further than you think.
- You’re not “outgrowing” them at 2M revenue because invoicing got too hard. You only outgrow when:
- Complex inventory / multi‑entity / consolidation, or
- Tons of departments and approvals.
- Until then, optimize for clarity, not enterprise features.
5. A very opinionated recommendation pattern
Given you’re “small but growing” and need budgeting, invoicing, cash flow:
If you’re US‑centric and plan to rely heavily on a CPA:
- QuickBooks Online Plus
- Use QBO invoicing, QBO bank feeds
- One external Google Sheet for a simple 12‑week cash forecast and a 12‑month budget
If you’re more remote / global or care a lot about UI and multi‑currency:
- Xero Growing
- Same idea: native invoicing + bank feeds + one Google Sheet
No separate invoicing app yet. No cash flow SaaS yet. That’s me slightly disagreeing with the more app‑heavy approach. Most small companies need discipline, not more software.
6. Implementation sanity checks
To keep things from turning into chaos:
- One operating bank account, one card account to start
- One person is “owner” of the books, even if they’re not an accountant
- Weekly 15 minutes to check:
- Cash balance
- Who owes you
- Who you owe
- Monthly: close books, run P&L, compare to budget
- Quarterly: export your key reports and store them offline
If a tool makes that cadence feel painful, it’s the wrong tool for you, no matter how many accountants swear by it.
tl;dr: Pick QuickBooks or Xero based on who will help you, test with real invoices and real bank data, keep your stack lean, and put more energy into your process than in hunting for “the perfect” finance SaaS.
Short analytical take, building on what @shizuka and @mike34 already covered without rehashing their playbooks.
They both focused on “which tool” and “how many tools.” I’d zoom out one level: what structure do you want around your finance, then pick software that fits that structure.
Think in three layers:
System of record
This is QuickBooks or Xero almost by default for a small but growing company. Here I slightly disagree with the “try lots of tools” instinct: you really want one boring general ledger you never casually change. Switching hurts more than living with minor annoyances. -
Decision layer
This is where budgeting and cash flow decisions actually happen. Very often that is not the accounting app, it is a spreadsheet (Google Sheets, Excel) with 3 tabs:- Rolling 12-week cash view
- Annual budget vs actual
- Simple scenario tab (what if revenue +20 percent or -20 percent)
Most founders underestimate how far this can take them before needing a SaaS forecaster.
Workflow layer
This is where invoicing, approvals, and collection reminders live. Here is where you decide:- “All in one” in QuickBooks or Xero
- Or use a more polished front-end like Stripe Invoicing, Zoho Invoice, etc, feeding the accounting tool in the background.
Where I differ slightly from both:
- I would time-box your decision. Give yourself 2 weeks to test QuickBooks and Xero with real data, then commit for 24 months. The real cost is churn, not a less-than-perfect pick.
- Do not design for your hypothetical 5-year complexity. Design for 18 months out, as long as there is a credible migration path later (both QuickBooks and Xero have that).
Since you mentioned feeling overwhelmed by QuickBooks, Xero, and “various SaaS tools,” one pragmatic pattern:
- Pick one general ledger (QuickBooks Online if US-centric, Xero if more global or you care more about UI).
- Keep budgeting and cash flow in a spreadsheet until you can clearly articulate what the spreadsheet cannot do. That is your spec for a future tool like Float or Fathom.
- Revisit your stack once your finance questions become “scenario-heavy” (fundraising, debt, complex projects) rather than “what is my cash next month.”
@shizuka did a good job reframing around “who owns the books,” and @mike34 laid out clean tiered setups. Use their advice to narrow down which of the two majors fits your context, but guard against the temptation to assemble an impressive-looking “finance stack” before your basic rhythms are solid.
Concrete final thought: before buying anything else, define three recurring views you want to see every month and every week. Then choose the minimal combo of general ledger + spreadsheet that can produce those views reliably. Anything that does not serve those specific views is optional noise.
