People who've used VLC Media PLayer long-term: still happy with it? Need honest user review on VLC
Easy to find reviews from people who tried something for a week. Harder to find takes from people who’ve actually stuck with VLC over time. Anyone in that camp willing to share?
VLC Player - My Honest Review
I’ve been using VLC media player for quite a while now, mainly because it’s simple to install and doesn’t require any extra setup. You download it, open a file, and it just works, at least most of the time. I’ve tested it with different formats like MP4, MKV, and AVI, and in general it handles them without needing additional codecs.
Day-to-Day Use
For basic playback, VLC does its job. Opening files is quick, controls respond well, and things like subtitles or switching audio tracks are easy enough to manage. It’s the kind of player you can rely on for casual use without thinking too much about it.
Issues I Run Into
This is where things become inconsistent for me. Every now and then, I open a file and something just doesn’t work: In some cases, it doesn’t play audio, even though the file itself is fine.
At first I assumed it was a problem with specific files, but the same files worked fine in other players. What made it more confusing is that I saw exactly the same behavior on CachyOS. That makes me wonder: what am I doing wrong? I tried adjusting output settings and switching different modules, but nothing really fixed it in a reliable way.
Interface and Settings
The interface is functional but feels a bit outdated. It’s fine for simple tasks, but once you start digging into settings, it’s not always clear what each option does. You can tweak a lot of things, but it doesn’t always feel user-friendly when you need to troubleshoot.
Trying an Alternative
Because of these issues, I decided to try Elmedia Player.
One of the first things I noticed is how consistent playback feels. With VLC, I sometimes had to second-guess whether a file would work properly. With Elmedia, that uncertainty is mostly gone.It supports all the common formats I tested (MP4, MKV, AVI, MOV), and more importantly, it handles them without odd issues.
The interface is noticeably cleaner and more modern. It doesn’t try to expose too many technical settings upfront, which actually makes it easier to navigate.
What stood out to me:
  • The layout is more intuitive, especially for casual use
  • Controls are clearly labeled and easy to access
  • Managing playlists feels more natural and less clunky
Compared to VLC, I spent less time digging through menus and more time just watching content.
Final Thoughts
I still use VLC from time to time because it’s lightweight and familiar. But I don’t fully rely on it anymore, especially when something doesn’t play correctly. At that point, I usually switch to Elmedia instead of trying to fix the issue.
If you’re experiencing the same problems, especially on CachyOS, it might not be something you configured incorrectly. It could simply be how VLC behaves on certain setups.
I’ve used VLC for years on Windows, Linux, and macOS. My take, it is still worth keeping, but not worth treating like your only player.
What VLC still does well:
It opens almost any file.
It starts fast.
It handles subtitles and audio track switching well.
It stays light on system resources for normal 1080p playback.
Where I disagree a bit with @mikeappsreviewer, VLC has been more stable for me on Windows than on Linux. On Linux, I’ve seen odd hw accel issues, subtitle timing bugs, and random audio output weirdness. On Windows, it’s been boring in a good way.
Where VLC shows its age:
The UI feels dated.
Settings are messy when somthing breaks.
Updates are steady, but they don’t always make the app feel more polished.
Large 4K HDR files are where I notice hiccups most often.
If you want one player with fewer headaches, I’d look at Elmedia Player on Mac. It feels cleaner and I spend less time poking menus. VLC is still a solid backup tho, and for many people it’s enough. My honest answer, yes, still worth using. Full switch? Depends on your OS and how often you hit weird files.
I’m a little less harsh on VLC than @mikeappsreviewer, but also less loyal to it than @espritlibre sounds.
Short version: yes, VLC is still worth using in 2026, just not as some untouchable king of media players.
Why I still keep it installed:
  • absurd file compatibility
  • portable and lightweight
  • no codec scavenger hunt
  • great for random old files, test clips, weird containers
Why I do not fully trust it:
  • UI still feels stuck in another era
  • preferences menu is a maze when somthing breaks
  • hardware acceleration can get janky depending on GPU/OS combo
  • sometimes updates fix one thing and quietly annoy another
My experience has actually been the opposite of some Linux complaints. On one of my Linux boxes VLC has been fine, but on Windows I had occasional stutter with certain HEVC files. So a lot of this is system-specific, which is honestly part of the problem.
If you want a default player and you’re on Mac, Elmedia Player is a legit option. Cleaner interface, fewer weird moments, less menu diving. VLC is still the tool-box player I reach for when a file is cursed.
So yeah, worth using? absolutely. Worth fully switching and deleting everything else? nah. Keep VLC installed, but don’t marry it.
I’m closer to @voyageurdubois on this: VLC is still worth having, but I’d push back a bit on the “backup only” framing. For a lot of people, VLC is still perfectly fine as the main player if your library is mostly normal SDR 1080p and mixed older formats.
What keeps VLC relevant:
  • still absurdly good codec support
  • no nonsense install
  • reliable subtitle handling
  • plays damaged or odd files better than many prettier apps
Where it loses points for me:
  • HDR and some high bitrate 4K can feel inconsistent
  • settings are cluttered
  • the interface has not aged gracefully
  • behavior can vary a lot by platform and GPU
I also think @espritlibre and @mikeappsreviewer are both right about one thing indirectly: VLC’s biggest weakness is not playback, it’s predictability. When it works, it’s excellent. When it misbehaves, troubleshooting feels older than the app itself.
If you’re on macOS, Elmedia Player is honestly the cleaner daily-use option.
Elmedia Player pros:
  • better looking interface
  • simpler controls
  • usually less digging through preferences
  • good streaming and playlist handling
Elmedia Player cons:
  • not as iconic for weird edge-case files as VLC
  • some features people expect in VLC’s giant toolbox are less front-and-center
  • platform fit matters more, especially if you switch between OSes a lot
My verdict: VLC is still worth using in 2026. Worth fully switching to as your one forever player? Only if you value compatibility over polish. If you want fewer annoyances day to day, especially on Mac, Elmedia Player makes more sense. Keep VLC installed either way.
