What are the best apps to help me get serious about budgeting?
I’ve tried tracking my expenses in spreadsheets, but I keep falling behind and losing track of where my money is going each month. I’m looking for budget apps that are easy to use, work well on mobile, and can help me stick to savings goals and pay off debt. What budgeting apps do you actually use and recommend, and why?
I bounced off spreadsheets too. Here’s what finally stuck for me and people I know.
  1. You Need A Budget (YNAB)
    • Style: zero based. Every dollar gets a job.
    • Best for: if you want to change habits, not only see reports.
    • Why it helps:
    • Forces you to only budget money you already have.
    • Strong goal tools for sinking funds like car repairs, holidays, etc.
    • Excellent teaching content and live workshops.
      • Downsides:
    • Subscription.
    • Takes a week or two before it feels natural.
      • If you try it, start simple.
    • 4 to 6 categories to start: Housing, Utilities, Groceries, Transport, Debt, Fun.
    • Add detail later once you trust the system.
  2. Monarch Money
    • Style: modern Mint replacement.
    • Best for: seeing the full picture with less effort.
    • Why it helps:
    • Clean mobile app, connects to banks and auto categorizes.
    • Good for tracking net worth and recurring bills.
      • Downsides:
    • Subscription.
    • Less “behavior change” coaching than YNAB, more tracking and planning.
  3. Copilot (iOS only)
    • Style: visual and simple.
    • Best for: if you like graphs and quick swipes.
    • Why it helps:
    • Fast at categorizing with swipe gestures.
    • Clear monthly “left to spend” views.
      • Downsides:
    • Apple ecosystem focused.
    • Not as strong for envelope style budgeting.
  4. Goodbudget
    • Style: digital envelopes.
    • Best for: envelope fans who want simple and cheap.
    • Why it helps:
    • You plan envelopes at the start of the month and track spending against them.
    • Good for couples that share categories.
      • Downsides:
    • Less automation.
    • Interface feels older.
  5. Simplifi by Quicken
    • Style: spending plan.
    • Best for: auto tracking without much manual work.
    • Why it helps:
    • Strong for recurring bills, subscriptions, and trends.
    • Good reports that show where your money goes over time.
      • Downsides:
    • Subscription.
    • Some people report sync bugs, so test with your banks first.
A few practical tips so you do not fall behind again:
• Pick one app and commit to a 30 day “test month”
  • Do not mix apps at the same time. That muddies the data and your brain.
• Turn on every automation possible
  • Bank connections.
  • Auto categorization rules for common merchants.
  • Alerts when you cross a budget line.
• Put in a 5 minute daily check in
  • Morning or night, open the app.
  • Approve transactions, fix wrong categories, glance at “left to spend”.
  • A short daily habit beats a big weekly catch up that you start skipping.
• Use fewer categories
  • Groceries, Restaurants, Fun, Shopping, Transport, Other.
  • You will stick with it longer if you do not micromanage every dollar.
• Tie it to something you want
  • Example: “I use this app so I hit 300 per month to travel”
  • Name that goal inside the app. YNAB, Monarch, and Simplifi all support goals.
If you want strict behavior change and are ok with some learning curve, try YNAB first.
If you want smooth tracking with strong mobile and minimal effort, try Monarch or Simplifi.
Spreadsheets are fine for theory. Apps win for daily friction. The less you have to think, the more you stay on track.
I’m with you on falling off the spreadsheet wagon. They’re like diets in January: good intentions, dead by the 10th.
@andarilhonoturno covered a bunch of the “classic” apps already (YNAB, Monarch, etc.), so I’ll throw in a few different angles and push back on a couple points.
1. PocketGuard
If you want something that just tells you “here’s what you can still spend today without screwing Future You,” PocketGuard is decent.
  • Connects to banks, auto categorizes
  • Has an “In My Pocket” number that updates as bills and savings goals are accounted for
  • Very phone friendly
    Where I disagree a bit with the heavy zero based approach: if you’re already overwhelmed, PocketGuard’s simpler “don’t go over this” view can be less mentally exhausting than assigning every last dollar a job.
2. Wally
More minimalist, a bit less hand-holdy than YNAB or Simplifi.
  • Works well if you have mixed currencies or travel
  • You can scan receipts if you’re into that
  • Good if your banks don’t sync perfectly, since it’s built with manual in mind
    If you hated spreadsheets because of data entry, though, this might feel like Spreadsheet Lite and not stick.
3. Zeta (for couples)
If part of “where is my money going” is actually “where is our money going,” Zeta is built around shared budgets.
  • Joint and individual views
  • Shared goals and bill tracking
  • Mobile first
    The catch: if you’re solo, it’s overkill.
4. Actual Budget (if you like YNAB’s idea but not subscription)
Local-first, envelope style, YNAB-ish.
  • One-time purchase instead of ongoing sub
  • Solid for people who like control over their data
    But it’s a bit geekier. If you barely tolerate tech, I’d skip this.
Where I’d nudge you differently from the usual advice:
  1. Start with “tracking only” first, not full budgeting
    Instead of trying to build the perfect budget on day one, use any app to just watch your spending for 30 days. Don’t set categories or limits beyond super broad stuff: Needs / Wants / Debt / Savings.
    Reason: most people set fantasy budgets that collide with reality in week two, then quit. Let the app show you your real baseline first.
  2. Use notifications as guardrails, not shame cannons
    Turn on:
  • Low balance alerts
  • “Big transaction” alerts
  • Category over X dollars alerts
    Turn off anything that nags you every time you buy a coffee. If the app feels like a parent, you will stop opening it.
  1. Pick an app based on your biggest failure point, not features
  • If you forget to open things: choose the one with the cleanest, least noisy mobile UI (Monarch, PocketGuard, Copilot) and put it on your home screen.
  • If you overspend emotionally: something strict like YNAB or Goodbudget actually helps, even if it’s annoying at first.
  • If syncing is always broken with your banks: pick an app that handles manual updates well (Wally, Actual, Goodbudget).
  1. Hard rule: if it feels like work for 2 straight weeks, ditch it
    Not “it’s confusing on day 2” but “I dread touching this” after 2 weeks. Budgeting has friction baked in; the app’s job is to remove extra friction. If it adds more, try a different one without guilt.
If I were you and wanted simple, mobile, and “just keep me on the rails,” I’d test in this order:
  1. PocketGuard
  2. Monarch or Simplifi
  3. YNAB only if you’re ready to treat it like a skill you’re learning, not just another app to install and forget.
